| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#379 |
Just the tip
Bridgestone RE-11 in 245/45R16 is my vote for tires. I use it for track, autox, daily, and it's even good in rain. Since they are in the top category of summer tires they don't work very well below 45 degrees (no summer tire does), but that's what my winter tires are for.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes ![]() |
#380 |
Drives: ae86/frs
#381 | |
Drives: Scion FR-S
| The Following User Says Thank You to GuerillaRacing For This Useful Post: | yo joshman (04-20-2015) |
#382 |
So I am looking into 16's I used this calculator and debating 245 and 235. How close is too close until there's interference with any suspension items? 245 are ideal which brings the gear ration back to 4.10 so this is prefered. I forget who made this calculator but I think the end of the red line may be where suspension parts are. I used the Y axis line as a guide to clearance if it is the max. Anyway the offset for the fender lip should be okay. I dont want the tires sticking past the fenders. I also am going to put TRD lowering springs.
thanks for any help steve
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
#383 | |
Just the tip
| The Following User Says Thank You to stockysnail For This Useful Post: | stevesnj (07-05-2015) |
#384 |
The problem will be the limited number of 235/245 sized tires to choose from.
| The Following User Says Thank You to Kostamojen For This Useful Post: | stevesnj (07-05-2015) |
#385 |
Drives: 2013 raven black fr-s
I'm running 16in wheels with 225s all around. The car seems fairly stable but I do get some sidewall deflection if I'm more than half throttle on any hard coners
| The Following User Says Thank You to bakerr6 For This Useful Post: | NWFRS (07-13-2015) |
#386 |
What brand tires you have and whats the offset front and rear? Thanks!
#387 | |
Drives: Toyota 86 GTS
#388 |
Drives: '15 BRZ RA
#389 |
Sorry guys I'll pull the specs tonight. I believe the width is 7in
| The Following User Says Thank You to bakerr6 For This Useful Post: | stevesnj (07-17-2015) |
#390 |
Drives: '15 BRZ RA
It is better to use 215 or less in 7''.
#391 |
Only users lose drugs.
Drives: All the time
225 is certainly acceptable for use on a 7" rim, especially in taller aspect ratios required for running smaller diameter wheels. I run 225/50-16s on 16x7s and have zero issues at all. The tire does not roll over like everyone thinks it will, even when autocrossing, and I'm only running pressure in the high 30's.
#392 |
Drives: 15 BRZ LTD, 05 FXT
I have some 15" Enkei RCG4's that'll be my winter wheels!
| Wheel Directory: Styluz S006 18x7.5 +40 | Pavel | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 01-22-2014 04:16 PM |
| FS [SYD] 16 inch GT wheels and tires! | luv85 | Australia Classifieds | 3 | 11-04-2012 06:15 AM |
| Help! Two 10 inch vs One 10 (or 12) inch | cyntage | Electronics | Audio | NAV | Infotainment | 7 | 09-27-2012 11:20 PM |
| I need 19 inch wheels today! | benqld7 | AUSTRALIA | 16 | 08-07-2012 08:33 AM |
| 16 inch wheels for the base model!!! | Blokatos | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 12-07-2011 11:17 AM |
