Old 07-16-2015, 10:40 AM   #1
ogrowup
Drives: Asphalt build in progress
Balky 1st gear shift
back story first:
I had the typical 2nd gear notchy shift until I changed the transmission oil with Motul 300 and all was good. Over time I made a few (haha) mods and I now have the Cartboy short shift kit, ACT HDSS clutch kit w/ ACT streetlite flywheel, and the one piece carbon fiber driveshaft from Drive Shaft Shop.
Now, at times it can be really really difficult to get it into 1st gear. I started to keep track of it and this is what I discovered:
  • 1st gear shift is never a problem if the car is rolling at all.
  • It's not a problem while the oil temp is under 190 degrees
  • this did not happen prior to the installation of the drive shaft
Once the car is good and hot, and I'm sitting at a traffic light, then it can often take multiple attempts to get it into 1st gear. I mean a lot of effort. I try to slip it in 3rd, then 1st. I try reverse then 1st. I try to rev match, and sometimes I just have to jam it into 1st. I've been driving manual transmissions for 45 years, so no, the problem is not my skill at a 6 speed.
Anyone have this problem? Any ideas out there how to fix this??
Anyone out there have this problem?
ogrowup is offline   Reply With Quote
Old 07-16-2015, 10:43 AM   #2
Originally Posted by ogrowup View Post
back story first:
With the list of mods that you have done that effect the shifter it may be tough to figure out what is going on.
All other gears ok all the time?
Old 07-16-2015, 12:59 PM   #3
bcj
Geo Tyrebighter Esq
bcj's Avatar
Drives: '13 scion fr-s
Drive shaft expanding and putting axial load on the trans tail shaft?
Old 07-16-2015, 01:30 PM   #4
3nl
Drives: 2015 FR-S 6MT
How many miles are on the transmission and how long have you had the Kartboy shifter installed? If it is happening while you are stopped and nothing in the transmission is moving (meaning nothing to synchronize) and it doesn't slide into first, it just might be a badly installed shifter. You said second is notchy, is it also hard to get it into second like first? If both are difficult, it might just be the shifter not connecting with the 1-2 shift linkage.
Once you do have it in first and warmed up, can you slide it into neutral and back to first with no effort?
3nl is offline   Reply With Quote
Old 07-16-2015, 02:00 PM   #5
Well, that's for sure ......
First thing I would do is take that short shifter off and see if it was the cause ....
Old 07-16-2015, 04:46 PM   #6
ogrowup
yup
smooth as silk on all other gears, including 1st until it gets hot
Old 07-16-2015, 04:50 PM   #7
ogrowup
Trans has 18,000 miles. Kartboy has been in there for at least 10,000 miles, with no issues at all. I did not start to have this problem until the driveshaft was installed. 2nd gear used to be notchy, but no longer is after i changed to motul 300.
The problem happens when:
the engine is hot
nothing is moving in the transmission
Old 07-16-2015, 06:15 PM   #8
the engine is hot
HMMMMM then something is apparently expanding. Doubt it would be the shaft since heat has little impact on carbon fiber.
I am stumped.
Old 07-16-2015, 06:44 PM   #9
Teseo
Drives: frs
Tryed to put neutral first then 1st gear?
Old 07-16-2015, 08:40 PM   #10
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
When I read "Balky" I first thought of this...
Old 07-16-2015, 08:48 PM   #11
Your age is showing!
Old 07-17-2015, 05:54 PM   #12
ogrowup
I am stumped.
This is too funny. I have a propensity for having things happen to cameras, cars and computers that no one has heard of before. I should be hired to torturous test products for manufacturers...
A friend of mine who does mods on Morgans thinks it's clutch related...
Time will tell...
Old 07-17-2015, 06:01 PM   #13
JEDI
JEDI's Avatar
Drives: 2015 FR-S RS 1.0 #0993
Have you checked motor and trans mounts? If one of these have excessive play it could have this effect. Sounds from your list of mods this would be next on the list and stockers will wear faster with the additions you've made. Maybe I missed something in the post regarding trans mounts , is there a carrier bearing worn out.
2015 Subaru WRX - SOLD!
2013 Scion FR-S - Traded In!
2015 Scion FR-S RS 1.0 - My DD , GF, and BFF!
JEDI is offline   Reply With Quote
Old 07-17-2015, 06:23 PM   #14
mav1178
mav1178's Avatar
So... just out of curiosity, have you tried changing back to the OE driveshaft?
-alex
BRZ shift gear indicator wants you to shift gears too soon? Jfheisenberg BRZ First-Gen (2012+) — General Topics 31 03-24-2015 01:50 PM
Gear shift 'step'. -Tom- Cosmetic Modification (Interior/Exterior/Lighting) 1 01-05-2015 03:13 PM
brz series.blue gear shift from 1st - 2nd -3rd? iarefluffy Engine, Exhaust, Transmission 0 10-21-2014 04:41 AM
How to Smoothly and Quickly Up-shift from 1st to 2nd Gear? DemonRawr BRZ First-Gen (2012+) — General Topics 20 10-20-2014 04:51 PM
Manual gear shift in Automatic 86 djmm Scion FR-S / Toyota 86 GT86 General Forum 21 07-30-2014 07:08 PM
