Old 07-13-2015, 01:39 AM   #1
timmymartinez
Drives: 2015 Scion FR-S
Suspension problems? 2015 FRS
Hey guys I just got my 2015 FRS a a week or so ago and I noticed there's more clearance from the right rear tire to the wheel well upwards than the left side. I've went on many different garages and surfaces and it's always the same measurement. Have any of you had the left rear lean a little bit parked? Any diagnostics will help , is it just because it hasn't been worn it yet? Btw I'm only 140 so I don't think it's my weight lol. I already checked tire pressure and the dealership said it was in factory standards but why does it lean?
timmymartinez is offline   Reply With Quote
Old 07-13-2015, 03:12 AM   #2
Welcome to the forum ......
It could be that a rear spring isn't seated properly.
I suggest you have the dealer, or a local auto shop, put it up on a rack and check out the rear suspension.
Old 07-13-2015, 08:21 AM   #3
BlackJesus
Shut up baby, I know it
BlackJesus's Avatar
Drives: 2013 BRZ DMG
Could you post a picture? @humfrz said bwst bet is the dealer. Always make sure that they have a solution before letting them "fix" anything on your car
BlackJesus is offline   Reply With Quote
Old 07-13-2015, 08:34 AM   #4
DarkSunrise
DarkSunrise's Avatar
Uneven rear camber? I know on my car, the RR wheel had -1.4 degrees camber, whereas the RL wheel had -1.0 degrees camber. Apparently a lot of these cars come with uneven rear camber from the factory. That might cause the uneven measurements you describe.
2022 BRZ Build
2013 FR-S Build
2013 VS 2015 BRZ Suspension changes fasteddy Suspension | Chassis | Brakes -- Sponsored by 949 Racing 28 03-30-2017 04:07 PM
WTB 2015 BRZ Stock Suspension donoman Want-To-Buy Requests 7 04-07-2015 04:27 AM
2015 models suspension different ??? Sugi Suspension | Chassis | Brakes -- Sponsored by 949 Racing 7 12-25-2014 11:15 PM
Review of 2015 BRZ suspension changes? thismock BRZ First-Gen (2012+) — General Topics 10 09-26-2014 09:38 AM
2015 Model FRS suspension changes SeanRTR Suspension | Chassis | Brakes -- Sponsored by 949 Racing 19 05-21-2014 12:21 PM
