Old 07-09-2015, 12:14 AM   #2353
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Originally Posted by BRZtoni View Post
yeah I noticed that as well its super super tiny... @King Tut
your truly helpful and I will definetly contact you when I need help hooking up the vacuum lines hopefully I wont be a big headache. LOL
EBCS won't like the vacuum block. I really couldn't use mine on it as the source for the EBCS needs to be directly from the turbo compressor.
I had to keep the w/g, and EBSC on a seperate connection than my fast turbo vac block which gets it's input post throttle body/intake. With the EBCS and w/g into the vac block I kept overboosting.
2cents~
Old 07-09-2015, 09:55 AM   #2354
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
2cents~
Yeah, as I mentioned it is not an optimal setup, but it will work. It took some fine tuning, but I got mine to where I was pretty happy with the boost curve using a GFB Electronic Boost Controller setup:
The best way to do things would be a vacuum manifold for the BOV and boost gauge and a direct compressor housing fitting for the wastegate and EBCS.
Old 07-09-2015, 06:22 PM   #2355
willharp360
So I'm having issues while driving my car. Anytime that I give it throttle the car resists and then jerks back and forth a few times, doesn't matter what gear I am in. That's the best way I can explain it, anyone have the same issue or know what it could be?
willharp360 is offline   Reply With Quote
Old 07-09-2015, 06:25 PM   #2356
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
compressor housing fitting? like tap a fitting into the turbo?
is there any other way than doing that?
Flex Fuel Turbo BRZ
BRZtoni is offline   Reply With Quote
Old 07-10-2015, 08:39 AM   #2357
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Yes and yes!
You can buy asilicone coupler/t-band that has a fitting already on it. They were kinda hard to find though especially one that will fit in the tight spacing. Of you can weld a piece onto the charge pipes and tap that. Similar to how there is a big chunk welded on for the MAF sensor. I didn't like that option as it would destroy a good part of the powdercoating.
At the bottom of the turbo compressor there should already be a thick, round section that is ideal. Start with a small hole and slowly work your way up as to not crack it. Lots lof lub when tapping the threads too.
You gets your boost directly from the source and it will allow the ebcs to remain most accurate. Putting it on the compressor will also allow a slightly safer reading as it will always read a bit higher than what the intake manifold is seeing.
Old 07-10-2015, 09:59 AM   #2358
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Did that just start? Who tuned the car? Have you datalogged that specific issue and sent it to your tuner?
Old 07-10-2015, 10:56 AM   #2359
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Yes and yes!
ima try to go through with the vacuum manifold route first and see how my boost spike is. and if its still pretty bad i might have to go that route. im not familiar or feel comfortable with tapping into my expensive turbo. might have a shop help me.
Flex Fuel Turbo BRZ
Old 07-10-2015, 11:03 AM   #2360
willharp360
It just started yesterday and I'm still on the basemap right now
Sent from my SAMSUNG-SM-G900A using Tapatalk
Old 07-10-2015, 05:25 PM   #2361
FullBlown
FullBlown's Avatar
Drives: Scion FRS
Check the oring on the pump. Are you able to get a log?
FullBlown is offline   Reply With Quote
Old 07-10-2015, 05:30 PM   #2362
xDBOYx
xDBOYx's Avatar
Drives: 2013 SWP BRZ Limited
This is what I'm using. Search atp quick tap. Idk how well it works since my car still isn't up and running yet.
xDBOYx is offline   Reply With Quote
Old 07-10-2015, 05:49 PM   #2363
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
Yes and yes!
let me know how that goes if it works for you i might purchase one!
thanks for the advise man!
Flex Fuel Turbo BRZ
Old 07-10-2015, 07:13 PM   #2364
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Log it and send it over to the Maestro LJ he'll take care of you. However, it is a basemap, I would expect the driveability to be less than optimal because every car is different.
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 07-10-2015, 08:11 PM   #2365
xxscaxx
I don't have a FBM kit but i've used this quick tap in the past on my old STi with no issues. Its a good substitute if you are against tapping the compressor housing.
xxscaxx is offline   Reply With Quote
Old 07-11-2015, 01:57 PM   #2366
BRZtoni
Turbo E85
BRZtoni's Avatar
Drives: 13 wrb brz
@FullBlown
im missing another piece of my intercooler piping please help asap T_T
Flex Fuel Turbo BRZ
best company ever, big fuck off turbo, blown, bow chicka wow wow, fbm, full, owners, powaaaaaa!, thread, will work for turbo
AVO Turbo Kit Owners Topic Sportsguy83 Forced Induction 1935 02-20-2023 10:46 AM
Full Blown FRS/BRZ Stage 1 Turbo Kit FullBlown Forced Induction 456 09-27-2021 03:10 AM
FA20Club Turbo Kit Owners Topic pixel67 Forced Induction 1531 09-09-2014 12:36 PM
Full Blown Turbo Kit! Unleashed Engine, Exhaust, Bolt-Ons 70 10-09-2013 09:46 AM
WTB: Full Blown turbo kit (used) whitefrs Engine, Exhaust, Bolt-Ons 12 03-29-2013 09:15 PM
