Old 07-07-2015, 05:07 PM   #15
brady86
Drives: 2013 firestorm fr-s
http://www.datazap.me/u/brady86/3rd-...ta=1-2-8-12-14
and lastly a 3rd gear pull on the 93 octane stage 2 after i re flashed at the gas station
stll has some knock but not like before. @steve99
brady86 is offline   Reply With Quote
Old 07-07-2015, 05:13 PM   #16
steve99
Drives: FT86
You will need to log engine load in your logs as timing tables are load vs rpm.
quick look at logs suggest timing changes as per jb86d,s how to guide few posts back would solve most of your problems, that must be pretty ordinary 93 fuel.
Old 07-07-2015, 05:18 PM   #17
steve99
Drives: FT86
better gass ?? cooler temperature ?? different gears means different loads to timing and fueling is different
Old 07-07-2015, 06:49 PM   #18
ztan
Drives: Toyota 86
yeah on the way to work on highway i went to pass and bam went from 1.00 to .68 and it stayed like that rest of the trip.
You'll get more part and full throttle knock at highway speeds at lower RPM in the higher gears (higher engine loads). Downshift and make the pass at redline...
ztan is offline   Reply With Quote
Old 07-07-2015, 06:54 PM   #19
brady86
Was on same gas and temp should have been about the same.maybe even a little hotter I did a 3rd gear pull before to.
Old 07-08-2015, 07:59 AM   #20
wparsons
wparsons's Avatar
seems like a lot more work then I want to do for just a flash tune maybe I should go get a dyno tune by jay perry. and just use my oft for clearing codes and data logging
Unless you're going to pay a lot extra for a low throttle street drivability tune, you'll be in the exact same position. Most tuners on an N/A mostly stock car are only going to be tuning at larger throttle inputs, mostly focused on WOT.
Modifying a tune to remove some low rpm timing, or adding in more aggressive IAT based timing reduction doesn't take long at all.
You also have the option of driving differently... keep throttle application light if you're under ~3500-4000rpm and you shouldn't see this knock either. It's high load, large throttle, low rpm that does this. It's reproduceable in my car with a 91 octane tune (or stock tune), even in the dead of winter (low IAT's).
flickr
Old 07-08-2015, 10:08 AM   #21
D_Thissen
D_Thissen's Avatar
Like Will said, don't smash the throttle in high gears at low RPM, that should help with some of the knock. When I first picked up my OFT, I was on the diagnostics page and my IAM was 0.7.. On the stock OEM tune.
Old 07-08-2015, 03:58 PM   #22
Phantobe
Phantobe's Avatar
Drives: 14 Ultramarine FR-S
IAM of .70 is default for the stock tune, anytime you reflash to to OEM tune it will be .70 IAM.
2014 Ultramarine Scion FR-S
2000 Integra LS - SOLD
Phantobe is offline   Reply With Quote
Old 07-08-2015, 04:37 PM   #23
D_Thissen
D_Thissen's Avatar
Really? I didn't know that. Even if you bought a brand new car and ran the best 93 you could find, it would still be .7?
Old 07-08-2015, 05:33 PM   #24
wparsons
wparsons's Avatar
No, it defaults to 0.7. It can still climb higher. Shiv's tunes (and almost all others) default to 1.0 after a flash.
That said, mine defaults to 0 after a flash to the stock tune.
flickr
Old 07-08-2015, 05:42 PM   #25
Phantobe
Phantobe's Avatar
Its also worth pointing out it can & will go below 0.7.
Even on the stock tune on 91 I would get IAM as low as ~.4. Arguably an aftermarket tune with no knock might be safer than the stock tune, but who knows I know tuners argue about the IAM thing.
Basically let the ECU do its thing & correct the knock or tune it so you get no knock, afaik the latter will net more power. As IAM will be steady at 1.0.
Old 07-15-2015, 09:00 PM   #26
ronboogieon
BReeZy Hunter
ronboogieon's Avatar
Drives: 13 DGM BRZ Limited 6MT
Can temperature affect IAM? It's been 80F here and my IAM is stuck at 0.72-0.84. Yesterday it was 0.78 at 80F. Today it was 0.84 at 75F.
I'm on the Stage 1 91 tune on Chevron 92 gas. 2-3 fill ups ago I switched from E85 tune if that matters.
ronboogieon is offline   Reply With Quote
Old 07-15-2015, 10:14 PM   #27
JB86'd
JB86'd's Avatar
Drives: JAWS
Hotter temp = more potential for knock = lower IAM if it knocks
JB86'd is offline   Reply With Quote
Knock Correction vs Knock Correction Learn values? swift996 Software Tuning 19 11-03-2015 10:09 PM
FR-S Rod knock pozer Issues | Warranty | Recalls / TSB 95 11-03-2015 09:39 AM
Tip in knock? bmsi30 Issues | Warranty | Recalls / TSB 17 08-25-2014 04:12 PM
Header Knock 912matthews Engine, Exhaust, Transmission 3 04-26-2014 02:19 PM
ca-fi knock off questions fionnsfrs Electronics | Audio | NAV | Infotainment 2 10-27-2013 01:47 PM
