Old 07-08-2015, 09:07 AM   #43
Rafi@RR-racing
Rafi@RR-racing's Avatar
Drives: Toyota GT86
Originally Posted by ka-t_240 View Post
I typically run 200tw tires for most events. I have 2 events per year that I usually plan on r comps(Hoosier a6) for autox and time attack. The rest I run in street classes. My plan was to order dtc60s originally.
Looks like the end bp20 has a higher temp rating and a slightly friction rating, but only at the high heats. Are the compounds with letters the hawk products?
Would you say that the lower initial friction rating would result in a bit less intitial bite?
Dust,noise, etc don't bother me. The sacrifice is worth it when it comes to proper track performance.
A lot of guys run DTC-60 or equivalent on stock brakes because the stock rotors do not have sufficient thermal capacity, and therefore overheat the pads -- so you need to run a higher temp pad on stock rotors.
With our 330mm rotors, that is not necessary unless you are doing more sustained endurance efforts on race rubber.
Lets put it this way, we ran BP30s on the Element Time Attack FRS, we Phil was really impressed with the shear braking power of this setup. And keep in mind, Phil's car is just a bit on the extreme side:-)
That said, BP30's run friction coefficient of about 0.62, and DTC60's are about 0.75 --- we had DTC60's with us to try, but it was pointless, we did not need that kind of friction, and using the DTC60s would reduce our pedal pressure too much.
BP20's will feel like they lack bite until they get up to temp, otherwise they feel great.
I would try BP20's first, I think you will be happy. The next incremental step up if you feel any fade is "Compound J," followed by BP30's.
Rafi
Rafi@RR-racing is offline
The Following 2 Users Say Thank You to Rafi@RR-racing For This Useful Post:
DAEMANO (07-08-2015), ka-t_240 (07-08-2015)
Old 07-08-2015, 10:12 AM   #44
ka-t_240
Replacement pads for the bp20 are only $86ish? Was just looking thru your website.
ka-t_240 is offline
Old 07-08-2015, 10:20 AM   #45
ka-t_240
Has anyone tried fitting these under the stock wheels?
ka-t_240 is offline
Old 07-08-2015, 11:11 AM   #46
SubaruLifer
Drives: 2015 ISM BRZ Premium
One of the earlier posts in this thread:
Originally Posted by Rafi@RR-racing View Post
That's a good question, generally the Stage II and IV will not fit stock rims because they use much wider calipers to accommodate thick pads.
So if you want maximum clearance, you need to go with Stage I or Stage III which use the more narrow caliper. Rear should fit no problem with stock wheels.
That said, for the front, even with the Stage I or Stage III, you will still need approx. 10mm spacer for stock wheels.
You can download the wheel fitment templates off of the description page of each brake kit on our site.
-Rafi
SubaruLifer is offline
Old 07-08-2015, 11:42 AM   #47
Rafi@RR-racing
Drives: Toyota GT86
That's one of the nice things with these pads. They are a very common pad configuration that fits many different Wilwood, AP, and other manufacturer's calipers.
Don't be fooled by the relatively low price, these pads are really good.
Rafi
The Following User Says Thank You to Rafi@RR-racing For This Useful Post:
DAEMANO (07-09-2015)
Old 07-09-2015, 08:41 PM   #48
Panman
Panman's Avatar
Drives: 86 GTS
@Rafi@RR-racing - You have email from me regarding my delivery.
Panman is offline
Old 07-10-2015, 01:20 PM   #49
ka-t_240
Besides the caliper clearance/pad thickness, are there any differences the stage 1 vs stage 2? One caliper stronger than the other,one better at heat disipation, ect.
ka-t_240 is offline
The Following 2 Users Say Thank You to ka-t_240 For This Useful Post:
endless_pain (07-10-2015), Pat (07-10-2015)
Old 07-10-2015, 06:09 PM   #50
Rafi@RR-racing
Drives: Toyota GT86
Both Stage I and II calipers use the same forged construction, and are the same except for:
(1) Stage II calipers accommodate thicker pads. Stage II pads are 0.8" thick, and Stage I pads are 0.65" thick. Thicker pads reduce heat transfer and last longer.
(2) Stage I calipers are powder coated red or black, Stage II are black anodized. Powder coating looks great, but is not as durable as anodizing for those who track their cars.
(3) Stage I calipers require less wheel backspacing than Stage II calipers.
-Rafi
DAEMANO (07-10-2015)
Old 07-10-2015, 09:29 PM   #51
ka-t_240
-Rafi
Thank you, that was my assumptions in the differences between each. I was liking the thicker pads, as that is thicker than most pads for the OEM calipers. As someone who has had the joy of experiencing boiled fluid, I am all about preventing that. I would assume the extra clearance between the stage 1 and 2 would be thinning up the caliper in the center, thus the thinner pads and extra wheel clearance.
The narrow version should see any negative impacts in the ability to handle stress or heat from being "narrow", should it?
ka-t_240 is offline
Old 07-15-2015, 02:58 PM   #52
ModinJapan
ModinJapan's Avatar
Drives: 2013 SCION FRS
We have special pricing on these, pm us for more information!
-Josh
ModinJapan is offline
Old 07-15-2015, 03:15 PM   #53
DAEMANO
Time Traveller
-Josh
PM price for Stg 1 & 2 kits shipped to 92704 pls
DAEMANO is offline
Old 07-15-2015, 08:20 PM   #54
Rafi@RR-racing
Drives: Toyota GT86
The narrow version was mainly designed for added wheel clearance, but I will tell you that it will easily handle ANY street application and MOST track applications. But if you happen to have wheels with sufficient backspacing, I recommend the wider Stage II/IV calipers, it will be that much better, not to mention that the pads will last much longer.
Rafi
Old 07-17-2015, 01:45 PM   #55
ModinJapan
ModinJapan's Avatar
You've got PM!
Old 07-18-2015, 06:48 AM   #56
Panman
Panman's Avatar
Drives: 86 GTS
Rechecked my templates today for my Stage I kit - both my RPF-1 +35 and Desmond Regamaster 17x8 +35 will clear.
Panman is offline
big brake kit, competition, track
AP Racing brake systems in development track_warrior Suspension | Chassis | Brakes -- Sponsored by 949 Racing 872 09-17-2017 07:43 PM
Megan Racing Coilovers - Street / Track / EZ STREET - Starting at $699 Shipped GuerillaRacing Brakes, Suspension, Chassis 149 05-12-2015 05:53 PM
AP Racing Factory Big Brake Kit, NOT Competition Lonergt Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 08-25-2013 04:51 PM
Official street racing thread. All street racing goes here! bkblitzed Off-Topic Lounge [WARNING: NO POLITICS] 8 07-19-2013 11:31 AM
Essex/AP Racing Competition Brake System in Development JRitt Brakes, Suspension, Chassis 1 06-14-2012 01:32 PM
