Old 07-08-2015, 07:00 PM   #309
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by Spartarus View Post
Ok then. It was just a casual suggestion, don't have to go that route. I'll share the information when I have all of it anyway...
I'm glad to hear the car is great. Glad to know I won't ruin mine by throwing a v8 in there. The original Vorshlag blog posts sold me on the idea anyway. Lots of really good information packed in there, even though the last update is last December.
It has been updated 2 July with tons more info....
cf6mech is offline
Old 07-08-2015, 07:03 PM   #310
bumppinKota
Drives: FRS!!!
Can you post a link... I'm having trouble finding it
bumppinKota is offline
Old 07-08-2015, 07:09 PM   #311
cf6mech
Originally Posted by kch View Post
http://www.ft86club.com/forums/showp...&postcount=201
This guy has a 5.3L iron block LS and they're fitting a turbo. Details are scarce.
There's a ton of room under the bonnet specially around the headers.....the exception is the throttle body,gets a little tight there.....don't see why not....but at some point the diff and axles and supporting tire size would have to be addressed at higher hp .....which means of course $$$$$$$.
cf6mech is offline
Old 07-08-2015, 07:12 PM   #312
cf6mech
http://www.vorshlag.com/forums/showthread.php?t=8275
cf6mech is offline
The Following 4 Users Say Thank You to cf6mech For This Useful Post:
bumppinKota (07-08-2015), civicdrivr (07-09-2015), Raven604 (07-09-2015), xxscaxx (07-09-2015)
Old 07-08-2015, 07:41 PM   #313
bumppinKota
Drives: FRS!!!
Good read! Thanks! I would like to do this a few years down the road. Gotta save till then.
The Following User Says Thank You to bumppinKota For This Useful Post:
cf6mech (07-08-2015)
Old 07-09-2015, 01:45 AM   #314
modernbeat
Vorshlag R&D
modernbeat's Avatar
Drives: A new one every month
...I'm glad to hear the car is great. Glad to know I won't ruin mine by throwing a v8 in there. The original Vorshlag blog posts sold me on the idea anyway. Lots of really good information packed in there, even though the last update is last December.
Rick has been getting private photos and email updates since then. He's shared a portion of them with the group. Terry did a massive update to the thread, as was noted. We tried to keep the momentum up while we waited for the headers, and waited, and waited. Before the header wait, and after we had a good production set, we moved forward quickly on the car. So that big gap with no updates...yeah, that was the headers.
On the standalone ECM, if this were a one-off swap we'd talk to the owner about development costs VS a semi-ready off the shelf solution and most likely go with the aftermarket ECM. We'd also have a one-off done in just a few months, about a third of what developing a kit will take.
When developing a kit, and that's what we are doing with Rick's car, we have a lot of competing issues to work around. We try not to modify the tub or subframes if possible. We make sure everything will go together with just hand tools and occasionally a drill. The components need to be affordable and not hinge on any one unusually expensive part, which in many people's eyes will make the kit undesirable unless a substitute part or solution can be found. When doing a development project like this, we eat all the development costs so when a product is built, it's ours. The car owner pays the normal part price, and reduced installation costs, but the majority of hours spent on it are absorbed by the shop. So along those lines our plan is to build a bridge and wiring harness to make this swap as easy as possible, and trying to keep the electronics cost low-ish, and not lock the owner out of the ECM.
That, and if I went with an aftermarket ECM, I'd use a Life Racing unit.
Jason McDaniel at Vorshlag Motorsports
modernbeat is offline
The Following 3 Users Say Thank You to modernbeat For This Useful Post:
cf6mech (07-09-2015), civicdrivr (07-09-2015), strmshadow84 (07-09-2015)
Old 07-09-2015, 11:29 AM   #315
Spartarus
...Just add nauseum
Spartarus's Avatar
Drives: 2003 (AP1) S2000
I understand the gap and wasn't knocking you for that, I'm just impatient haha.
Honest curiosity about the kit though, as I'm still considering options... Will you be selling a "stage 0" similar to some of your BMW kits with only the mounting hardware and exhaust components for those who want to find their own ECU solution and engine? Or for people who will need a standalone anyway for mods / tuning capability / ...?
Also, I've had no trouble digging up the t56 magnum xl, but only as a swap-in unit for Coyote mustangs... Am I under the correct impression that it isn't available for the LS-series yet? If so, can the ford bellhousing just be popped off and swapped for a GM small block->T56 bellhousing, or did they mess with the input shaft?
EDIT: wow, I can't believe I didn't see that update until now.... whoops.
Spartarus is offline
Old 07-09-2015, 02:00 PM   #316
cf6mech
The input shaft was re-splined for a GM application specifically for us at the time, but was under the impression this was going to be available to the general public by now as a cataloged option. I'm pretty sure a call to Tremec could remedy this either way.
cf6mech is offline
Old 07-09-2015, 06:16 PM   #317
modernbeat
Vorshlag R&D
modernbeat's Avatar
...Will you be selling a "stage 0" similar to some of your BMW kits with only the mounting hardware and exhaust components for those who want to find their own ECU solution and engine?...
Rick is correct. We had Tremec custom build the Magnum XL for us with the GM bellhousing and input shaft. It should be a catalog item in the future.
While I can't say it with absolute certainty, I expect we will sell this kit just like the E36 kit. A base kit of hard parts to make ordering easy, and all the hard parts and optional parts available separately.
The Following 2 Users Say Thank You to modernbeat For This Useful Post:
shiro (07-14-2015), wparsons (07-18-2015)
Old 07-12-2015, 09:09 PM   #318
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Dyno news yet?
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline
Old 07-13-2015, 03:42 AM   #319
cf6mech
Originally Posted by carbonBLUE View Post
Dyno news yet?
Its scheduled for Monday the 13th ....today.
cf6mech is offline
The Following User Says Thank You to cf6mech For This Useful Post:
carbonBLUE (07-13-2015)
Old 07-13-2015, 05:49 AM   #320
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Do you think the torque dip will be gone?
Captain Snooze is offline
The Following 2 Users Say Thank You to Captain Snooze For This Useful Post:
cf6mech (07-13-2015), civicdrivr (07-13-2015)
Old 07-13-2015, 07:21 AM   #321
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Will still be there from 0-750rpms
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
The Following 4 Users Say Thank You to Floggin Tires For This Useful Post:
Calum (07-13-2015), cf6mech (07-13-2015), Vracer111 (07-13-2015), wparsons (07-18-2015)
Old 07-13-2015, 09:46 PM   #322
Vracer111
Vracer111's Avatar
Drives: '13 Nissan Frontier (4.0L 6spd 2WD)
Dang you, torque dip...is there no solution!!!!!!
Had a '13 FR-S Asphalt 6spd manual (bought new 5/25/12, sold 6/10/20) but needed to let her go... she will be missed.
Vracer111 is offline
The Following User Says Thank You to Vracer111 For This Useful Post:
Calum (08-12-2015)
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 09:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 10:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 08:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 05:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 01:19 PM
