#15 |
Drives: many
I had thought about this a long while back for an MR project but the crank rotated the wrong direction.
#16 |
Drives: stock
Is this a hya bus siamese If so its perfect for this car. All you need to do is chop out all the metal bits that make up the chassis. Then insert a carbon fiber tub made with all the same attachment points for body panels and running gear.
It would drive like a mini TVR
#17 |
Drives: '06 AM V8V Coupe
Engine cost aside, you have to figure out how to mate the engine to the transmission....this seems pretty hard lol. And then get electronics to cooperate.
#18 | |
Drives: toyota mr2/ Toyota GT86
#19 |
Drives: many
#20 |
very likely but its also going to be £60K, whereas a used Trev is about 20K
#21 |
Drives: Toyota 86
We have already done type of engine swap. Our V8 is based on the Kawasaki ZX-12 engine available in either 2.4 litre or 3 litre configurations. The kit can be installed without drilling a single hole in the car and includes wiring loom adapters and all the parts to fit the engine to the car (hoses, carbon drive shaft, gearbox adapters etc).
Here are a couple of reviews:- http://www.speedhunters.com/2015/06/...y-at-11600rpm/ http://www.speedhunters.com/2015/01/...ynergy-brz-v8/ |
#22 |
Drives: 13' Scion FRS Track car
@MSEL ...how much a v8 swap like this cost ? I mean I am surprised anybody would do anything so nice
2013 Scion Frs Track Car - Sold.
#23 | |
Drives: 2015 CWP BRZ Limited
#24 |
Thats pretty neat
Drives: LOADING......
Man I need to get me one of them synergy v8's to build a sweet grown up gokart with!!!!
#25 |
Because compromise ®
Drives: Red Herring
@MSEL
Thanks for posting here. I haven't won the lottery yet so this is just an interest question. Is there an air filter lurking in there?
#26 | |
Drives: Toyota 86
The Following User Says Thank You to MSEL For This Useful Post: | Captain Snooze (07-11-2015) |
#27 | |
Drives: Toyota 86
Why do it? We did it to show that we could do it. It was a challenge we set outselves to do the conversion without cutting a wire, drilling a hole or in any other way modifying the original chassis. The result is something which adds to the base car and in our opion correct the main short coming, which is lack of power, without detracting from what makes the original car so good. |
The Following 2 Users Say Thank You to MSEL For This Useful Post: | Griever423 (09-06-2015), Valentino (07-13-2015) |
#28 | |
Drives: Red Herring
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
2JZ swap? | jordydiaz | Engine Swaps | 44 | 05-21-2015 10:19 PM |
WRX SWAP!!! | PowderfaceTr. | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 02-24-2015 06:29 PM |
Should I swap? | michaelahess | BRZ First-Gen (2012+) -- General Topics | 8 | 06-12-2012 07:32 PM |
