#6469 |
Drives: 13 Subaru BRZ
#6470 |
It's the Mad Cow
I'm just doing what I would prefer based on my experience.
At this point it will cause a restriction but it would lower temps. Since with E85 I don't need it this is more about lowering temps under the hood then charge temps as those are fine thanks to the fuel choice. Until I decided that this unit will be the keeper and not a larger model I don't want to modify it directly. Sent from my SM-G920V using Tapatalk
05 GTO 408 Stroker \ 13 FRS 210 Twin Screw Supercharger on E85 \ 14 F-150 5.0L |
#6471 | |
#6472 |
It's the Mad Cow
Getting ambient temps pushed through the engine bay will help lower temps but if you feel otherwise congratulations.
Regardless the point is the same since I don't need the charge air cooled for running or operation adding the restriction of the intercooler and everything else in the kit would make the car lose power which would make the bay cooler but it wouldn't be the solution I want, hints why I already said it's not the solution I'm looking for at this time. If you feel the need to check the temperature of your unit by all means go for it but I'm talking about lowering temps in the bay not checking them, cooling the intake charge or modifying the unit at this time. My reasons for doing so are all valid so pushing your opinion when all I did was ask the other poster to let me know how his experience with the hood he chose went really has no bearing here. Sent from my SM-G920V using Tapatalk
| The Following User Says Thank You to Cross For This Useful Post: | clayrush (07-26-2015) |
#6473 | |
#6474 | |
It's the Mad Cow
#6475 |
Drives: 2014 BRZ (SOLD)
I have vented cf hood and Temps are not much lower like I would have thought. Although it does cool off quicker
Sent from my SAMSUNG-SM-G900A using Tapatalk
Supercharged 2014 DGM Limited
| The Following User Says Thank You to SpeedWi For This Useful Post: | Cross (07-25-2015) |
#6476 | |
It's the Mad Cow
| The Following User Says Thank You to Cross For This Useful Post: | Dream20b (07-25-2015) |
#6477 |
Drives: 2014 FT86
Run your a/c in the staging lanes. I watched a 15F difference on the torque app while sitting in the staging lanes (190F/on to 205F/off). Turn it off right after you spin to clean the tires.
| The Following User Says Thank You to SprintexUSA For This Useful Post: | Cross (07-25-2015) |
#6478 | |
It's the Mad Cow
#6479 | |
Drives: GT 86
Are you saying you did not think there was much difference between the N/A and FI cars? Could you elaborate a little more? Do you have any more info on the stock car you drove? |
#6480 |
Drives: 2014 FT86
Uncorked n/a on e85 was as quick as 8-9psi in the other two. 12psi is a different story.
| The Following User Says Thank You to SprintexUSA For This Useful Post: | CK_Bladesmith (07-26-2015) |
#6481 |
Just the tip
The 210 supercharger with a 70mm pulley is running 11.5psi on 92 octane gas, so that's much more than the N/A car with e86. Add 25 or so hp for adding e85 then you have a little more.
9psi is what comes from the 75mm pulley that comes with the sprintex kit here in 'murica.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#6482 |
Drives: 2017 Camaro 1SS
Sprintex intercooled, whatever pulley comes with intercooled kit can't remember, delicious flex fuel tune, delicious flex fuel kit, 56% ethanol, everything else stock. At 5 secs in video I push gas pedal to floor. I'm in 6th gear. I have the pedal held down... What might be causing that dip in rpm and acceleration at 6 seconds in the video? It doesn't seem to happen in lower gears. |
| Innovative ideas to increase interior storage capacity? | swift996 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 01-30-2013 10:45 PM |
| AVO vs Innovative | diss7 | Forced Induction | 32 | 01-21-2013 06:15 PM |
| Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
| Technical topic sub-forums | OrbitalEllipses | Site Announcements / Questions / Issues | 1 | 07-17-2012 11:38 PM |
| Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
