Old 07-19-2015, 09:19 AM   #15
ogrowup
Drives: Asphalt build in progress
Originally Posted by mav1178 View Post
So... just out of curiosity, have you tried changing back to the OE driveshaft?
-alex
Not yet, and really don't want to ...the carbon fiber driveshaft gives you better throttle response and a much more solid feel...The prevailing wisdom, ( and we'll find out tomorrow) that it's clutch related.
I made the following mods which by themselves are good, but together they transform the car, all of which I learned about on this forum:
1. Heel toe pedal
2. Strut braces
3. B pillar harness bar ( amazing difference, really tightened up body)
4. Kart Boy short shift kit
5. Cusco carbon Fiber /leather steering wheel
6. Carbon Fiber driveshaft
7. Wilwood big break kit
8. Fortune coil over kit
9 18x9.5 wheels and Conti 255/35 18 tires
Each of these affect the way the car feels. I'm not a technical guy, but I have a good sense of feel, and all of these items I am touching, either directly or indirectly. Major enhancement of the driving experience. Combined with a 10psi turbo,(325HP at the wheel) every time I get in this car I feel like I'm launching the space shuttle. Haha except when I can't get it into 1st.
That may just be the price I pay for modding a car. When you go down this road, you become Dr Frankenstein, putting together parts that were not necessarily meant to be together. Once that happens, you can't complain that the monster is running amok in the village...
ogrowup is offline   Reply With Quote
The Following User Says Thank You to ogrowup For This Useful Post:
Tcoat (07-20-2015)
Old 07-19-2015, 11:42 AM   #16
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
Clutch, yes, but if you swapped a part and immediately afterwards there is a problem that wasn't there prior to swapping the part, the sensible armchair mechanic in me would say for you to swap it back to stock to see if the problem goes away.
First rule of DIY mechanics is to troubleshoot by removing variables.
-alex
Old 07-20-2015, 01:42 AM   #17
RJasonKlein
RJasonKlein's Avatar
Drives: 2013 Scion FR-S 10 Series
My money is on the clutch, but you need to systematically troubleshoot to confirm it.
RJasonKlein is offline   Reply With Quote
Old 07-20-2015, 01:56 AM   #18
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
Do you have a clutch smell, ever? Have you tried the amateur testing of clutches and/or taken off the transmission to check it? Could be the little rubber/plastic ball under shifter not engaging well... but these cars too new for this.
Old 07-20-2015, 06:45 PM   #19
ogrowup
As a matter of fact, sometimes I do smell something. I usually wrote it off to a shitty job of shifting. From what I've seen and heard these cars have pretty tight and notchy gearboxes.. we are early adopters and these cars are Version 1...
Short of taking the transmission out, I have found success in putting it in 2nd gear then 1st. Going into 2nd seems to open things up ( non techincal term) and it goes into first pretty well most times.
On the bright side, it could be an awesome anti theft feature. And my 16 year cannot make it work so that's an upside as well.
Sometime soon, I'm going to have the trans pulled and take a hard look
Old 07-20-2015, 06:57 PM   #20
Packofcrows
Just remember this car dont like being shifted down to first unless you @ around 5mph. Shifting into 2nd is best at high rpms.
Old 07-24-2015, 12:49 PM   #21
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I have the exact same issue but no driveshaft and im running an ACT Xtreme pressure plate. My trans prolly has about the same milage and this issue is within the last 1000 miles if that with no mods being added. Only difference is the weather is much hotter. I only get the issue during the day and never at night. Makes me wanna sell it
lbroskee is offline   Reply With Quote
Old 07-27-2015, 03:57 PM   #22
ogrowup
The car or ACT??
It is frustrating as hell, and it makes me crazy in traffic. Thanks for this, I'm going to look at a different clutch flywheel set up because this situation has to end.
Old 07-27-2015, 04:07 PM   #23
lbroskee
lbroskee's Avatar
The car. Im on a regular flywheel. Had exact same issue with my FX350. So im to the conclusion it's heat (so boost is bad idea in Florida) or only the stock clutch is any good for us (still power limiting)
Old 07-27-2015, 06:22 PM   #24
3nl
Drives: 2015 FR-S 6MT
That's definitely not true if the car is warmed up - at 25mph it'll glide right into first at 5000rpm when doing a heel-toe with stock trans fluid (probably even more buttery with good fluid). I don't have to force it or push any harder than I would for any other downshift as long as I am properly rev-matching. Sure, it's easier to screw up a heel-toe into 1st compared to 2nd because of the ratio, but requiring driver precision doesn't mean the car doesn't like something.
Downshifting into 1st is one of the most fun things you can do in this car - sliding the ass out at low, safe speeds with power (as opposed to a handbrake) requires you to do this. I've had plenty of ass-out time in my car and haven't touched the handbrake for anything besides parking and I like my drivetrain so I don't clutch kick.
If you can't shift it into first when you are in the powerband and you are sure that you are doing it properly, you should take the car in to be checked out since it should have absolutely no problem doing this.
3nl is offline   Reply With Quote
Old 07-31-2015, 03:39 AM   #25
ogrowup
After careful investigation and comparing notes with other users of the ACT HDSS clutch and flywheel, we all have the same symptoms. I've decided to ditch the ACT clutch and flywheel and go with the clutch masters FX 300 clutch and flywheel. They assert the clutch and flywheel. Will report results after its installed.
chaoskaze (07-31-2015)
Old 07-31-2015, 04:17 AM   #26
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Ever thought about getting the jdm Toyota TRD one or STI one? Pretty sure those will probably give you less headaches...
Old 07-31-2015, 12:16 PM   #27
frsvr4
Drives: '13 FRS
So the clutch wasn't fully disengaging and instead, it caused the disk to drag between the pressure plate and flywheel and reduced the life of your transmission. Good find and good decision! Have you given ACT feedback? You could save dozens of people from this same experience if ACT makes a revision.
Ps: I see this crap all the time with my other car and it wrecks expensive synchros. It's nice that clutch options for this car are cheap and plentiful.
'13 Asphalt FR-S // 6 spd, 3M bra, BeSpoke, Sportsguy83 arm rest, YoSpeed sills & plaque, P3Cars Vent Gauge +oil P sensor; on shelf: SRP pedals
'93 Pearl White 3000GT VR-4 // 5 spd, stock block & 30+ psi: 10.5@135
frsvr4 is offline   Reply With Quote
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) — General Topics 31 03-24-2015 01:50 PM
Gear shift 'step'. -Tom- Cosmetic Modification (Interior/Exterior/Lighting) 1 01-05-2015 03:13 PM
brz series.blue gear shift from 1st - 2nd -3rd? iarefluffy Engine, Exhaust, Transmission 0 10-21-2014 04:41 AM
How to Smoothly and Quickly Up-shift from 1st to 2nd Gear? DemonRawr BRZ First-Gen (2012+) — General Topics 20 10-20-2014 04:51 PM
Manual gear shift in Automatic 86 djmm Scion FR-S / Toyota 86 GT86 General Forum 21 07-30-2014 07:08 PM
