Old 07-16-2015, 12:50 PM   #1
Icanfaptothis86
tickle fight referee
Icanfaptothis86's Avatar
Drives: 2015 Subaru BRZ
Doing my first trackday this wknd
I am doing my first trackday in a car this Sunday and my jimmies and johnnies are all vaporized. I have been on this track a dozen times on my motorcycle but never a car. Tips are welcome
Icanfaptothis86 is offline   Reply With Quote
The Following User Says Thank You to Icanfaptothis86 For This Useful Post:
CSG Mike (07-16-2015)
Old 07-16-2015, 12:52 PM   #2
MightyMeeple
Slower than Fast
MightyMeeple's Avatar
Drives: BRZ Limited 6MT
Assume you will have an instructor with you on board:
1. Don't be afraid to ask questions.
2. Do what your instructor advises.
3. Drive well within your limits.
4. Have fun.
MightyMeeple is offline   Reply With Quote
The Following 4 Users Say Thank You to MightyMeeple For This Useful Post:
DAEMANO (07-16-2015), fstlane (07-16-2015), MisterSheep (08-04-2015), strat61caster (07-16-2015)
Old 07-16-2015, 12:59 PM   #3
Icanfaptothis86
I changed the oil this wknd and I have my car in the shop getting a brake fluid flush coolant flush tire rotation and some other stuff
Old 07-16-2015, 01:05 PM   #4
Icanfaptothis86
I bought a nomex thong
The Following 3 Users Say Thank You to Icanfaptothis86 For This Useful Post:
DAEMANO (07-16-2015), fstlane (07-16-2015), strat61caster (07-16-2015)
Old 07-16-2015, 05:45 PM   #5
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
http://www.ft86club.com/forums/showthread.php?t=25485
ineedyourdiddly
Old 07-16-2015, 06:46 PM   #6
CSG Mike
CSG Mike's Avatar
All the same basic principals apply. No sudden inputs, and apply brakes and throttle as if you were on two wheels. The car is more forgiving, but speed is achieved in the same fashion.
wparsons (07-21-2015)
Old 07-20-2015, 02:41 PM   #7
Icanfaptothis86
Did the track day. I took my old 2005 mini cooper S that has not had regularly scheduled maintenance and no functioning airbags. Maybe 165hp on a good day but it does have racing pads and brake fluid. Anyways the other cars in level 1 were 2 brand new M3s a M4 and a NSX. I was running in front mostly due to lack of fawx given about destroying the car. My heel toe is solid although I did miss second gear once allowing the next car to catch me. The instructor said I need to work on throttle steering a front wheel drive car.
Cant wait to take the brz
The Following 2 Users Say Thank You to Icanfaptothis86 For This Useful Post:
CSG Mike (07-21-2015), strat61caster (07-20-2015)
Old 07-20-2015, 02:45 PM   #8
Icanfaptothis86
Also should note that I lost my center caps hitting the kerbing at 90mph. I would suggest taking rims you dont give any fawx about or perhaps removing your centercaps for the trackday. That was my lesson learned.
THis thread is so useful someone needs to sticky this
Old 07-20-2015, 03:25 PM   #9
FrX
Drives: 2013 Scion FR-S, 1993 Lexus SC300
Organizations around here tend to discourage running center caps for that very reason. They fall off and create debris on the track that someone else could run over. I made the mistake of running center caps on for one track day at a particularly brake heavy track. They melted. That's another good reason to not run them.
FrX is offline   Reply With Quote
The Following User Says Thank You to FrX For This Useful Post:
Old 07-20-2015, 03:29 PM   #10
DarkSunrise
DarkSunrise's Avatar
Throttle steering will take on a whole new meaning with RWD
2022 BRZ Build
2013 FR-S Build
The Following 2 Users Say Thank You to DarkSunrise For This Useful Post:
CSG Mike (07-21-2015), wparsons (07-21-2015)
Old 07-20-2015, 03:31 PM   #11
Icanfaptothis86
Yea I think heat was involved as well bc they were just laminated on there to begin with.
It was 104 yesterday
Brakes did better than I thought they would
Oil temps were fine but I did run the heat at full blast just in case
Old 07-21-2015, 12:50 PM   #12
CSG Mike
CSG Mike's Avatar
Removing centercaps is typically standard procedure and part of the car-prep/tech checklist that most organizations require.
let us know when you need pads and fluid for the BRZ
Old 07-21-2015, 01:10 PM   #13
stugray
Drives: 2013 GBS BRZ Limited
Believe it or not: First time out - leave the TC & VSC ON.
Wait until you experience the nannies stepping in a few times before you go and disable it all.
The truth is: If, as a beginner, you drive the car in a way that is making the nannies yell at you then you are not driving smoothly enough.
You have to be really good before the nannies are actually HURTING your lap times.
The Following User Says Thank You to stugray For This Useful Post:
strat61caster (07-21-2015)
Old 07-21-2015, 01:21 PM   #14
CSG Mike
CSG Mike's Avatar
I disagree.
Everyone needs to start with the nannies off, and also KNOW that they have all the nannies off. This prevents dependence on the nannies, and progresses the driver's understanding of vehicle dynamics that much faster. This prevents the mentality of "oh the nannies will save me" versus "oh the nannies aren't there and if I do that, it'll probably spin me out, possibly damaging the car, so I won't do that".
A novice will not have the awareness to notice a flashing VSA light.
Pat (07-23-2015)
Any Tacoma peeps driving to Portland this wknd? DarrenDriven Northwest 0 01-29-2015 02:58 PM
Hooked on Driving event next wknd at Atlanta Motorsports Park BadCompany235 Tracking / Autocross / HPDE / Drifting 0 08-29-2012 11:28 AM
Forged Performance Track wknd at AMP BadCompany235 Tracking / Autocross / HPDE / Drifting 3 07-31-2012 03:04 PM
OMG, Just had Best call..SCION Drift Ride Along this Wknd!!! MarkRacerX Scion FR-S / Toyota 86 GT86 General Forum 22 07-25-2012 10:37 AM
Autocross next wknd for me! Interesting response re: classing.. MarkRacerX Tracking / Autocross / HPDE / Drifting 42 06-18-2012 01:52 AM
