Old 07-24-2015, 04:16 PM   #337
Pug_BRZ
Drives: WRB Subaru BRZ
Originally Posted by modernbeat View Post
Without having a RHD car to verify, I can't be sure, but everything except the headers should fit.
FWIW, we've actively looked for RHD models to build kits for. But either the logistics or price for one has prevented us from sourcing a car for mockup.
Yep, I certainly get that - if the logistics were possible, I'd just ship my car. But that's prohibitively expensive. I've been following the blog, and from what I've seen on a range of different blogs, the biggest issue with the FRS/BRZ in an engine swap is the CANBUS coding. Crack that ECU problem, and the exhaust is trivial in comparison.
Pug_BRZ is offline
The Following User Says Thank You to Pug_BRZ For This Useful Post:
cf6mech (07-24-2015)
Old 07-24-2015, 06:15 PM   #338
Captain Kermit
Drives: 1981 Holden Commodore
One thing I've been thinking about is the keyless entry/start in GTS spec models which the FRS doesn't have. Fortunately there are at least 4 LS conversions taking place in aus at the moment so we should get a little info soon enough.
Captain Kermit is offline
Old 07-24-2015, 07:21 PM   #339
Pug_BRZ
By whom? Links?
Pug_BRZ is offline
Old 07-24-2015, 07:29 PM   #340
Captain Kermit
By whom? Links?
2 in Qld that are being done with no/little online presence, one on the Central Coast which has occasional teaser pictures put up on the NSW 86 club Facebook page but no updates of any substance and this one in Bathurst:
https://facebook.com/madpandagarage
Old 07-24-2015, 10:33 PM   #341
Griever423
Drives: 2020 BRZ PP
Originally Posted by BRZR1 View Post
factory LS1 with cam, headers, exhuast and a tune should put down 375 pretty effortlessly.
I'm in the process of this swap myself (holding out now for vorshlag) but i will be going the Turbo LS3 route.
I think the biggest wow factor of Vorshlag is the hand tools installation and the plug and play harness.
I may end up having to go stand alone to get it all working properly but Vorshlag is still the best solution to date.
A mild street cam and tune will put it right at or a little above 400 wheel. That thing is gonna scream.
Griever423 is offline
The Following User Says Thank You to Griever423 For This Useful Post:
Old 07-27-2015, 05:17 PM   #342
Black86
Black86's Avatar
Drives: 2013 Raven Black FR-S
I would love an ls1 with cam and bolt ons in my frs lol I bet even at 330-340whp with an LS this car will be nuts..
-Raven Black 13 FR-S : The daily driver
-88 supra turbo : 2jz 66mm single on E85 in the process
Black86 is offline
Old 07-28-2015, 02:52 AM   #343
MaximeT
MaximeT's Avatar
Drives: GT86-ACE-JRZ-RPF1-Essex
Do you guys know a good shop in Europe that can do the LSx swap ?
JRZ 12-32 | ACE 350 | Delicious Tuning | RPF1 | Essex Sprint | SPL | Powerflex | My Car
MaximeT is offline
Old 08-05-2015, 06:02 PM   #344
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Updates?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline
Old 08-05-2015, 06:12 PM   #345
cf6mech
Drives: FRS Silver LS1 swapped.
Ran out of money at this point.....got the car at home and awaiting an estimate to finish up from Vorschlag with me acquiring the necessary funds......what's left....due to GTO oil pan a new mount configuration for front sway bar is needed...currently I have no front sway bar on car , can- bus integration , currently all I have is speedometer and fuel quantity , have no power assist steering or air-conditioning
cf6mech is offline
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
bumppinKota (08-05-2015), civicdrivr (08-05-2015)
Old 08-10-2015, 07:20 AM   #346
Calum
That Guy
Drives: 2013 asphalt FRS MT
I saw this and thought it might be interesting to the swap guys. If Edelbrock offers this separately it might work really well with the LS's throttle body placement and flow needs.
Originally Posted by djdnz View Post
Calum is offline
The Following User Says Thank You to Calum For This Useful Post:
cdrazic93 (08-10-2015)
Old 08-11-2015, 06:42 PM   #347
carbonBLUE
Reverse Burnouts
is power steering due to can-bus? also running AC lines shouldn't be too hard to DIY. with all the R&D they have done and for how long they have kept the car. they really should just finish it up for you with how little is left to do. you are basically at the finish line.
(wont forget you)
2011 Infiniti G37x
The Following User Says Thank You to carbonBLUE For This Useful Post:
cf6mech (08-12-2015)
Old 08-11-2015, 07:15 PM   #348
Calum
That Guy
Both of those items aren't working because of the issues they are having integrating both ECU's via the canbus. If you read some of the posts farther back in that s thread the details are there.
Calum is offline
Old 08-11-2015, 08:04 PM   #349
djliquidsteele
Drives: Scion FR-S
Would running a Motec make any of this easier? Or is motec purely engine management?
djliquidsteele is offline
Old 08-11-2015, 11:08 PM   #350
cf6mech
All that is left sans front sway bar is can-bus related, I was given an estimate on the onset , the build ran over budget, they require more money and I have no money left at this time. It will in time be finished....that is a promise.
cf6mech is offline
The Following 4 Users Say Thank You to cf6mech For This Useful Post:
Breeeep (08-11-2015), Calum (08-12-2015), civicdrivr (08-11-2015), Pug_BRZ (08-12-2015)
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 10:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 01:19 PM
