Old 07-26-2015, 12:50 AM   #365
MGPAX
Still 17!
MGPAX's Avatar
Drives: 2014 Silver BRZ Limited
it does you just have to remove the top 3 lines from OFT log files
the bit that says proceed log, ie all lines above column headers
leave just the headers ie the rpm,load,maf v ect and data and it work fine
I'm sorry. But how do you do that?
MGPAX is offline   Reply With Quote
Old 07-26-2015, 01:01 AM   #366
steve99
Drives: FT86
just open file in text editor like notepad
wordpad ect
or even excell just save it as a csv again not excell format.
Old 07-27-2015, 10:21 AM   #367
mid_life_crisis
Drives: FR-S 10 #103 AT
Third gear would be crushing the speed limit around here.
How much will it hurt to do it in second?
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
Old 07-27-2015, 10:33 AM   #368
steve99
Drives: FT86
it will work you just dont get as much data resolution due shorter time period.
Old 07-28-2015, 11:29 AM   #369
mid_life_crisis
Having finally gone and looked at the Wiki for that tool, I can see why some people are intimidated by it at first and ask for some hand holding. I'm sure it's simple once you've done it a couple of times, but that's a lot to digest the first time around.
Old 07-28-2015, 01:54 PM   #370
mid_life_crisis
So I got the utility to generate a new MAF Scale table for me (minimal changes) but I can't get it to copy & paste to the tune file.
I've got Romraider open as Debug level.
Any ideas?
Old 07-28-2015, 03:56 PM   #371
MGPAX
Still 17!
MGPAX's Avatar
I got mine to start working again by pulling the tune file off of OFT and renaming it in my comp to anything else and putting it back on. I think it just doesn't like "old" tunes for some people.
All my tunes have maf volts again now.
Hope this helps.
Pax
I'm B00D btw.
Originally Posted by efactor84 View Post
I'm still waiting after updating my tablet from Openflash with the new logs, but no luck with MAF Voltage or IAM. Hopefully Shiv is on this issue. I did some logs, but I cannot do anything right now. My LTFT is sitting between +3-5% with Stage 2 UEL, which is kind of frustrating. I was thinking about using my stock scale and paste it on the Stage 2, sinced the MAF voltage and the Engine g/s are different to see if it would change based off Mishimoto claiming no tune required. Here is a comparison. The temperature for my IAT was reading between 93-96F. My main goal is to get the LTFT to sit -2/2+. Otherwise I'll have to wait for Vishnu Performance to come up with the update for CAL ID ZAJ1D00D to get the MAF Volt and IAM readings.
Old 08-17-2015, 10:12 AM   #372
trueno86power
[||•]=(86)=[•||]
trueno86power's Avatar
Drives: 2017 Toyota 86
Hi guys, I've just crossed this thread. Thanks to all for all the info!
I'm using a OFT Stage 2 tune with my EcuTek software.
Mods: OEM headers/gutted cat - Nameless FP/OP combo - Kakimoto Cat-back
And I've just buy an used Injen intake for really cheap. I know this is probably the worst intake on the market, but still I would love to scale the maf to make it work correcly with the OFT tune.
Just before I loose my time on scalling the MAF on the Injen, did anyone try it with success ?
trueno86power
GR | TOM'S | TRD
2017 Toyota 86
trueno86power is offline   Reply With Quote
Old 08-17-2015, 10:23 AM   #373
steve99
Drives: FT86
Any ideas?
right click on maf scale in utilility select the "Copy Romraider" option then it should work when you paste scale into romraider.
Old 08-27-2015, 11:06 PM   #374
JB86'd
JB86'd's Avatar
Drives: JAWS
Is it important to have the MAF IAT compensation table zero'd out? Or is it okay to log when the temp is about 75F, as long as all my logs are around the same temp? Average temp around my area is 75F so I'm thinking it may be ideal?
JB86'd is offline   Reply With Quote
Old 08-28-2015, 05:45 AM   #375
Kodename47
Kodename47's Avatar
Drives: UK GT86
If you're consistently logging with similar ambient temperatures then you can just leave it alone. You could just zero it out though without issue for this purpose and then return it after.
.: Stealth 86 :.
Kodename 47 DJ:
Old 08-28-2015, 05:35 PM   #376
JB86'd
JB86'd's Avatar
Drives: JAWS
Okay cool. So I'm seeing 11.25 AFR at WOT from ~5K to redline, is it better to just do closed loop scaling and datalog that, then do open loop if it's still off?
Old 09-25-2015, 11:00 PM   #377
RustySocket
Slow Learner
RustySocket's Avatar
Drives: 15 Halo FRS
I have finally gotten a grasp of how to use the @vgi tool and am currently working on scaling the closed loop portion of my MAF scale.
I've read through this entire thread and the one thing I'm not clear on is how to set the Filters and would appreciate some confirmation that I'm thinking about this correctly. Hoping @steve99 or another knowledgeable person will advise:
This is how I have the filters set up:
CL/OL Status Value = 2 (I'm using OFT for logging)
MAF Voltage Maximum = 3 (This is one I don't completely understand because I see some setting it to 5 but I believe the transition to OL happens above 3)
Engine Load Minimum = 0.05 (Not sure where this should be set)
IAT Max = 300 (Left this at the default, not sure what to do here)
AFR Maximum = 15 (again left at default, I believe I read a post that suggested it to be set to 16 but cannot find it now)
AFR Minimum = 13.7 (again left at default)
dv/dt Maximum = 0.7 ( I understand this is to remove data caused by quick changes in throttle but I'm not sure what a reasonable value is)
Cell Hit Minimum Count = 15 (Suggestions on appropriate numbers here?)
There is a wealth of information here and at times I really feel over my head but I have a desire to learn and am trying not to ask stupid questions but I've searched/read and can't get a feel for where these filters should be set to Scale the Closes Loop portion of the MAF.
Thanks for any help
RustySocket is offline   Reply With Quote
Old 09-25-2015, 11:13 PM   #378
steve99
Drives: FT86
Thanks for any help
best to leave the default values in tool
excapt maybe iat max set it to maybe 100f so it throws away high intake air temp data
AFR in Closed Loop Toyota John Software Tuning 39 07-07-2019 08:26 AM
BRZedit Fuel Trims, Closed to Open loop transiton mad_sb Engine, Exhaust, Transmission 32 08-06-2015 03:14 AM
Notes on injector / maf scalining using full time open loop mad_sb Software Tuning 40 03-03-2014 05:49 PM
Screencast: closed loop boost control with RaceRom jamesm Software Tuning 2 02-10-2014 02:23 PM
Screencast: experimenting with full-time closed loop fueling jamesm Software Tuning 2 12-27-2013 10:19 AM
