Old 01-11-2013, 04:20 AM   #43
Mo707
Mo707's Avatar
Originally Posted by chris's fr-s View Post
Does this mirror also fit the frs
Yes
Mo707 is offline   Reply With Quote
Old 01-16-2013, 09:03 PM   #44
epsilonkore
Drives: FireStorm 6 Spd Manual
I am currently trying to install my Subaru Homelink in my FR-S based off this forum thread saying I could. I fail to see the provided connecting cable to power the mirror, any suggestions?
epsilonkore is offline   Reply With Quote
Old 01-16-2013, 09:11 PM   #45
DaJo
FT86Club Vancouver
DaJo's Avatar
Drives: BRZ Sport-Tech; Drove: MR-S, AE86
It's not a very long wire at all. It's strapped to another line up in there. You can JUST see it if you poke your head up there close to the windshield looking up.
It should be just slightly behind the dome light (towards the rear) and a little bit to the passenger side IIRC...
1984 AE86 BT 20V 5MT 2007-2012
2000 MR-S 5MT
2010-2012
2013 BRZ Sport-Tech 6AT
Since '12 (OEM+ STI tS Build)
2015 Lexus IS250 AWD F-Sport 2 2015-2018
2018 Lexus NX300 F-Sport 3 Since '18
DaJo is offline   Reply With Quote
Old 01-16-2013, 09:26 PM   #46
epsilonkore
I wouldn't have kept going without the confirm Thanks! It was UP IN THERE and taped to a group if wires (like you said) had to get a smaller friend to fish it out without my large hands ripping the top apart. Thanks again!
Old 05-14-2013, 01:38 PM   #47
sherlockyou
Drives: 86 GTS aero
Anybody know if this mirror will fit on Australian 86??
sherlockyou is offline   Reply With Quote
Old 05-16-2013, 12:51 AM   #48
WolfSongX
WolfSongX's Avatar
Drives: 2013 Subaru BRZ Limited SWP
I have the auto dim mirror with the compass but without the Homelink and I've been wanting to upgrade to this. Does anyone know if I need another adapter kit or can I reuse the one in my current mirror?
Thanks
Derek
2013 BRZ Limited SWP
Professional driver in search of closed course..
WolfSongX is offline   Reply With Quote
Old 06-11-2013, 06:35 PM   #49
Scionshaun
Aloha!
Drives: Whiteout
This mirror is made by gentex, what's the model number? And is it already prewired to plug and play or do we have to splice wires connect if we ont get it from subaru?
Scionshaun is offline   Reply With Quote
Old 11-01-2013, 12:42 PM   #50
gtishtar
Drives: 86
i'm not sure if i'm misunderstanding your instruction, cuz i can't find it ...uploaded the video, maybe you could help me with it
the only connect i can find is connected to the overhead console
gtishtar is offline   Reply With Quote
Old 11-01-2013, 09:33 PM   #51
Gen
Drives: Scion FR-S
It's a pain to find. I had to fish around in there for 30 minutes before I was able to locate it.
Gen is offline   Reply With Quote
Old 07-05-2014, 08:20 PM   #52
BKF
I just installed the HomeLink mirror and, like everyone else, it took me quite a while to find the little plug. Here is some additional information that may be useful: the plug is wrapped in thin foam rubber tape. This tricked me because I was feeling around for hard plastic. I thought the soft materials were insulation. Also, the plug was taped to the headliner, not to the underside of the roof. The location of the plug was consistent with where it is shown on the installation instructions.
Everything about the installation was pretty easy. I probably spent more time trying to locate the plug than I did on all of the other steps combined. After you find the plug, you will have to pull on it fairly hard to get it free because it has been taped down onto your headliner.
BKF is offline   Reply With Quote
Old 10-20-2014, 07:51 PM   #53
Shinobu's Smile
Drives: 2010 Tacoma, 2015 BRZ AT Limited
Even with all the "its in there just keep searching" i was going to give up and just assume the 2015's didnt have it. Somehow just fiddling around in there loosened up the foam coated plug. Thank you so much.
On a separate note, did anyone find that there was a lot of slop/play with the 2 holed metal insert that slides into the "U" shaped metal spring? Mine had so much juggle that when i mounted the mirror it rattled a lot. I had to wrap electrical tape around the U spring to make the metal insert snug and when the mirror is mounted and it still wobbles a little.
Part was H501SSA041 from subaruonlineparts.com
Shinobu's Smile is offline   Reply With Quote
Old 07-11-2015, 03:01 PM   #54
jtsimaras
Drives: Subaru BRZ, Mazda CX5,
I think my homelink is buggered. The LEDs don't blink at all and not syncing however compass and auto dim work. Sucks I bought off ebay and good luck getting money back as it is electronic. Has anyone else had this issue? thanks
jtsimaras is offline   Reply With Quote
Old 08-04-2015, 10:52 PM   #55
fridayfrs
Drives: Frs
Thought these may help someone installing the mirror. The empty plug is where the wiring harness plugs into.
Size:  277.5 KBName:  ImageUploadedByTapatalk1438739484.264216.jpg
fridayfrs is offline   Reply With Quote
Old 11-17-2015, 05:10 PM   #56
davesrave
davesrave's Avatar
Drives: 2014 Boxster S; 2015 Macan S
Does anyone know if the U-Pin in the existing mirror can be reused instead of the replacement U-Pin contained in the kit?
davesrave is offline   Reply With Quote
Homelink mirror ? FRS not an option - so does BRZ part fit ? rikdrt1 Scion FR-S / Toyota 86 GT86 General Forum 5 06-12-2012 12:00 PM
How to install Homelink mirror? Grimlock Electronics | Audio | NAV | Infotainment 10 06-10-2012 07:07 PM
Nav auto dimming when headlights on speedracer38 Electronics | Audio | NAV | Infotainment 1 06-06-2012 01:59 AM
Auto Dimming Homelink/Compass Mirror Part Number R0ME0 BRZ First-Gen (2012+) — General Topics 5 04-19-2012 01:19 PM
question about tinted windows with auto dimming mirror... Norcalmav23 BRZ First-Gen (2012+) — General Topics 13 04-06-2012 08:37 PM
