Old 07-28-2015, 08:44 PM   #1443
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by Arcade_West View Post
CAN SOMEONE PLEASE CONFIRM IF THIS WILL FIT SHIIIIIIIIET
18x9.5 + 43 rims, square
265/35R18 all around
Have MCA coilovers, with the ability to adjust camber front and back (but i don't want to go more than -1 deg on the rear, front can go to about -2.5 if needed)
dude. no offense but i feel like people don't even bother reading. do you see the first post? there is a reason i made it so detailed.
also could people please stop quoting photos, its frustrating as hell. if you want more pm the person or click their name --> statistics --> search threads started by said person.
yes it will fit. you will pull camber at the top hats to gain the clearance you need at the strut and should be okay. i know people running RS05RR's at +42 with a 265 and they are just fine.
what is the reason you don't want more than -1 in the rear. i would tell you to go at least -1.4.....
mcs, great suspension--what spring rates?
Jive Turkey is offline   Reply With Quote
Old 07-29-2015, 11:31 AM   #1444
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
I don't know about anyone else, but I love MEATY....
@Jive Turkey
Volks ZE40 18X10 +40
Michelin PSS 275/35/18.
I think this is as big as you can fit in the front basically with stock fenders. I barely can fit a finger between the tire and the coilover.
Old 07-29-2015, 11:35 AM   #1445
Pekingduck
Drives: 4 wheels
@Jive Turkey
Did you have any rubbing in the rear
Pekingduck is offline   Reply With Quote
Old 07-29-2015, 11:57 AM   #1446
Sportsguy83
Drives: Limited BRZ
I still haven't been able to take them through the paces, as I have two TPMS sensors clunking around inside the wheels and need to wait for the new ones.
I had done a mild fender roll to fit 265 MPSS on 9.5 wheels with +40 offset. I have driven this setup a bit, and have not rubbed yet front or back.
The fronts are not rolled at all, completely stock.
Rubbing will hugely depend on camber and ride height too.
I run right now -2.3 in the front and -1.8 in the back.
I raised the car a bit before rolling fenders last time. I had almost no fender gap before, now about 1 finger in front and two tight in the back (insert pink/sink finger jokes).
Old 07-29-2015, 03:54 PM   #1447
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Lots of good lookin cars/wheels/meats in here. hit us up if you are looking for anything for your ride!
FT-86 SpeedFactory is offline   Reply With Quote
Old 07-29-2015, 04:05 PM   #1448
stevesnj
stevesnj's Avatar
any 16" wheels?
My 2016 Build thread
Old 07-29-2015, 04:25 PM   #1449
FT-86 SpeedFactory
Originally Posted by stevesnj View Post
any 16" wheels?
we dont carry 16". we do have 17x7.5, 17x8, 17x9, 18x8, 18x9.5, 18x8.75, and 19x8.5
Old 07-29-2015, 10:23 PM   #1450
manualmotive
manualmotive's Avatar
Drives: '14 BRZ Todoroki/OriginLabo
Ended up going with the 245/40 federal SS595 on my 17x9 +35 vordovens. Here's some shitty phone pics of the first test fit; Haven't driven on them yet as I haven't gotten a post-coilover-install alignment yet, but they look pretty meaty for 245's. Fits the rear fender a lot better than I expected Planning to go lower in the front a tad with less camber but Imma see see how much it rubs first. The rear will be lower after I get RLA's as well.
manualmotive is offline   Reply With Quote
Old 07-31-2015, 12:12 AM   #1451
c4lvinnn
Drives: Toyobaruion
Gramlights 57DR
18x9.5 +38 255/35/18
Rear camber: -3.2
Front camber: -3.5
Toe: zeroed
c4lvinnn is offline   Reply With Quote
Old 07-31-2015, 12:50 PM   #1452
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Any fitment issues running 17x9 +45 wheels with a meaty tire?
Intent > Content
Old 08-01-2015, 06:44 PM   #1453
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
I run 275/40 out back.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
Old 08-02-2015, 03:05 PM   #1454
solidONE
solidONE's Avatar
With a +45 offset? How about the front?
Intent > Content
Old 08-02-2015, 03:15 PM   #1455
slicktop
245/45 front
275/40 rear
Will be rolling/pulling most likely as I haven't driven much on it yet but it looks like it'll rub.
-slicktop
2013 Scion FRS
Old 08-03-2015, 04:01 PM   #1456
JellyForSale
That Striped FRS
JellyForSale's Avatar
Drives: 2013 Ultramarine FR-S 6MT
Heres my new setup, only meaty by definition in the rear.
Enkei Kojin
18x8 Front
18x9.5 Rear
Michelin Pilot Sport A/S3
225/45/18 Front
255/45/18 Rear
Even on stock suspension no rub or issues at all!
JellyForSale is offline   Reply With Quote
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 05:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 06:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 12:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 01:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 03:05 PM
