Old 07-19-2015, 05:36 PM   #15
Lonewolf
Lonewolf's Avatar
Drives: Moped
@PST I always look forward to your posts...so much detailed info and data...love it
Old 07-19-2015, 07:05 PM   #16
D_Thissen
D_Thissen's Avatar
Would a 5W30 oil be safe to use in the winter?
Old 07-19-2015, 11:07 PM   #17
JB86'd
JB86'd's Avatar
Drives: JAWS
So for a DD in Socal that sees mostly weather above 50° F, some spirited driving and occasional autox is it a toss up? Or still go with 0w-20?
Thanks for doing this test and sharing your data
JB86'd is offline   Reply With Quote
Old 07-20-2015, 11:23 AM   #18
bluesubie
Drives: 2004 Subaru Forester 2.5XT
These cars are brutal on oil when it comes to the track. IIRC, Mike at AZP Installs did a used oil analysis on Motul 300V 5W30 and the oil sheared to a 20 weight which is no easy task because 300V is a very shear stable oil. It also is a very thick 30 weight with a high High Temp High Shear so it's very close to a 40 weight when new.
You can also fine tune your oil pressure by doing a mix of 5W40 and 5W30 if you don't want to go with full 5W40.
Subaru Japan allows 5W40 in the BRZ in harsh street driving conditions so that's saying something, IMO.
bluesubie is offline   Reply With Quote
Old 07-20-2015, 11:27 AM   #19
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
I've spent the majority of my adult life in states that border Mexico, so I have no personal experience with winter weights. I suspect it would be okay based on the research Element Tuning has done, but I'd defer to someone more familiar with that region. I believe they found the engine is not that sensitive to heavy weights when cold.
You're very welcome. I'd say it's probably a toss-up. So long as you're staying with the same oil (synthetic, non, ester base, etc.) you shouldn't have any issue changing weights for different events.
Absolutely. We change oil every ten hours of run time since our car is a pure track rat.
Jake
GSpeed is offline   Reply With Quote
Old 07-20-2015, 01:21 PM   #20
hpde_addict
Drives: '18 Camaro V6 1LE
You will want 5W30 for spirited driving and autocross. It's hot as hell in SoCal during the summer.
hpde_addict is offline   Reply With Quote
Old 07-20-2015, 03:26 PM   #21
Jack Black
Drives: 2015 FR-S
Why don't you have any temp data below 210* for 5w30 but you do for 0w20?
Jack Black is offline   Reply With Quote
Old 07-20-2015, 05:05 PM   #22
Dezoris
Dezoris's Avatar
If you are in a hot climate, you might as well just run a 10w30 over 5w30 for stock cars. Most oils have to make trades offs to have a lower winter weight. This is usually not apparent until you get the oils in the higher end of their temp ranges.
Old 07-20-2015, 06:04 PM   #23
RedBRZ80
Drives: 2013 Red BRZ
I've been running 5W30 Motul for the last 50k miles.. In Florida.. With twice a month autoX and a few track days to boot.. Just about perfect.
RedBRZ80 is offline   Reply With Quote
Old 07-20-2015, 07:04 PM   #24
CSG David
CSG David's Avatar
We use 0W20, 5W30, 5W40, and rare occasions of 15W50. Different grades for different applications.
Old 07-20-2015, 07:30 PM   #25
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
The test file I used for 5W30 started with oil temps at 210. I'd already warmed the car up, filled it up with gas, etc. I'll have to go back through some other log files to see how it looked during the "warmup" period, but I don't remember it being any higher than the 0W20 from what I remember on the display. I won't be in the office until Wednesday (this is my weekend) so I'm working off of memory here, sorry.
Interesting! Would you mind sharing some of the temp vs. pressure data for the 5W40 and 15W50?
Jake
Old 07-20-2015, 08:02 PM   #26
Calum
That Guy
Drives: 2013 asphalt FRS MT
I'm running 5w30 up here in Nova Scotia in a DD. For reference, it was 16 degrees C today on my way to work and my oil temp was over 100 degrees C just driving in light traffic at ~110-115 kph.
I really need to install a pressure gauge but I'm still waiting to see if someone will develop a sensor that will inject a signal on the bus so that it could be monitored with torque. High hopes, but I really hate the look of aftermarket gauges in my car.
Old 07-20-2015, 09:27 PM   #27
CSG David
CSG David's Avatar
Jake
We don't have the logged data for 5W40 and 15W50. What we do know is the oil pressure isn't completely optimal even at 5W40 and 15W50.
Old 07-21-2015, 03:22 AM   #28
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
So I would be able to run 15w50 without issue, during the hot summers here on a boosted frs?
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Quickie: 0w20 vs 5w20 / 5w30 empower-auto Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 12-17-2016 01:54 PM
Oil 5w30 cooldandani Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 05-27-2015 09:50 AM
UOA 5w30 Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 07-07-2014 11:29 PM
Where to buy Eneos 5w30? mswhong AUSTRALIA 0 03-26-2013 06:25 AM
DOT Crash Test (non) Data for FR-S/BRZ Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 15 03-24-2012 04:21 AM
