Old 07-29-2015, 09:26 PM   #2675
Lebby83
Drives: 2019 BRZ, 2016 Touareg
Originally Posted by Bramick View Post
^^^ Add to cart. Click pay now
Trust me I will add to cart once I save up some extra $$$$ for it all.
Rob
2019 BRZ Limited Sport
2016 VW Touareg TDI
Lebby83 is offline   Reply With Quote
The Following 2 Users Say Thank You to Lebby83 For This Useful Post:
Bramick (07-30-2015), ScionOfHorus (07-29-2015)
Old 07-29-2015, 09:29 PM   #2676
DaiTT500
DaiTT500's Avatar
Drives:
future Jackson racing owners and current Jackson owners, join this group if you have not already:
https://www.facebook.com/groups/792052427502668/
DaiTT500 is online now   Reply With Quote
The Following 6 Users Say Thank You to DaiTT500 For This Useful Post:
Bramick (07-30-2015), dj2020 (07-29-2015), funwheeldrive (07-30-2015), mou (07-30-2015), Sleepless (07-29-2015), Yoda (07-30-2015)
Old 07-30-2015, 10:16 AM   #2677
10Stars
Drives: 14 Subaru BRZ Limited WRB
[ame="https://www.youtube.com/watch?v=KU7_JkNxuVE"]May the BOOST be with you! Jackson Racing Supercharger Install - Scion FR-S Track Build - EP04 - YouTube[/ame]
10Stars is offline   Reply With Quote
The Following 5 Users Say Thank You to 10Stars For This Useful Post:
campy (08-01-2015), clayrush (07-30-2015), LucidMomentum (07-30-2015), mou (07-30-2015), SPCorBUST (08-01-2015)
Old 07-30-2015, 11:23 AM   #2678
ApolloSki
Stealth
ApolloSki's Avatar
Drives: Ultramarine FR-S
Originally Posted by 10Stars View Post
The part where he said his hands were going to itch for days was pretty funny. Thanks for the share.
ApolloSki is offline   Reply With Quote
Old 07-30-2015, 11:42 AM   #2679
DeliciousTuning
PhoneFlash by EcuTeK
DeliciousTuning's Avatar
But that off center maf housing though
Sincerely,
Zach
Old 08-02-2015, 04:16 AM   #2680
CSG Mike
CSG Mike's Avatar
Originally Posted by dkstylezz View Post
JRSC Carb legal with Oil cooler. Purchsed from FT86SF.
Shipping Received on june 8th
Installed on June 23rd.
Currently have around 2400 miles on the kit
No track days or drag racing.
Daily driven to work and home.
2 drives down to San Diego.
Noise started to develop around 4 weeks after the installation.
for 2 weeks sound gradually became louder and I am Concerned.
Checked clamps and hoses for leaks everything is good.
Checked Rotrex oil reservoir and oil levels are good. Followed priming instructions during installation.
No CEL
Any Help? Bad bypass valve? or bad Rotrex.
Here is one video i have several more taken on other days.
This is very upsetting to see happening.
Was your kit professionally installed or installed at home? It sounds like the supercharger may have been starved of fluid.
Old 08-02-2015, 04:24 AM   #2681
dkstylezz
dkstylezz's Avatar
Drives: 2013 Subaru BRZ
I was aware of that could happen so i have been keeping a close eye on the charger oil levels and they have not changed. It was installed in my garage with a mechanic with experience installing Rotrex kits. I personally have some experience working in a mechanic shop in Seattle too when i was younger.
I hope this does not lead to some sort of debate or worst case denial of warranty due to not having it installed at a shop.
dkstylezz is offline   Reply With Quote
Old 08-02-2015, 07:56 AM   #2682
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
No CEL
Maybe it's because you are missing half a hose clamp?
I bet it's the whistle due to a vacuum/boost leak at the open coupler.
Spinning Sushi is offline   Reply With Quote
Old 08-02-2015, 10:41 AM   #2683
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
No CEL
Your timeline as far as install -> noise developed sounds pretty similar to mine but your noise sounds a lot worse than mine.
You think half a hose clamp is just chilling on top of the coupler?
Looks like the overlap of the band to me.
Old 08-02-2015, 10:59 AM   #2684
CSG Mike
CSG Mike's Avatar
My suspicion is not that the lines are kinked, but that the supercharger may not have been primed correctly on the initial install, which lead to a momentary starvation upon initial startup.
At this point, you'd need to contact your original vendor for a warranty claim, if that's the route you'd like to go. If they are unable to do anything, or are unwilling to assist themselves, then PM me your Rotrex serial number, and we can discuss how to proceed.
Old 08-02-2015, 11:29 AM   #2685
dkstylezz
dkstylezz's Avatar
All clamps have been already checked for leaks. At first it just sounded like a wind whistle some what similar to what you would get from an aftermarket intake whistle. I also dont feel any power loss i would get form boost leak.
The noise is only present around 900 to 1000 rpm. once you get over 1000 rpm the whistle goes away. but the whine im not too sure it seems the whine got louder in the past couple days. The whistle has been developed over 2 weeks.
Old 08-02-2015, 01:14 PM   #2686
dkstylezz
dkstylezz's Avatar
I understand that could be the first question to ask. Although I don't understand how i could have done it wrong. Followed directions carefully. Made sure to unscrew the IN banjo bolt a little to let air and oil seep out. Blew air through the reservoir until i saw blue oil leaking out the banjo and tightened it to torque spec. Made sure the oil levels NEVER dropped low and checked the oil levels after letting the car idle to make sure of proper oil circulation. I also did check inside the reservoir to see if there is actually oil flowing and it was flowing.
Due to the fact of understanding the importance of the priming stage during installation, I kept myself paranoid checking oil levels and checking for leaks every opportunity i had. Even after the installation i managed to check the system before/after drives and during gas fill-ups.
Just went out side to double check the lines to see if there were any kinks or awkward bends that could cause restriction and couldn't find any. The oil was flowing well through the reservoir.
Old 08-02-2015, 01:37 PM   #2687
dkstylezz
dkstylezz's Avatar
Its not missing. Its there. half is covered under the shadow making it seem like the clamp is only half way there.
Old 08-02-2015, 04:34 PM   #2688
themajesticone
themajesticone's Avatar
Drives: '13 UM86
Anyone feel like donating me a JRSC kit? PM Me for serious offers.
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
