Old 07-06-2015, 03:16 PM   #2563
glamcem
glamcem's Avatar
Drives: 2022 BRZ Limited
Originally Posted by Xuningshen View Post
I bought this to make my life easier too... who needs a that much windshield washer fluid anyway....
http://www.ptuning.com/subdir/itemde...&ModelDesc=FRS
hmm this might be very useful. Since it didn't let me use the brake ducts (behind the fog lights), I couldn't use the reservoir that came with the KW kit, even though it was smaller than the OEM piece, this one looks even smaller than that..
Can you take a photo (looking directly) when you install it so that how much clearance left between that and the foglight? It says for FRS but I think it should be the same for BRZ as well
glamcem is offline   Reply With Quote
The Following User Says Thank You to glamcem For This Useful Post:
CSG Mike (07-06-2015)
Old 07-06-2015, 03:44 PM   #2564
Xuningshen
Drives: Subaru BRZ
yeah the way their website works it separates the brz and frs category. but its in both of them.
I plan on taking my bumper off this weekend so I can give you the measurement then? I don't know if you noticed that it sits underneath the bumper support arm. So there is plenty of room
2014 WRB BRZ
Xuningshen is offline   Reply With Quote
The Following User Says Thank You to Xuningshen For This Useful Post:
glamcem (07-06-2015)
Old 07-06-2015, 03:45 PM   #2565
Xiao Li
Xiao Li's Avatar
Drives: '14 BRZ, '01 S2K
You're in California; why did you decide to not get the CARB kit, even if it's only for the sticker?
I do have the CARB kit. Also I see you have both the oil coolers (engine/SC) mounted with the bracket on the bottom as opposed to the top of the support. Is that how it's made to be mounted? Like if I buy the oil cooler now and mount it after the kit is already installed, I'd have to relocate both oil coolers to the bottom?
Xiao Li is offline   Reply With Quote
The Following User Says Thank You to Xiao Li For This Useful Post:
Old 07-06-2015, 03:47 PM   #2566
Xiao Li
Xiao Li's Avatar
I'd like to see how it sits when mounted in place of the factory reservoir as well. Can you post pics once it's in?
Old 07-06-2015, 03:54 PM   #2567
CSG Mike
CSG Mike's Avatar
That is correct. If you did your own install, you won't have any issues relocating it.
Xiao Li (07-08-2015)
Old 07-06-2015, 05:57 PM   #2568
Xiao Li
Xiao Li's Avatar
Awesome, thanks! Expect a order from me in a few weeks.
Old 07-06-2015, 07:35 PM   #2569
Xuningshen
Drives: Subaru BRZ
I've had it installed for awhile. I'm just taking off my bumper for my general checkup I do every so often and I'll take pics then. it mounts under the driver side bumper "arm support" when the stock one mounts more towards the driver side of the arm.
2014 WRB BRZ
Old 07-07-2015, 02:17 AM   #2570
dkstylezz
dkstylezz's Avatar
Drives: 2013 Subaru BRZ
Does anyone know where i can purchase the Delicious Flash and go tune plus the 11psi map sensor in person tomorrow?
Im in SoCal
dkstylezz is offline   Reply With Quote
Old 07-07-2015, 03:18 AM   #2571
CSG Mike
CSG Mike's Avatar
Im in SoCal
@DeliciousTuning.
You're gonna need to drive to San Diego if you want it same day.
DeliciousTuning (07-08-2015), dkstylezz (07-07-2015)
Old 07-07-2015, 04:47 PM   #2572
Yoda
Drives: Crystal Black BRZ(Sophia)
Random question can the JRSC kit get close to 300whp on 93 gas?
I have seen 280whp from a few members but nothing really higher.
Yoda is offline   Reply With Quote
Old 07-07-2015, 07:49 PM   #2573
dkstylezz
dkstylezz's Avatar
@DeliciousTuning.
Thanks Took the trip down and got the tune and the 11psi map sensor. I can already feel the change while i was driving back home.
The Following 2 Users Say Thank You to dkstylezz For This Useful Post:
CSG Mike (07-07-2015), DeliciousTuning (07-08-2015)
Old 07-07-2015, 08:09 PM   #2574
CSG Mike
CSG Mike's Avatar
I suspect it's possible with the right supporting mods *cough* header/frontpipe
Old 07-07-2015, 08:23 PM   #2575
Yoda
Well then...I will keep that in mind
Old 07-08-2015, 01:32 PM   #2576
Xiao Li
Xiao Li's Avatar
As for exhaust, would anything pass the headers still be able to safely run the CARB tune? I know changing out the headers will most likely need a retune.
Jackson Racing Rotrex Supercharger System Info and Discussion Jackson Racing Forced Induction 827 04-06-2020 04:56 PM
Jackson Racing Supercharger Press Release and Info CounterSpace Garage Forced Induction 110 01-03-2017 09:04 PM
jackson Racing engine oil cooler - modular to fit the Jackson Racing Supercharger! CSG Mike Forced Induction 24 04-27-2016 12:59 PM
Jackson Racing supercharger NoppyNop Forced Induction 241 06-26-2014 03:05 PM
Jackson Racing Supercharger Pre-Order Sale, $200 off! Xero-Limit Forced Induction 2 03-05-2014 04:14 PM
