Sam Strano
Old 07-15-2015, 12:59 PM   #3543
TMF
TMF's Avatar
Drives: '14 FRS TT5
Originally Posted by Arigh View Post
This will be the first nationals I attend and also the first time on concrete. I'm already signed up for a test and tune slot, and the evo school test and tune as well, so I know I'll have some amount of time to adjust setup, but early is a great time to ask: Any big differences between the two surfaces for setup? Do you adjust damping and pressures to compensate for the increased grip levels?
Another question in relation to this, how many turns are you guys running on your Koni's , specifically with TRD springs and sways? I just need a rough baseline...
TMF is offline   Reply With Quote
Old 07-15-2015, 01:04 PM   #3544
veloscaraptor
Drives: '15 fr-s
Originally Posted by SeanRTR View Post
It's not marked on the tire. It's not actually 200 TW either, but they say it is, so you're legal. You won't get protested and ridiculed for cheating.
Thanks! That's what I'd guessed, just wanted to check in.
veloscaraptor is offline   Reply With Quote
Old 07-15-2015, 01:28 PM   #3545
ButteR
Drives: 2015 Scion FR-S
I hear so many answers from many different people. I talked to a guy last Saturday whose been tuning suspensions for autocross for 25 years and said that for our cars (in stock form), with the single adjustable konis, to set the front to full firm and the rear from 1/2 to one full click from soft.
I took his advice and I liked the way the car drove a lot better than when I had everything set to full soft. The rear I'm not so sure about yet.
Remember that the TRD spring rates are the same as OEM. I thought that they were stiffer, but they're not apparently (correct me if I'm wrong)
ButteR is offline   Reply With Quote
Old 07-15-2015, 01:41 PM   #3546
Biggins
Drives: Yes
That's exactly where I start. Depending on site/weather conditions, I might adjust a 1/2 turn from there on the applicable end. However, I do not have the TRD stuff and only a smallish front bar.
Biggins is offline   Reply With Quote
Old 07-15-2015, 02:55 PM   #3547
TMF
TMF's Avatar
Drives: '14 FRS TT5
Thanks for the info, appreciate the starting point! Although I thought I've heard that you're not supposed to run Koni's on full hard/stiff?
BTW, I'm having a hard time finding the spring rates for the TRD springs, but they might be different than stock. This thread shows a rate, but it is the rate for the springs on the TRD coilovers, and there is no confirmation that those springs are the same as the USDM TRD springs. See page 8, starting at post 160.
http://www.ft86club.com/forums/showthread.php?t=8739
Old 07-16-2015, 02:30 AM   #3548
markw
Drives: 2014 FR-S
In stock form, as in TRD or Stock springs? No one knows what the TRD's are but guesses are that they're the Eibach Pro springs, given that the bump stops say Eiebach on them. In completely stock form ie non trd springs/bars, our cars are very tail happy, so softening up the rear and firming up the front will remove some of that. I've been really happy with my setup, I just have to grow a pair and take some risks at coning or spinning the car. I think my fear of a +1 or more when it counts slows me down. I'm slowly getting over that though, and seeing better results.
Mark
markw is offline   Reply With Quote
Old 07-16-2015, 09:37 AM   #3549
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
For everyone trying to understand adjusting your Konis (or any adjustable shocks) there's an episode of the Grassroots Motorsports podcast that's an interview with Lee Grimes. In it Lee does a great job of explaining the overall idea of tuning shocks to adjust for different surfaces and driving characteristics. I listened to it yesterday and it really helped me comprehend what is going on when you're messing around with shock tuning. Definitely worth giving a listen.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
The Following 2 Users Say Thank You to Shark_Bait88 For This Useful Post:
qoncept (07-16-2015), TMF (07-16-2015)
Old 07-16-2015, 11:18 AM   #3550
qoncept
qoncept's Avatar
https://grassrootsmotorsports.com/fo...s/92935/page1/
qoncept is offline   Reply With Quote
The Following 4 Users Say Thank You to qoncept For This Useful Post:
Briankbot (07-16-2015), NJ10 (07-20-2015), Shark_Bait88 (07-16-2015), TMF (07-16-2015)
Old 07-16-2015, 11:35 AM   #3551
Shark_Bait88
^That's the one!
I've become obsessed with automotive podcasts lately. Between GRM and Slipangle my commute to and from work has gotten much more interesting.
The Following User Says Thank You to Shark_Bait88 For This Useful Post:
Pat (07-16-2015)
Old 07-16-2015, 07:59 PM   #3552
Briankbot
Briankbot's Avatar
Drives: 2013 FRS
This is no longer correct. I have a set sitting in my living room stamped "200 treadwear".
Briankbot is offline   Reply With Quote
Old 07-16-2015, 09:15 PM   #3553
cab33
Drives: Fast
Question about the Rival S...
They are asymmetrical, but there are no lefts and rights?
So the tread pattern will be opposite on one side of the car than the other?
cab33 is offline   Reply With Quote
Old 07-16-2015, 10:29 PM   #3554
ButteR
Anyone here actively autocross and drift in socal? If ya do, Send me a pm plz.
Old 07-16-2015, 10:32 PM   #3555
coneracer30
Drives: 2013 Fiestorm FR-S
I run the koni's at 1 turn from full stiff front and 1 turn from full soft rear with TRD springs.
coneracer30 is offline   Reply With Quote
The Following User Says Thank You to coneracer30 For This Useful Post:
TMF (07-17-2015)
Old 07-17-2015, 12:02 PM   #3556
renfield90
The Stig's German cousin
There's an outside shoulder and an inside shoulder, the outside should be outside on all four corners.
Tread construction is asymmetrical, but carcass construction is symmetrical - you can flip it so the outside is now on the inside without losing much. The tread isn't directional so it doesn't really change wet handling much either.
Cinco De Mayo SCCA SOLO Ryeong86 NY / NJ / CT / PA 0 04-23-2013 05:22 PM
Koni Sports in SCCA SOLO Ryeong86 Tracking / Autocross / HPDE / Drifting 4 04-22-2013 12:58 PM
2013 Preliminary SCCA SOLO and PRO SOLO National Schedule Scooby South Tracking / Autocross / HPDE / Drifting 13 12-05-2012 08:08 AM
Houston SCCA Solo #9 - 5 FRS, 1 BRZ hankster Tracking / Autocross / HPDE / Drifting 0 10-09-2012 01:35 PM
SCCA Solo Car Class for the FR-S/BRZ? MrVito Scion FR-S / Toyota 86 GT86 General Forum 31 06-15-2012 10:03 AM
