| Software Tuning Discuss all software tuning topics. |
#15 |
Drives: UK GT86
Thought I'd update this with my "finished" scale:
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 03-25-2017 at 08:20 PM. |
| The Following User Says Thank You to Kodename47 For This Useful Post: | ztan (07-12-2015) |
#16 |
Drives: Toyota 86
Thanks, that has prompted me to do a bit more tweaking. I found, as you did, that my last scale at the top of the post read a bit rich. I tried your finished scale against my PLX Bosch 4.9 and it made the Denso sensor read a bit lean compared to that reference. I also had significant STFT oscillation at closed loop cruise operation, possibly related to the sharper elbow on your last curve under AFR 12.5.
Latest scale attached with sensor correlations and summary curves of different scalings; this one is working pretty well for me with good closed loop and WOT tracking of my Bosch 4.9 wideband, there are some hysteresis issues as the Bosch wideband responds much more quickly to transients. |
#17 |
Drives: UK GT86
The MY17 seems to have improved scaling. It's going to be hard to confirm at this point of the sensors are the same however the scaling is quite similar to @ztan's. I've added the graph below
.: Stealth 86 :.
Abbey Motorsport/K47 Tuned Sprintex 210 Supercharger Kodename 47 DJ: Soundcloud / Instagram / Facebook Last edited by Kodename47; 03-25-2017 at 08:21 PM. |
#18 |
The Dictater
Drives: '13 Red Scion FRS
Sorry to bring up such an old thread, but I was wondering if non-FI folks like me would benefit from using @ztan's sensor scales specifically for more accurate logging in OL situations?
Is this a bad idea if I don't have a wideband sensor to correlate against? It wouldn't directly affect the operation of the engine much (0 lambda is still 14.7 AFR), but would affect any future changes I make. |
#19 | |
Drives: FT86
Been using that scaling in my car for years, it just allows you to see and log afr llwer than 12.17, its handy when scaling maf or logging tunes that run richer targett afr than 12.17. oft tunes for example target 11.8, but thier tunes has rescaled o2 to read that but not as low as 10. Basicly their is no harm in running this scaling |
| The Following User Says Thank You to steve99 For This Useful Post: | Spuds (05-16-2017) |
#20 | |
The Dictater
#21 |
The Dictater
So I went to go do this in my tune using romraider and Kodname's OFT definitions and there is only one front O2 sensor scaling. It doesn't indicate A or B like the screenshots above. Is this expected? It's the same for the regular OFT definitions as well.
Im also working under the assumption that I can just match my scale to the screenshot, so let me know if I am wrong on that. |
#22 | |
Drives: FT86
yes only one occurrence listed in kodes defs. yes copy the entire table |
| The Following User Says Thank You to steve99 For This Useful Post: | Spuds (05-17-2017) |
| is the front o2 sensor a wideband sensor? | mad_sb | Engine, Exhaust, Transmission | 19 | 12-13-2015 02:20 PM |
| Scaling for vortech 2.5 bar map sensor? | Frs32907 | Software Tuning | 2 | 11-08-2015 05:41 PM |
| Front Oxygen Sensor Scaling - How do we make it read richer values? | D-VO | Software Tuning | 7 | 05-08-2014 04:48 AM |
| Greddy informeter, boost sensor, boost sensor harness, info touch sensor apaptor | Supra2k | Audio/Visual, Electronics, Infotainment, NAV | 1 | 02-26-2014 08:11 PM |
