Old 08-02-2015, 10:44 PM   #99
superleggera
superleggera's Avatar
Drives: BRZ / MX5 / S4
how does it drive?!
superleggera is offline   Reply With Quote
Old 08-02-2015, 11:23 PM   #100
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Originally Posted by superleggera View Post
how does it drive?!
Right now I have the MAF disconnected because it has not been tuned yet. I am getting the Ecutek tune it yourself kit and will get a base tune from my tuner to flash into it this week. So for now I'm driving it easy at no boost and the AFR is about 22.4 - pretty rich (edit lean). It drives fine and by some act of God 2nd gear engaged today. Can't wait till I can actually open her up!
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
Old 08-02-2015, 11:27 PM   #101
migueralliart
migueralliart's Avatar
Drives: 2013 Firestorm FRS
Wait an AFR of 22? Wouldn't that be waaaay to lean?
migueralliart is offline   Reply With Quote
The Following 2 Users Say Thank You to migueralliart For This Useful Post:
D_Thissen (08-02-2015), TurboBRZ (08-03-2015)
Old 08-03-2015, 12:25 AM   #102
TurboBRZ
TurboBRZ's Avatar
Yeah you're right, brain fart... At idle it's running about 7.7 or so. Been a long day. I drove it around a circle in my neighborhood about 4x never going over 25mph or 2500 rpm.
It is possible that the main set of injectors hadn't kicked in yet - there are 2 sets on this car and I noticed when doing the coolant that the primary set didn't kick on for a good 5-8 minutes.
Old 08-03-2015, 03:34 AM   #103
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
You need to make an instagram! This FRS in Rally blue is really cool and your work deserves to have a following!
spicyricecake is offline   Reply With Quote
The Following User Says Thank You to spicyricecake For This Useful Post:
Old 08-03-2015, 03:40 AM   #104
Slammedsteve
Drives: 2013 Asphalt Fr-s,91 240sx missle
Wow great job on the repairs man! But holy sh!t does a fr-s bumper look sweet in wrb!! Looks way better then a Brz in wrb. Edit: omg I can't stop staring at the pics, holy hell does that bumper look sweet in wrb
Slammedsteve is offline   Reply With Quote
The Following User Says Thank You to Slammedsteve For This Useful Post:
Old 08-03-2015, 07:42 AM   #105
TurboBRZ
TurboBRZ's Avatar
Thanks lol. It's a BRZ though with the fr-s front end. I think the color looks great on that bumper too. Thanks for the support!
The Following User Says Thank You to TurboBRZ For This Useful Post:
Sportsguy83 (08-03-2015)
Old 08-03-2015, 07:48 PM   #106
TurboBRZ
TurboBRZ's Avatar
BIG Thanks to @Sportsguy83 for helping me out today with an ECU flash and base tune from HRI Tuning. Super nice of you for driving 45 minutes each direction just to help me out. Now my car starts and runs with the MAF and 4Bar MAP sensor installed!
Tomorrow after I get my temporary tag I'll take it out on the street for a bit of fun - but not too much until I get the full tune next weekend.
The Following 2 Users Say Thank You to TurboBRZ For This Useful Post:
Mathewgzlz (08-03-2015), Sportsguy83 (08-05-2015)
Old 08-04-2015, 11:26 PM   #107
TurboBRZ
TurboBRZ's Avatar
So tonight I took the car out a few times since it has a base tune. My wastegate has a 0.5 bar spring in it, but at max boost my gauge is only registering 5psi. I haven't gone WOT yet, but this car does make a lot more power than the stock one even without really getting on it.
The only thing bugging me is my AFR gauge - which lead me to check the mileage reading on my dash that is generated from the factory O2's. My Innovate SC2 keeps reading 7.5 or 22.4 with very little in between. If I'm not boosting it's 7.5, if I am boosting even a tiny bit it shows 22.4
So when I look at my mileage indicator and I'm still on the throttle, but very lightly - it's showing 56-114 or so mpg. Then when I'm accelerating it's bouncing around from 35-47. To me this indicates that the factory O2s are also getting a lean readout.
As the tuner has done a few of these CX kits now, including one just a week ago - and he tuned SportsGuy's car, I'm thinking his base tune is done properly but my O2s are not getting the proper readout. I'm guessing that the bungs on the downpipe are a bit too tall and thus the sensor is not getting in contact with enough exhaust gases to get a true reading. Although it seems strange since the bung I used for the wideband is the one included in the installation kit from Innovate...
Tomorrow when the engine is cool I'm going to swap the position of my wideband and the 2nd O2 sensor to see if it makes any difference on the wideband reading since the other bung is much shorter. I'm also going to hook up my Techstream to the car and do some data logging to see what the stock O2s are registering for AFR. If worse comes to worse and my tune is off a bit, SportsGuy said he'd help me out again on Thursday night at the local meetup event.
Old 08-05-2015, 10:35 AM   #108
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Innovate doesn't sell an SC2. What exactly is your wideband setup? Do you have the LC-2 hooked up to an aftermarket gauge? I believe the Innovate wideband has to be properly calibrated for it to work. Did you perform the calibration prior to install? Those numbers you keep posting don't make any sense. You should be at 14.7 at idle and cruising. You should be around 13 during partial throttle, and you should be in the 11 to 12 range during WOT.
TurboBRZ (08-05-2015)
Old 08-05-2015, 10:42 AM   #109
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I didn't get the notification. Glad to have helped and we'll work on it tomorrow at the meet.
Old 08-05-2015, 10:42 AM   #110
Sportsguy83
Drives: Limited BRZ
I think this is what the car has installed?
@TurboBRZ
http://www.innovatemotorsports.com/products/db.php
Old 08-05-2015, 10:51 AM   #111
King Tut
NASA SpecE30 Racer
King Tut's Avatar
@TurboBRZ
Probably that gauge combined with an LC-2. This is probably where he screwed up, note 0v = 7.35 A/F and 5v = 22.39 which means he is only seeing either 0 volts or 5 volts and nothing inbetween:
The DB gauge’s WHITE wire is the signal input from the
wideband controller. The gauge is setup to work with an
analog output configuration of 0v = 7.35 A/F and 5v = 22.39 A/F.
LC-2: Connect the DB gauge’s WHITE wire to the
LC-2’s YELLOW wire.
LC-1: Connect the DB gauge’s WHITE wire to the
LC-1’s BROWN wire.
LM-2: Connect the DB gauge’s WHITE wire the LM-2’s
Lime Green Wire on the analog cable. Connect the
LM-2’s yellow wire on the analog cable to the same
ground as the gauge.
LM-1: Connect the LM-1 to the computer and launch LM
Programmer. Setup the analog output 2 and configure it
as 0v = 7.35 A/F and 5v = 22.39 A/F. Lastly click on the
“Program” button.
Connect the DB gauge’s WHITE wire to the white analog
output wire of the LM-1.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Sportsguy83 (08-05-2015), TurboBRZ (08-05-2015)
Old 08-05-2015, 10:56 AM   #112
Sportsguy83
Drives: Limited BRZ
See @King Tut post above, I bet that solves it.
Probably that gauge combined with an LC-2. This is probably where he screwed up, note 0v = 7.35 A/F and 5v = 22.39 which means he is only seeing either 0 volts or 5 volts:
brz cx racing turbo, brz rebuild, brz turbo
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 05:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
