#183 |
Drives: GBS BRZ
My understanding is it is a few different seals and is fed by engine oil. So instead of self contained oil you are running contaminated engine oil but has a greater cooling capacity. This does not translate to runs cooler all the time. For winter time use the v2 will most likely warm up faster. I would assume when you run the v2 you will need a separate oil cooler to keep things in check. Maybe someone on here that is running one can chime in?
| The Following User Says Thank You to bee_are_zee For This Useful Post: | Figo (07-23-2015) |
#184 | |
Drives: Raven Scion FR-S
Now I'm sure vortech did this for a reason for manuals and autos and tapping into a different line but I don't know how this would affect bogging and stalling. This car is all electrical and it's always a mystery but idk I'm hoping someone could explain why they do this and or why this happened and now the car runs perfect
"To make it in America you need three things, a smile, a gun, and a plan. If you need to give up one thing, give up the smile. If you need to give something else up, lose the gun. But never, ever, give up your plan."
#185 |
Drives: 2013 FRS- Hot Lava
How many people running the open flash header+ tune with their vortech? Any feedback?
#186 |
yeah i am its pretty boss... im pushing 260 whp on my automatic frs with it on 7psi ... dynojet but it was also hot and humid as a donkeys ass
| The Following User Says Thank You to ScionFR-S For This Useful Post: | sirsol66 (07-27-2015) |
#187 |
#188 |
Drives: 13' BRZ
Anyone running a turbo smart kompact bov? Just picked up a used one. All it does is flutter. I'm using a pink spring. I added 4 washers and it still flutters. You can barely hear it. Not quite what i was looking for. Setups?
edit. after reading around it seems like maybe there is too much tension. I guess Ill take the washers out and loosen the cap. Hopefully I don't need a new spring. Edit2 Fixed it today by removing all washers, then loosening the cap on the bov to the lightest setting. Works well now. Sent from HTC M8 while in burnout mode Last edited by cruizin01; 08-01-2015 at 09:24 PM. |
#189 |
Drives: Vortech Supercharged FR-S
Finally.
I'd rather lose by a mile because I built my own car,
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. Last edited by Figo; 08-13-2015 at 06:26 PM. |
| The Following User Says Thank You to Figo For This Useful Post: | JDsThatGuy (08-13-2015) |
#190 |
Is anyone running a perrin oil cooler or any other T-stat oil cooler with the Vortech kit during cold winter(snow days)? I live in NJ & PA and it is really cold here in winter.
I know that the perrin oil cooler is T-stat, and the oil should not flow to the cooler until the temp reach 185F. However, is it actually work that well in real life? A simple question is: Will the engine heat up as fast as a car without oil cooler?
than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book. ( White Tiger ) - FiGo's 車誌. |
#191 |
Drives: GT86
Hi guys,
even though I am not really active in this forum here, I'd like to share my Vortech build with you guys which I just picked up today from my local shop: - Vortech V-2 H67B Supercharger with 3.125" pulley - CP Pistons 10:1 - Pauter rods - Remax Japan oil pump - Greedy Type-R Blowoff (for electrical boost control) - ACT Clutch with light flywheel (street style) - ARP head studs - Metall head gasket - Ferrea +1 valves (intake and outtake) - Supertech double valve springs - heads have been done to fit the new valves - 550ccm injectors with oem pump - JDL UEL header with exchange cat - Motiv Concepts overpipe 2,5" - JDL Ultraquiet frontpipe 2,5" - Milltek resonated catback - Rev limiter set to 8.750 rpm As for the numbers: I achived 391 HP at the crank and 384 Nm. All on ROZ 98. Sadly the power and torque drops quite a bit after 7.000 rpm. Otherwise I had surely broken the 400's mark ![]() The 3.125" pulley spins my V-2 to approx. 56.700 rpm at the new redline generating 1.1bar boost. All of this runs on XXR 527's 8,75"x18" with 245/35 Hankook tyres. Upper curve: Power; Lower curve: Torque
| The Following 3 Users Say Thank You to w0wbagger For This Useful Post: |
#192 |
Vortech Supercharger V3 kit
Vortech Maxflow race BOV JDL UEL catless header, JDL overpipe JDL ultra quite front pipe (1 HFC + 1 resonator) ARK Grip catback The BOV sounds great at shift, but kinda too loud for me at cruising. So I have changed it back to the one that come with the sc kit. [ame="https://www.youtube.com/watch?v=1qMJnQXmyes"]https://www.youtube.com/watch?v=1qMJnQXmyes[/ame]
| The Following 3 Users Say Thank You to Figo For This Useful Post: |
#193 |
Change Maxflow race BOV to regualr BOV that came with Vortech kit today.
Check post above for the sound of Maxflow BOV. .
#194 |
Drives: 2015 Fire
Super boss bro how much are u in so far
2015 FireStorm FRS
HT Auto / TRD / Toms / FA 500 / Valenti / SPC / OFT / Borla / Flossy / Vigilant Motorsports / To be continued... |
#195 |
Drives: GBS BRZ
Does anyone know the diameter of the charge pipe on the driver side of the car? I'm talking about the 90 degree right before the intercooler.
#196 | |
Drives: WRB Limited BRZ
| The Following User Says Thank You to Alltezza For This Useful Post: | Figo (09-09-2015) |
| STX Rules and Setup Questions | Scooby South | Tracking / Autocross / HPDE / Drifting | 3914 | 07-18-2023 04:16 AM |
| Questions and Discussion on Vortech Supercharging Systems | Brian@Vortech | Forced Induction | 1462 | 01-27-2017 02:05 PM |
| Vortech Offical Owner Thread | cjsporl1996 | Forced Induction | 2 | 03-27-2014 12:50 AM |
| Who to tune Vortech setup? | pheoxs | Forced Induction | 18 | 02-20-2014 02:58 AM |
| Sprintex or Vortech, which setup has more potential? | Turbowned | Forced Induction | 328 | 09-14-2013 11:09 AM |
