Old 07-17-2015, 06:35 AM   #1
Packofcrows
hey you, yeah you <3
Packofcrows's Avatar
Drives: 2014 37J FR-S
is main relay kill switch bad for ecu?
Have simple covered kill switch on battery and crazy rewired and hidden nifty distributor kill switch I'd like to swap for a ecu kill switch. Why? Idk. I have good insurance and no sign of attempt theft. Knock on wood.
So please just help me answer this.
Is a main relay kill switch bad for ecu? An incomplete circuit.
Last i messed with a ecu was on a ae86. Id take ecu with me everywhere when parked until it fried... then just got removable hub and such.
Old 07-18-2015, 02:27 AM   #2
Poodles
Drives: 2015 Series.Blue
The keys already have chips in them... If the car is stolen, it's because they towed it, not because they hotwired it.
Old 07-18-2015, 02:39 AM   #3
stugray
Drives: 2013 GBS BRZ Limited
Yes it is bad to remove the power from the ECU.
It resets it and it needs to relearn the engine parameters all over again when you turn it back on again.
If you did that every time you shut off the car, it would hardly have enough time to relearn each time you drove it.
Old 07-18-2015, 02:55 AM   #4
Packofcrows
I thought so. Thanks. Guess I'll leave both kill switches as they are.
Cusco Street Kill Switch- ft86me Engine, Exhaust, Transmission 5 07-24-2015 09:14 PM
FRS Fuel Kill Switch? nabil_frs Electronics | Audio | NAV | Infotainment 5 07-09-2015 09:45 PM
Fuel or Battery Kill Switch? nabil_frs CANADA 3 03-09-2014 09:43 PM
Rear Light Kill Switch flightless37 Cosmetic Modification (Interior/Exterior/Lighting) 1 11-06-2013 11:03 AM
How to replace turn signals with switch backs and its relay switch. Scionshaun Scion FR-S / Toyota 86 GT86 General Forum 1 05-31-2013 12:42 AM
