Old 07-04-2015, 03:23 PM   #1401
slicktop
Drives: 2013 Raven FRS 2JZ-GTE/V160 swapped
Originally Posted by Ruckus View Post
Those rears though!!! I need 275's in my life. You think 275s on a 17X9 ET35 rears will work?
With camber, anything is possible. However, I would stick with 265 unless you do a large roll/pull.
-slicktop
2013 Scion FRS
2JZ-GTE/V160 Swap Build Thread
slicktop is offline   Reply With Quote
The Following User Says Thank You to slicktop For This Useful Post:
Ruckus (07-24-2015)
Old 07-06-2015, 02:03 PM   #1402
brady86
Drives: 2013 firestorm fr-s
@Jive Turkey did you notice the car get much slower with the 18x9.5 with 265 all around I am n/a still so I am worried about making it unbearably slow with this heavier set up and taller gears.
brady86 is offline   Reply With Quote
Old 07-07-2015, 01:52 AM   #1403
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
down low, yes you do feel the weight, but its never unbearable where you really feel sluggish. once you're in 3rd+ don't even notice IMO. also depends on the type of wheel/tire you will run. stock weighs 42~lbs. mine is roughly 3lbs heavier per corner if i remember the weight correctly.
Jive Turkey is offline   Reply With Quote
Old 07-07-2015, 01:09 PM   #1404
brady86
I have been looking for a pair of gramlights 57 extreme sp 18x9.5+40 with 265-35-18 tires. so almost same as your set up lol @Jive Turkey
Old 07-07-2015, 01:46 PM   #1405
Jive Turkey
the tuna, no crust.
had that exact setup as my first. just get a good tire that runs wide and you can even go to a 255/35 if you want
Old 07-15-2015, 04:29 AM   #1406
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
Hi guys. Im running VOLK TE37 SL's 18x9.5 +40. Tires are 255/35/18
Jolt182 is offline   Reply With Quote
Old 07-15-2015, 04:32 AM   #1407
Jolt182
Jolt182's Avatar
Drives: Asphalt FRS
So far no rubbing!
The Following 2 Users Say Thank You to Jolt182 For This Useful Post:
Hicklinc (02-20-2018), mmmcambelsoup (07-16-2015)
Old 07-17-2015, 12:01 AM   #1408
shaunieboy77
Drives: gray 2015 scion frs
Originally Posted by Hotchkis View Post
Here's ours:
- HRE C106 18 x 9 +35 (All 4)
- Dunlop Z2 255/35R18 (All 4)
- No Rubbing, No modification
Additional Info:
- Due to smaller aspect ratio, the 255/35R18 overall diameter is the same as 255/40R17 on the Direzza ZII, so gearing is the same. Good to know for guys that are on the fence about 17" vs 18" with using these tire sizes. 18" tires are more expensive, but sexier
- We are running Koni single adjustable shocks, so this fitment is good for stock style strut perches. Our camber plates include OE crash bolts which are set to full negative camber. So they are set to the least amount of tire to perch clearance.
- Front camber is -2.8°
i have 18x9.5 +34 rims..im getting coilovers to eliminate wheel gap..but im looking for a tire that i wont have problems with rubbing or need to make any modifications once the couls are on.. help please
shaunieboy77 is offline   Reply With Quote
Old 07-19-2015, 06:58 PM   #1409
Jive Turkey
the tuna, no crust.
well are you willing to roll fenders?
how much camber would you like to run.
you would want a 255/35 atleast but with a +34 its kind of aggressive and you would need at least -2 in the rear and like -2.5 in the front for clearance purposes.
rubbing also depends on your suspension and how soft/stiff it is.
i'm on a 18x9.5 +40 with a 265 MPSS and i only rub on really harsh dips. regardless you will rub the rear bumper "tab"
so you can go with a 255/35 for the meaty look but you'll need more camber.
or go with a 245/40 tire that runs wide and have a slight stretch.
Old 07-19-2015, 10:10 PM   #1410
mrharry
Drives: GT86
anyone know what else i can do to prevent rubbing?Cause right now my fender is slowly chewing up the tires on dips/tight turns but driving on a nice even road is fine.
i have already rolled the front and shaved the rear & raised the car
Front: 18x10+35 with AD08r 265/35
Rear : 18x10+40 with AD08r 265/35
Front Camber -2.5
Rear Camber -2
Ride Height : 345mm From Center Bore to Fender
mrharry is offline   Reply With Quote
Old 07-20-2015, 07:14 AM   #1411
keb86
Drives: Toyota 86
Originally Posted by coeurdencre View Post
Here's mine with Enkei Kojin in 18x9.5 +45 square
245/35/18 Toyo Proxes T1 Sport
Can we have more pictures?
keb86 is offline   Reply With Quote
Old 07-20-2015, 10:42 AM   #1412
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Can I join?
Left is oem, right is 295/35 Potenza RE760
[IMG][/IMG]
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
Bergen23 (07-20-2015)
Old 07-20-2015, 11:45 AM   #1413
BRZ RN
BRZ RN's Avatar
Drives: Blue BRZ
Originally Posted by BoxRZ_86 View Post
went with 245 width for now as i am still stock suspension. 17x9 +42.
first of all really nice looking, can we have more pics please?
now 2 questions:
1. does the front rub at all?
2. is your tire dimension 245/45/17?
BRZ RN is offline   Reply With Quote
Old 07-20-2015, 12:19 PM   #1414
BoxRZ_86
BoxRZ_86's Avatar
Drives: 2013 Subaru BRZ Limited SWP
Meaty Tire Thread
now 2 questions:
In the front the tires ever so slightly touch the spring perch when driving the car hard into turns and hit bumps mid turn and haven't seen any rubbing beyond a slight graze. I have taken the wheels off a few times just to check on them and the tires show no signs of any damage.
Yes they are 245/45/17, Sumitomo hr-z iii. So they could fit differently than other brands.
BoxRZ_86 is offline   Reply With Quote
The Following User Says Thank You to BoxRZ_86 For This Useful Post:
BRZ RN (07-20-2015)
Winter Tire Review Thread (Please contribute) pastuch Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 344 03-13-2024 06:49 PM
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 ScionFR-S Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 97 09-09-2015 07:32 PM
Meaty rubber on flush spoke rims? red_comet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 16 06-14-2013 01:21 PM
Official wheel/tire fitment thread needed empower-auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 4 06-22-2012 02:40 AM
The Wheel and Tire Fitting Thread EvoFanatic Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 2 03-15-2012 04:05 PM
