CANADA Canada
Old 07-13-2015, 09:46 PM   #9157
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Ruzbeh works at Mendes, right?
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
The Following User Says Thank You to AznKirby For This Useful Post:
FRSToyota86 (07-14-2015)
Old 07-13-2015, 09:51 PM   #9158
FRS_Ken
((•||=(86)=||•))
FRS_Ken's Avatar
Drives: '13 FR-S Ultramarine 6AT; '13 Yaris
Yes he does
FRS_Ken is offline   Reply With Quote
The Following User Says Thank You to FRS_Ken For This Useful Post:
Old 07-14-2015, 10:43 AM   #9159
CrazyBRZ
CrazyBRZ's Avatar
Drives: Subaru BRZ
Hey guys, I'll be going to Trackwerks this friday with two S2000 and one SI. We'll most likely leave from the east end. Let me know if some are interested in joining.
| Perrin 3'' Resonated Catback Exhaust | aFe/Takeda Intake |
CrazyBRZ is offline   Reply With Quote
Old 07-14-2015, 05:29 PM   #9160
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by normancw View Post
I've had it once - I replaced the one coil. I would recommend just replacing the one indicated by the code (front most passenger side) and keep 1 or 2 as spares. It's the most common one to throw a code (due to additional heat from cat?). If it happens again, there's a good chance it will be the same coil.
^^ This. No sense changing a perfectly good coil for another. Get 2 and keep 1 spare, change as needed.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
Ft86Chris (07-14-2015)
Old 07-14-2015, 05:57 PM   #9161
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Drives: Ashpalt 2014 Frs Manual
Going in Saturday for diagnostic, See if the dealership will take care of it, or if ill end up ordering coil packs myself, worth a shot nothing to really lose but an hour out of my day.
Thought crossed my head, a few people told me Royal Purple is bad for Boxer motors, i wonder if that is what caused my issues, other people have had none, or if its just the aggressive driving i put on the car, See what the Dealership has to say Saturday. hoping for the best, but do not want to be without the car for to long.
2014 Asphalt MT FR-S Ecutek custom tune, Bolton's and Sticky tires.
Ft86Chris is offline   Reply With Quote
Old 07-14-2015, 10:56 PM   #9162
pushrod
Benched 86lb
pushrod's Avatar
Drives: Ultramarine FR-S
My car started hunting at idle on the way home from work yesterday, and the check engine and slip lights came on this morning. I also have one partially bald tire and another with a puncture (again). I'm thinking the poor car is not standing up to my harsh treatment.
pushrod is offline   Reply With Quote
The Following User Says Thank You to pushrod For This Useful Post:
Ft86Chris (07-15-2015)
Old 07-15-2015, 08:01 AM   #9163
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
I get the traction light, along with the check engine light, under load the traction light comes on, I hope you have nothing serious going on!
Old 07-15-2015, 08:48 AM   #9164
jvincent
jvincent's Avatar
@pushrod, what are the codes?
Old 07-15-2015, 11:39 AM   #9165
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
P0351 is coil pack if that helps
Old 07-15-2015, 11:44 AM   #9166
jvincent
jvincent's Avatar
Assuming Royal Purple meets all the required specs, then shouldn't be anything that makes it "bad" for boxers. I'm new to the car scene but there are as many anecdotal pseudo-science arguements about oil as there are in high-end audio.
Is it possible that your tune is running lean? That would increase the engine temps. Do you have any logs from driving around?
The Following User Says Thank You to jvincent For This Useful Post:
Old 07-15-2015, 12:20 PM   #9167
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Haven't data logged in a while, i have cleared the code a couple times, but it comes back fairly quickly, I plan on data logging once i have a passenger available to help, The way i was instructed to do it by my tuner was to do a 3rd gear pull from 1500rpm WOT to limit, i assume there are other ways to log, but i am not sure what things to turn off on the logging to make it easier to read,
Appreciate the input, I should have answers saturday, depending on how things go. I enjoyed my buying experience with Bel-air, so hopefully service is better this time around ( 1st time was not the greatest, but mistakes happen, can't make a decision based on one event )
Old 07-15-2015, 01:58 PM   #9168
jvincent
jvincent's Avatar
If you have access to an OBDII dongle and Torque on your phone you can log AFR and the fuel trims pretty easily. That should tell you if you are running lean.
Old 07-15-2015, 02:20 PM   #9169
pushrod
Benched 86lb
pushrod's Avatar
The one code was P000C, which I've read has happened to other Subaru cars. It's cleared for now and hasn't come back since last night, but we'll see.
I did spill a tiny amount of oil on some of the cam sensor wiring last time I did an oil change. I should clean them up and see if that's all it is.
This is definitely making me reminisce about all the times I've spent under the hood of a car back in my beater days (everything pre-FRS).
Old 07-15-2015, 04:52 PM   #9170
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
Just wait till your clutch explodes
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
The Following 3 Users Say Thank You to UMB FR-S For This Useful Post:
Ft86Chris (07-15-2015), HeadBanger (07-15-2015), pushrod (07-15-2015)
