Old 07-18-2015, 11:57 AM   #1
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
0W20 vs. 5W30 Test Data
After our last test session, we weren't comfortable with the pressures and temperatures we were seeing on our unmodified car. We were running Motul 300V 0W20, and pressures were dropping below 5 psi in the pits at the end of the session. Oil temps as reported by the ECU were well over 270°.
For today's session, we switched to 300V 5W30 to see if we could keep the hot pressures a little higher. Here's a graph of what we found.
This shows psi per thousand RPM at varying oil temperatures. As we'd expect, the hotter the engine, the thinner the oil. This is normal. The red line is the "safe" goal of 10 psi/thousand RPM. That's not an especially scientific value, just something to compare as "good/bad."
RPM values below 1000 RPM were excluded to get data from only when the car was actually moving. We're not interested in heat soak right now, just on-track numbers.
The blue is the 0W20, and the yellow is the 5W30. You can see pretty clearly how the 5W30 helped keep oil pressures higher as temperatures increased, but didn't really give us abnormally high pressures at lower temperatures. Both tests were run on track here at the Motorsport Ranch, with ambient temperatures around 85-90F.
We may run 5W40 for the next oil change just to see if that moves hot pressures higher, but we think it's safe to say 5W30 is the right call for tracking a relatively unmodified car in hot climates.
Anyone have any similar experiences?
Update Aug. 30
Here's an updated graph showing the same data and processing, once an oil cooler is added to the system (green series). You can see the oil still behaves as it always has, but it's kept about 30° cooler.
Now that we've seen how well it works on our car, we'll definitely be pushing everyone to run an oil cooler if you're tracking your car in the summer. As much as we love doing engine swaps for people, we'd rather not do it because someone spun a bearing from letting their oil degrade.
GSpeed is offline   Reply With Quote
Old 07-18-2015, 12:09 PM   #2
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
That is very cool. Thanks for posting.
I don't get what the obsession with 0w-20 is around here. The copy of the factory service manual I have clearly states 5w-30 is an option along with 0w-20 and 5w-20.
Personally I use Castrol 0w-30 or Mobil1 0w-40 as they can be found locally.
Briankbot is offline   Reply With Quote
Old 07-18-2015, 01:37 PM   #3
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
Agreed. After seeing this data, we'll recommend 5W30 to all our customers.
Old 07-18-2015, 03:38 PM   #4
philooo
Drives: 13' Scion FRS Track car
I was at homestead last week with 90f weather, very humid mind you.
Brand new Motul 300v 0w20 and i had temp max of 255f and my pressure on track was +-50... I assume psi
How does it relate to your psi/rpm ?
50psi at 5000rpm = 10psi/1000rpm ?
Am i correct ?
I have it on video but no data logger yet.
I am stock with mishimoto oil cooler and no Ac radiator
philooo is offline   Reply With Quote
Old 07-18-2015, 03:44 PM   #5
GSpeed
GSpeed's Avatar
Drives: 2015 BRZ
That sounds about right to me. 255° seems about right for a track car on a hot day with an oil cooler, maybe a little on the hot side. You may gain a little bit by switching to 5W30, but you're probably fine for now. 50psi at 5000 RPM is better than we were able to get without an oil cooler.
Old 07-18-2015, 10:20 PM   #6
RehabJeff86
RehabJeff86's Avatar
Drives: 2013 WhiteOut FR-S
great data and I have been seeing similar at the track. Im currently using Motul 300V 15w50 for hot summer to keep adequate oil pressure above 30psi at redline with oil temp about 270F. Will be upgrading Oil Cooler hopefully to get oil temp down to 220-240F range and match it with 10w40. @CSG Mike @CSG David @mkivsoopra @sw20kosh @WoOosOn @BRZkitty
2013 Scion FR-S whiteout
2012 Porsche Panamera S carbon grey
2008 Range Rover Sport SS black - sold
2004 BMW M3 alpine wies - sold
RehabJeff86 is offline   Reply With Quote
Old 07-18-2015, 10:39 PM   #7
Sideways
BRZZZZZ
Sideways's Avatar
Drives: 2013 BRZ Whiteout
Definitely very good info thr. I was thinking of switching to 5w30 or 5w40 to prepare it to track days. Guess now I'm definitely going to heavier grade oil. Thanks for posting this info.
Sideways is offline   Reply With Quote
Old 07-19-2015, 12:16 AM   #8
olsonpg
olsonpg's Avatar
Drives: BRZ. R34 GT-T
Pardon the noobish question but synthetic or non ?
olsonpg is offline   Reply With Quote
Old 07-19-2015, 12:27 AM   #9
rice_classic
rice_classic's Avatar
Drives: Nevermorange FRS
http://lmgtfy.com/?q=Motul+300v
PRO86 | STL | LuckyDog
Old 07-19-2015, 12:29 AM   #10
olsonpg
olsonpg's Avatar
Originally Posted by rice_classic View Post
Lmao that made my night.
Old 07-19-2015, 01:51 PM   #11
kster1
kster1's Avatar
Thanks for posting this. Since my car is naturally aspirated with an oil cooler, the highest oil temps I've seen at the track is 225F. Even at these "safe" temps, I'll keep running a mixture of 5w30/5w40 of Motul.
kster1 is offline   Reply With Quote
Old 07-19-2015, 02:43 PM   #12
Uncle Benz
Uncle Benz's Avatar
Drives: GT86
I moved to 5w30 Motul 300v and the HKS oil cooler. At a recent trackday at Bedford Autodrome on the GT circuit I saw a maximum oil temp of 107 degrees Celsius, and 18 psi at tickover when returning to paddock. I never pushed the car hard before the modifications because tales of sky-high oil temperatures and <10psi in the paddock scared me a bit. I'm now seeing oil pressures of 125psi when the engine is cold, and this worries me a little too, so I've taken to letting the engine warm a bit before moving off. I guess you can't have it both ends??
Uncle Benz is offline   Reply With Quote
Old 07-19-2015, 02:50 PM   #13
Teseo
Drives: frs
Do it with OFT/RomRaider etc
Old 07-19-2015, 04:17 PM   #14
IBill4You
Drives: 2015 Subaru BRZ
Finally actual data rather than speculation. 0w20 fanboys can suck it
IBill4You is offline   Reply With Quote
Quickie: 0w20 vs 5w20 / 5w30 empower-auto Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 43 12-17-2016 01:54 PM
Oil 5w30 cooldandani Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 26 05-27-2015 09:50 AM
UOA 5w30 Rocket.BRZ Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 49 07-07-2014 11:29 PM
Where to buy Eneos 5w30? mswhong AUSTRALIA 0 03-26-2013 06:25 AM
DOT Crash Test (non) Data for FR-S/BRZ Dadhawk Scion FR-S / Toyota 86 GT86 General Forum 15 03-24-2012 04:21 AM
