Old 07-12-2015, 08:01 PM   #1
efactor84
efactor84's Avatar
Drives: 2015 Scion FR-S
Question Newb question for RomRaider with Openflash
I'm seem having trouble loading RomRaider Files from Openflash. I've downloaded the latest RomRaider. Loaded the definitions in the romraider folder for for ecu and car definitions to work properly. I tried using the files from OpenFlash version 2.067, but keep popping up an error message after adding the XML file and going to back to reopen. Any help would be appreciated.
efactor84 is offline   Reply With Quote
Old 07-12-2015, 08:05 PM   #2
steve99
Drives: FT86
Originally Posted by efactor84 View Post
I'm seem having trouble loading RomRaider Files from Openflash. I've downloaded the latest RomRaider. Loaded the definitions in the romraider folder for for ecu and car definitions to work properly. I tried using the files from OpenFlash has to offer from version 2.067, but keep popping up an error message after adding the XML file and going to back to reopen. Any help would be appreciated.
whats the error message ?
make sure your using OFT supplied romraider defs that come with oft tunes and not the defs from romraider github site
Old 07-12-2015, 08:08 PM   #3
efactor84
efactor84's Avatar
Old 07-12-2015, 08:14 PM   #4
efactor84
efactor84's Avatar
I understand the apply and save. What is the name of the file from OFT to load the definitions? I'm using the v 2.067 folder.
Old 07-12-2015, 09:04 PM   #5
ztan
Drives: Toyota 86
With that error message, if the .xml file is the right one and loaded properly, likely you have an unbalanced <table> xxxx </table> set of tags somewhere. I sometimes get these if I've messed with the .xml file and have left a tag open. They can be a real pain to find. Try finding another working .xml file for your ROM to start off with - it'll save you a lot of time.
ztan is offline   Reply With Quote
Old 07-12-2015, 09:30 PM   #6
efactor84
efactor84's Avatar
ZA1JD00D is my cal file for my 2015 Scion FRS. Does that have to be the definition file to match with whatever Openflash has to edit in RomRaider?
Old 07-13-2015, 01:21 AM   #7
steve99
Drives: FT86
ok make sure you unzip the v2.06 tune pack
their should then be a couple of folders
bin which containf the tune roms
xml containd the definitions
you need to point romraider to the exact definiton file not just the folder
eg ig you using ZA1JB01C rom then you need to point to matching definition file.
you need to set up defs first before you can open rom.
Old 07-13-2015, 04:11 AM   #8
aagun
Drives: 86
I checked opt defs and it is not available for d00d . open flash is available
aagun is offline   Reply With Quote
Old 07-13-2015, 04:58 AM   #9
ztan
Drives: Toyota 86
You'll need to use a xxxD00D.xml to open the ROM. If you open another .xml file (such as xxxB00D.xml) with a text editor and edit the "B00D" text info to read "D00D", save file as D00D.xml; you might be in luck and have a lot of addresses that are the same.
Old 07-13-2015, 06:13 AM   #10
steve99
Drives: FT86
_
If you have an OFT then contact the oft guys send them your stock rom D00D and they will make you up a tuned rom.
if you dont have oft then you will have to make your own
use this def below to open your stock D00D rom
https://raw.githubusercontent.com/TD...R_ZA1JD00D.xml
then you will have to manually copy and paste all the changed tables from a say B01D rom into the D00D rom
to find the changed tables you will need to compare a stock and tuned B01D.
Do not flash a B01D rom to a car running D00D they are not directly compatable due hardware changes to vehicle
Old 07-13-2015, 11:02 AM   #11
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That's weird, we have offering tune file support for D00D roms since 10/6/15. But for some reason, there was no D00D XML file in the download folder. An oversight on our part. If you need this XML, email me at shiv@openflashperformance.com and I'll send it to you. It will be available for download in the next version of the OTS map folder.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
aagun (07-13-2015)
Old 07-13-2015, 11:54 AM   #12
efactor84
efactor84's Avatar
Thank you Shiv for your support. I sent you the file to your email address.
Old 07-13-2015, 12:10 PM   #13
Shiv@Openflash
Drives: 2013 FRS
done!
Old 07-13-2015, 12:16 PM   #14
efactor84
efactor84's Avatar
Thank you Shiv,Steve99, and ztan and everyone else for their support. I was able to upload the xml file successfully. I'm very excited to have this done. I'll start getting into forums on tuning.
OpenFlash Tablet: RomRaider parameters for Launch Control and Flat-foot Shift Shiv@Openflash Software Tuning 118 06-04-2017 04:26 AM
sorry, newb question on Wheels jxl00 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 09-20-2014 01:19 AM
Newb question on cleaning engine bay swift996 Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 7 02-09-2014 08:34 AM
Quick newb question Gt86_nick Cosmetic Modification (Interior/Exterior/Lighting) 1 01-17-2014 07:58 PM
newb rim question carbonBLUE Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 06-29-2012 01:07 AM
