Old 07-10-2015, 11:49 AM   #1
burdickjp
Drives: 2013 ultramarine Scion FR-S
Data analysis and modification with Python
I've seen a number of tools for doing data analysis on here. Most are done with spreadsheets, which aren't conducive to large amounts of data. Others are written in Java, or .NET, which isn't bad, but isn't conducive to the end user wanting to learn not just what the tool does but how it does it.
Python is, by its nature, a human readable language, so I'd like to share with you how to do some data analysis in Python.
If you're running Linux you probably already have Python. We need the libraries called pandas and bokeh. I assume, since you are running Linux, that you know how to get these. I prefer using Python3.
If you're running anything else you can get an all-inclusive package called Anaconda which pulls everything in for you. Anaconda includes several environments for playing with Python. I prefer Spyder, as it has a variable explorer similar to MatLab. Think of it as being a MatLab environment, but better, because it's not MatLab.
Once you've got everything up, fire up Spyder. Throw this into the left pane and hit the green arrow. You'll want to edit line 13 to point to the log you'd like to use. Line 15 is the X axis of the graph. Line 16 is the Y axis.
Code:
# -*- coding: utf-8 -*-
 Created on Thu Jul  9 22:06:52 2015
 @author: jeff
 import pandas as pd
 from bokeh.plotting import figure, HBox, output_file, show, VBox
 output_file("graph.html")
 logRaw = pd.read_csv('log.csv')
 p1x = logRaw['time']
 p1y = logRaw['RPM']
 p1 = figure(tools="pan,wheel_zoom,box_zoom,reset,save", plot_width=1024, plot_height=600)
 p1.scatter(p1x, p1y, size=1, color="red", alpha=0.5)
 show(VBox(HBox(p1)))
I'll be updating this to include more awesome things like 3d graphs, etc. I'd eventually like to get MAF scaling tools and others ported to Python.
burdickjp is offline   Reply With Quote
The Following 4 Users Say Thank You to burdickjp For This Useful Post:
aagun (07-10-2015), DAEMANO (07-10-2015), GT86_PRAGUE (07-13-2015), mkivsoopra (07-10-2015)
Old 07-10-2015, 04:09 PM   #2
Kodename47
Kodename47's Avatar
Drives: UK GT86
If I remove the top line I get this error:
UnicodeDecodeError: 'utf-8' codec can't decode byte 0xb0 in position 24: invalid start byte
If I put the 1st line in I get:
p, li { white-space: pre-wrap; } p, li { white-space: pre-wrap; } # -*- coding: utf-8 -*-
SyntaxError: invalid syntax
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-10-2015, 04:52 PM   #3
burdickjp
Try it now. That "p, li { white-space: pre-wrap; } p, li { white-space: pre-wrap; }" was junk added in the posting process. If you open a blank spyder doc you'll see what the header is supposed to look like.
The Following User Says Thank You to burdickjp For This Useful Post:
Old 07-10-2015, 08:03 PM   #4
Kodename47
Kodename47's Avatar
Drives: UK GT86
This is what I've put entered:
Code:
 @author: jeff
import pandas as pd
logRaw = pd.read_csv('C:\EcuTek\MapAccessLogs\Sprintex 70mm-01-03-2015.csv')
p1x = logRaw['Time']
p1y = logRaw['FLKC']
I still get the same unicode decode error as above. Is it a log file length/format thing?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-10-2015, 09:09 PM   #5
phrosty
Why do you believe Python is, by its nature, a more human readable language than the other ones you mentioned (Java and C#)?
phrosty is offline   Reply With Quote
Old 07-10-2015, 09:16 PM   #6
burdickjp
I'm not a programmer, so the specifics of it are lost on me. I know that python is much easier for ME to read and understand than other languages. The only c-like language I've seen as similarly easy is wiring (arduino programming). It's my understanding wiring handles a lot in the background to make it easier in the foreground.
There's a reason python is experiencing explosive growth in academia, science, and research. It's not necessarily on topic here, but I LOVE python and feel it's the right tool for this job.
Old 07-10-2015, 09:17 PM   #7
burdickjp
Code:
 @author: jeff
import pandas as pd
I'm not sure. Are you using anaconda with python 3 or python 2?
Old 07-10-2015, 10:19 PM   #8
wbradley
Sarcastic SOB
wbradley's Avatar
Python: the programming language for Arduino.
Some cool project ts done with it. In the pinball machine hobby there are some real magicians. A guy named Ben Heck started with hacking game consoles and then controller U its for one off custom pinball machines.
Cool stuff.
Old 07-10-2015, 10:24 PM   #9
burdickjp
Cool stuff.
I'm sure someone had python being compiled for arduino, but I'm most familiar with wiring and arduino. Again: right tool for the job. Wiring is great for it.
Sent from my XT1045 using Tapatalk
Old 07-11-2015, 04:05 AM   #10
Kodename47
Kodename47's Avatar
Drives: UK GT86
I downloaded Python 3. I literally installed and then ran Spyder as you suggested.
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2015, 04:19 AM   #11
coyote
coyote's Avatar
Drives: Slowly
Python is great for this kind of stuff. I use it a lot.
Sent from my Nexus 6 using Tapatalk
coyote is offline   Reply With Quote
Old 07-11-2015, 06:47 AM   #12
burdickjp
There might be a bug with the current version of anaconda using Python3 and windows. Let me see what I can find.
Kodename47 (07-11-2015)
Old 07-11-2015, 07:10 PM   #13
Kodename47
Kodename47's Avatar
Drives: UK GT86
I'm on Windows8 64 bit. Should I revert to python2?
.: Stealth 86 :.
Kodename 47 DJ:
Old 07-11-2015, 08:15 PM   #14
burdickjp
Give it a try. I booted into windows and got a similar error.
BRZ MPG Data Analysis housecat BRZ First-Gen (2012+) — General Topics 30 02-14-2016 09:32 PM
Recognizing Brake Fade with Data Analysis GSpeed Tracking / Autocross / HPDE / Drifting 25 07-06-2015 01:42 AM
Help with School Assignment.(Programming with Python) Zaku Off-Topic Lounge [WARNING: NO POLITICS] 0 04-09-2013 03:55 PM
python vinyl wrapped interior panels Vonsamhain Cosmetic Modification (Interior/Exterior/Lighting) 26 10-14-2012 02:21 AM
Downloadable driving data/Toyota encourages modification nate89 Scion FR-S / Toyota 86 GT86 General Forum 22 03-15-2012 10:12 AM
