CANADA Canada
Old 07-08-2015, 05:42 PM   #9101
thcSpecter
Drives: WRB BRZ Aozora
Ill be meeting you guys at rcr. Should be there about 620
thcSpecter is offline   Reply With Quote
Old 07-08-2015, 06:13 PM   #9102
AznKirby
Are you 20/20?
AznKirby's Avatar
Drives: Hopes and dreams
Have fun, boys!
2014 FR-S Monogram
2005 Acura RSX Type-S
IG: @MonKehC
Old 07-08-2015, 06:34 PM   #9103
James FR-S
Drives: 2014 Asphalt FR-S
JDM Tips, Yo!
Thanks Ruzbeh!
The tips look great! I'll be coming by RCR but I'm bringing my 4 yr old and my car is dirty so I'll park nearby...
Cheers,
James
James FR-S is offline   Reply With Quote
The Following User Says Thank You to James FR-S For This Useful Post:
FRSToyota86 (07-09-2015)
Old 07-08-2015, 06:55 PM   #9104
iJeff
iJeff's Avatar
Drives: 2016 Raven FR-S
Anyone know where I can get this backup camera I have installed? I was going to do it myself but haven't a clue what I'm doing.
iJeff is offline   Reply With Quote
Old 07-08-2015, 07:05 PM   #9105
brilthor
brilthor's Avatar
Drives: Stage 2 NA E85 ultramarine FRS
Anybody have a couple passes for bluesfest I could borrow for tonight?
brilthor is offline   Reply With Quote
Old 07-08-2015, 08:51 PM   #9106
UMB FR-S
UMB FR-S's Avatar
Drives: Ultramarine Blue FR-S
I'm sure there are members that could help you with the install on here. I've never installed one but I'm sure it can't be too bad.
-- Kenny
"I don't always use heel/toe, but when I do it's because racecar."
UMB FR-S is offline   Reply With Quote
The Following 3 Users Say Thank You to UMB FR-S For This Useful Post:
FRSToyota86 (07-08-2015), iJeff (07-08-2015), OrangeGuitar (07-09-2015)
Old 07-08-2015, 09:29 PM   #9107
FRSToyota86
FRSToyota86's Avatar
Drives: 2013 Scion FRS
I can help.
Vortech V3 Supercharger| 12 PSI|E85 MotoEast Flexfuel kit|Crawford AOS| Mishimoto Oil Cooler|3"Perrin Resonated CBE| 3" JDL Front/Over Pipe|OpenFlash Performance Headers|Exedy Stage 2 Ceramic Clutch |Yonaka Coilovers|17x9 O.Z. Wheels| 245/40r/17|TRD Brake Pads|Perrin Master Cylinder Brace |ChaseBay SSBrake Lines|CF Side Fins|OEM Shark Fin Athena|Yospeed Console Plaque|R/T Shift Knob|Fog Lights|Backup Camera|Navigation| |TRD Quickshifter|Motul Gear Oil|
FRSToyota86 is offline   Reply With Quote
The Following User Says Thank You to FRSToyota86 For This Useful Post:
iJeff (07-08-2015)
Old 07-08-2015, 09:49 PM   #9108
iJeff
iJeff's Avatar
Originally Posted by FRSToyota86 View Post
I can help.
Thanks! How long did your install take?
Old 07-08-2015, 11:28 PM   #9109
FRSToyota86
About 3 hours
Old 07-09-2015, 07:04 AM   #9110
Ft86Chris
Winter ***e engaged
Ft86Chris's Avatar
Drives: Ashpalt 2014 Frs Manual
Hey Ruzbeh, car sounds great!
2014 Asphalt MT FR-S Ecutek custom tune, Bolton's and Sticky tires.
Ft86Chris is offline   Reply With Quote
The Following User Says Thank You to Ft86Chris For This Useful Post:
Old 07-09-2015, 09:44 AM   #9111
FRSToyota86
What kind of harness do you have?
Old 07-09-2015, 10:02 AM   #9112
FRSToyota86
Originally Posted by James FR-S View Post
Thanks Ruzbeh!
Cheers,
James
Good luck taking the old tips off...
Old 07-09-2015, 10:23 AM   #9113
jvincent
jvincent's Avatar
This.
Here was my process.
1. Break both bolts off using 10mm socket.
2. Get a hammer and beat the shit out of the tips using the claw end until they come off.
The Following 2 Users Say Thank You to jvincent For This Useful Post:
James FR-S (07-09-2015), OrangeGuitar (07-09-2015)
Old 07-09-2015, 12:59 PM   #9114
Slick
Slick's Avatar
Drives: FR-S Firestorm 6MT
Originally Posted by jvincent View Post
This.
If you have access to an angle grinder, just use a cutting wheel and slice into it below the bolt threads. Will come off in 2 minutes.
Slick is offline   Reply With Quote
The Following User Says Thank You to Slick For This Useful Post:
