Old 08-01-2015, 02:24 AM   #1
Scikotic
Scikotic's Avatar
Drives: 2014 FR-S Silver
A/C completely shut off...
Here's what happened... In 92 degree heat I drove to work (Hour and a half) with the A/C on full blast the whole way. My drive back home at 11pm I did not use the A/C at all. Today I get in the car and start my drive to work but only hot air comes out of the vent when I turn on the A/C. Both the A/C and recerc lights are on for full blast cool air, but not even the sniff of cold coming from the vent. So my hour and a half drive to work was full of hot air. I tried turning it on multiple times during the trip but still only hot air.
I am guessing a fuse or relay went out, but after spending a hour at work on google, I could not find where that fuse or relay is located on the car. Hopefully I am just blind and someone can just laugh at me. Otherwise I hope my compressor didn't kick the bucket when my car is barely a year old.
Anyone else have this issue happen? or know how to fix it?
Scikotic is offline   Reply With Quote
Old 08-01-2015, 02:27 AM   #2
T-Steve
Drives: 2014 BRZ
Does the air conditioning compressor come on when you press the A/C button?
(Do you hear a "clunk" and see the idle drop a few hundred RPM?)
T-Steve is offline   Reply With Quote
Old 08-01-2015, 02:48 AM   #3
Scikotic
Scikotic's Avatar
I am still at work right now, but I will check in about 45 minutes when I am off work and on my way home. What if there is a clunk? I am guessing that no clunk means the system isnt working at all
Old 08-01-2015, 04:36 AM   #4
I suggest you turn on the A/C and look to see if the clutch on the compressor engages.
At idle, when the compressor engages, you should feel/hear the engine pull down a bit.
Also, I suggest you check the fuse. It's a 50 amp fuse in the #5 slot (top right) in the fuse box under the hood. It's location is shown on page #256 (at least in my FR-S manual) of the driver's manual.
DANG, we got more 90+ degree stuff coming our way ..... I hope you get er to cool you down!
Old 08-01-2015, 07:11 AM   #5
Spinning Sushi
Legend
Spinning Sushi's Avatar
Drives: BRZ Limited
I had that happened to me when Torque decided to be an asshole and made my car throw a OBD malfunction code. I cleared the code, turned off the car, started the car and the AC was cold again.
Spinning Sushi is offline   Reply With Quote
Old 08-01-2015, 03:15 PM   #6
Scikotic
Scikotic's Avatar
Well I got back in the car to leave work last night and it was operating perfectly normal..... I am dumbfounded, but at least its working now.
Old 08-01-2015, 05:28 PM   #7
Maybe the fuse blow ...... and ......then ...... it got sooo hot in the car, that it melted back together ........
humfrz - is off his meds ......
Engine shut off by itself! Astroboy Issues | Warranty | Recalls / TSB 34 08-13-2018 01:57 PM
Rattling from front of car when you shut the engine off djdrugga24 Issues | Warranty | Recalls / TSB 8 04-01-2014 01:03 AM
Car Shut Down ScionFR-S Issues | Warranty | Recalls / TSB 10 11-22-2013 01:07 PM
Automatic shut-off whitefrs Scion FR-S / Toyota 86 GT86 General Forum 23 10-01-2012 05:47 PM
This is the coolest way to shut your truck’s tailgate ichitaka05 Other Vehicles & General Automotive Discussions 8 11-11-2011 11:46 AM
