Old 07-23-2015, 05:23 PM   #15
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Ah, sponsorship deal. That explains it.
Originally Posted by JS + BRZ View Post
I was serious but wasn't sure, hence the question mark? LOL
Maybe it's because Vossen wheel and Nitto tires were backing up this project, and they gave this set. I dunno.
Originally Posted by humfrz
I'm old and lazy
JS + BRZ (07-23-2015)
Old 07-24-2015, 01:37 PM   #16
10Stars
Drives: 14 Subaru BRZ Limited WRB
Awesome car but those wheels gotta go
10Stars is offline   Reply With Quote
Old 07-24-2015, 05:11 PM   #17
Streetthrowback
Drives: 2015 brz
Nice, keep them coming
Streetthrowback is offline   Reply With Quote
Old 07-24-2015, 05:41 PM   #18
cf6mech
Drives: FRS Silver LS1 swapped.
Having owned a 2012 Boss and now a FRS can't imagine how awesome this combination might be.....pulling plugs though has got to be a bitch.....
cf6mech is offline   Reply With Quote
Old 07-24-2015, 06:05 PM   #19
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
No way, they're right there on top, middle of the valve covers. I had a coyote mustang too, just not a Boss. I can see it being a pain on an LS-series where they're down by the exhaust manifold, but not with the Coyote in there the way it is... There's nothing in the way that I can see.
On a related note, I'm having issues sourcing lots of 1UZ stuff, and I saw the coyote first fire video several weeks ago, idea wheels have been turning.
Noting that they apparently did a cut-and-weld hack job on the oil pan.... Why not just use a Canton front-sump?
Wonder if they had to relocate the MT82 shifter or if it just lined right up? It's really easy to relocate as is, and the stock remote linkage is begging for reinforcement anyway... The way the article is describing the shifter feel it sounds like they may have dropped the MGW unit on...
There are many ways to displace.
-Spartarus
Spartarus is offline   Reply With Quote
Old 07-24-2015, 06:52 PM   #20
cf6mech
MGW is a good fix, wasn't to impressed with the Chinese getrag and the feel....the MGW made a difference for me. Brain farted on plugs.
Old 07-25-2015, 09:27 AM   #21
Spartarus
...Just add nauseum
Spartarus's Avatar
We all do that haha.
Pity so few people tore apart that MT-82 transmission, there were only a few really small things wrong with it; it didn't deserve the bad rep it had.
It needed a more solid linkage - Blowfish and MGW race spec did that just fine.
With some really minor internal upgrades it would hold all the power shifts and abuse you could throw at it. Stamped shift forks needed re-welding, and all the plastic shift pads and shift stops needed replaced with brass ones. After that, it's better than any transmission I've ever driven... The synchros are good for any RPM you can throw at them.
-Spartarus
Old 12-07-2015, 09:53 AM   #22
mike@vossen
Drives: GS F-sport | LS F-Sport
This car is an amazing piece of work. Got to check it out over the summer and its super impressive!
I hope to do an expose on it next year.
mike@vossen is offline   Reply With Quote
The Following User Says Thank You to mike@vossen For This Useful Post:
NyC Zn6 (12-07-2015)
Old 01-27-2016, 04:26 PM   #23
gtslow
Drives: 2015 Halo FR-S
Having been a former owner of a Coyote V8 powered Mustang I can get behind this, however I wonder if the increased weight over an LS series engine would be worth it. Also, the chinese Getregs are known to be pretty unreliable so your cheap 6 speed option would be out.
gtslow is offline   Reply With Quote
Old 02-10-2016, 01:33 PM   #24
D K
Stig's dark passenger
54/46 weight balance
LMAO
D K is offline   Reply With Quote
The Following User Says Thank You to D K For This Useful Post:
DAEMANO (02-10-2016)
Old 02-10-2016, 01:37 PM   #25
DAEMANO
Time Traveller
LMAO
To their credit, it doesn't look like they were trying to build a racecar. More like a project/show car. What purpose does it serve, other than being a cool demo? I have no idea.
Old 02-10-2016, 02:29 PM   #26
wbradley
Sarcastic SOB
wbradley's Avatar
Cool car when competing for highest numbers. And, low key looking to boot.
In reality, probably a barely manageable time bomb if you hit the accelerator slightly too much.
Would be fun to drive with extreme care.
The Following User Says Thank You to wbradley For This Useful Post:
Old 02-10-2016, 05:02 PM   #27
Matt@Cosworth
Drives: blue - Cosworth SC stage 3.0
I would absolutely fall all over myself trying to get to GM or Ford dealer if they would pull their heads out of their ugmmm.. design arts, and start building a car similar in size to the FR-S with their badboy engines in them (3/4 size Camaro or Mustang anyone?). Of course, for a lot of reasons that will never happen.
its coming
http://www.autocar.co.uk/car-news/ne...carbon-process
Matt@Cosworth is offline   Reply With Quote
Old 02-10-2016, 05:09 PM   #28
NOHOME
Drives: RAVEN
Quote from build article:
"Understand that Tasukon was forced to dumb down the throttle nearly 20 percent at speeds slower than 30 mph just to retain some semblance of grip and drivability"
As to the wheels, I bet they picked something that looked similar to stock wheels. This thing was meant to fly under the radar.
The good news is that many such swaps now carry over the electronic gas pedal. Many a big power swap has ended up with twitchy low speed throttle response due to the mechanical linkage design that might have been less than ideal.
And while it would be sacrilegious to most of this crowd, I would have built it with an auto-tragic gearbox, cause when you have that much surplus power, why shift your own? Plus the clutch ended up sucking in this case, as do most high performance clutches.
Would love to go for a drive and see how it compares to a V8 Miata.
NOHOME is offline   Reply With Quote
RightFootDown-Video: Stock Scion FRS versus Turbo Scion FRS, Street Comparison kanundrum FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 0 06-09-2015 12:47 PM
Scion Ride and Drive- Good Info Inside, straight from Scion District Managers! clevrname Scion FR-S / Toyota 86 GT86 General Forum 29 06-16-2012 08:39 AM
Scion FR-S Behind the Scenes with Scion VP Jack Hollis scion UriarteMD FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 19 06-14-2011 07:13 PM
