Issues | Warranty | Recalls / TSB Problems, issues, recalls, TSBs |
07-18-2015, 09:29 AM | #15 |
Drives: 2015 FR-S
What year and month was your car built? Sorry to learn the tranny needs to be replaced after only 33k miles.
07-18-2015, 12:17 PM | #16 |
Drives: 2013 whiteout frs
The Following User Says Thank You to bizintine For This Useful Post: | yo joshman (07-24-2015) |
07-18-2015, 12:19 PM | #17 |
Drives: 2015 FR-S
You can check the tag in the driver's door jamb. It will include vin, grvw, etc. The month of manufacturing is on the tag.
07-18-2015, 12:20 PM | #18 |
Drives: 2015 FR-S
...and it's great to hear toyota is stepping up and taking care of this issue for you.
07-18-2015, 12:32 PM | #19 |
MFD in 12/12
07-18-2015, 01:42 PM | #20 |
Drives: 2015 FR-S
Thanks Mr. Biz
Does anyone else know about tranny failures with stock power levels? |
07-22-2015, 07:08 PM | #21 |
Drives: 2015 FR-S
Any update on your tranny replacement?
07-23-2015, 06:17 PM | #22 |
Just got it back today and shes running better than ever. Shifts SUPER smooth, no more trouble getting into gears and no grinding noises. They also changed one of the bushings that cracked so the shift knob feels nice and tight getting into gears.
I asked them if they heard of any other cases of bad trannys but they said mine was the first. |
07-23-2015, 06:49 PM | #23 |
Drives: 2015 FR-S
What a relief...right?!
07-30-2015, 01:43 AM | #24 |
Okay so the car is still making the initial noises I brought it in for. I am no longer having trouble getting into gear so that seems to be fixed. But I am also hearing a lot of chatter when down shifting. Does anyone else get this? I hear the chatter especially when down shifting into second.
08-03-2015, 06:40 PM | #25 |
Drives: 2015 FR-S
I get the chatter because of my flywheel. Are you all stock?
08-09-2015, 12:22 PM | #26 |
power train wise i am all stock.
I think I am going to take this into my own hands install a perrin shifter bushing http://www.ft86club.com/forums/showthread.php?t=19767 and also a whiteline positive shift kit http://www.ft86club.com/forums/showthread.php?t=19782 because it seems that what i an experiencing is normal chatter |
Similar Threads | ||||
Damaged my apr splitter | Rocket.BRZ | Cosmetic Modification (Interior/Exterior/Lighting) | 23 | 07-18-2018 10:16 PM |
Damaged tire | frs_94 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-31-2015 01:09 PM |
Stock clutch+flywheel+pressure plate+ ACT lightweight flywheel & pressure plate | PineappleFriedRice | Transmission and Driveline | 0 | 11-08-2013 04:54 PM |
Wind damaged BRZ's | thermobox | Scion FR-S / Toyota 86 GT86 General Forum | 2 | 08-24-2012 04:23 PM |
