Old 06-24-2015, 04:25 PM   #113
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
Originally Posted by RBbugBITme View Post
Probably because they wanted to make sure everything from an inerter was contained inside the damper body.
I suppose. It's not really a 'damper' anymore if it only part of it is now a damper?!
Would you be able to generalize the range of effective mass, or coefficients, these inerters utilize in IndyCar racing? I understand in F1 the effective mass can be as high as 500 kg.
Hoosier Daddy is offline   Reply With Quote
Old 06-25-2015, 01:42 AM   #114
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Shock absorber dream team!
Old 06-25-2015, 04:53 AM   #115
ajc209
Drives: GT86 Cosworth
I have a feeling these shocks are gong to be:
[ame="https://www.youtube.com/watch?v=wyx6JDQCslE"]LMFAO - Sexy and I Know It - YouTube[/ame]
ajc209 is offline   Reply With Quote
Old 06-25-2015, 07:40 AM   #116
AZP Installs
AZP Installs's Avatar
Drives: '11 STi->'14 BRZ | '14 Touareg TDi
Send a message via AIM to AZP Installs
I hope folks embrace these dampers in the BRZ/FRS community.
Wish the cost would make them viable for our Spec86 Cup spec series but I fear they won't be viable for the target spec package price.
-mike
AZP Installs is offline   Reply With Quote
Old 06-25-2015, 09:27 AM   #117
WHITE
Thats pretty neat
WHITE's Avatar
Drives: LOADING......
Subbed. Have to say I'm really excited about this. You will have at least one buyer right here.
WHITE is offline   Reply With Quote
The Following 3 Users Say Thank You to WHITE For This Useful Post:
Deep Six (08-27-2015), Raceseng (07-02-2015), RBbugBITme (06-25-2015)
Old 07-04-2015, 12:56 AM   #118
cookiesowns
Drives: WRB BRZ Series.Blue
So when is this coming out?
cookiesowns is offline   Reply With Quote
Old 07-04-2015, 02:15 AM   #119
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
silly question, havent searched it yet; whats an inerter?
Old 07-04-2015, 05:27 PM   #120
Hoosier Daddy
Springs are displacement depended, dampers are velocity depended and inerters are acceleration depended. Inerters add effective mass to a body by adding an extra component of inertia, for very little added weight, which in turn dynamically reacts to suspension forces. Either a dense fluid or a mechanical metal flywheel is displaced or spun which has some amount of inertia based on its configuration. Their purpose is to cancel out or reduce disturbances which when tuned correctly allow tire patch contact to stay loaded to the road surface better and improve grip. That's how it does it. Now how that's supposed to feels to a driver? I have no idea.
I use the term tuned because a mass chosen will have a reaction exactly proportional 180 degrees out of phase with only one discreet input force completely cancelling out the dynamic force variation of that particular force. Any other input force will have different results with that same inertial mass. It will need to be tuned to best reduce the tire force variations throughout the different corners of a circuit.
Simplistically the math looks like this for spring, damper and inerter elements:
Spring Force = k(d1 - d0)
Force (N)
k - spring rate (N/m)
d1 - displacement on one side (m)
d0 - displacement on the other side (m)
Damping Force = c(v1 - v0)
Force (N)
c - damping coefficient (N*s/m)
v1 - velocity on one side (m/s)
v0 - velocity on the other side (m/s)
v = dd/dt
Inertance Force = b(a1 - a0)
Force (N)
b - inertance (N*s^2/m or kg)
a1 - acceleration on one side (m/s^2)
a0 - acceleration on the other side (m/s^2)
a = dv/dt
On corner inerters or typical 3rd inerters d0, v0, a0 can be assumed to be zero as only one end moves, the end connected to the upright, control arm, pushrod or pullrod. On 'heave' springs (3rd springs that connect to each other and not the chassis) d0, v0 and a0 could be non-zero.
I might have worked with these things before... Admittedly not Penske versions nor in IndyCar. Lol
The Following 11 Users Say Thank You to Hoosier Daddy For This Useful Post:
BatStig (07-04-2015), Calum (07-04-2015), Canehda (07-04-2015), cdrazic93 (07-04-2015), CSG Mike (07-04-2015), DAEMANO (07-24-2015), fstlane (07-04-2015), SkiRideDrive (08-28-2015), strat61caster (07-08-2015), Wepeel (08-31-2015), wparsons (07-04-2015)
Old 07-04-2015, 06:32 PM   #121
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I always thought spring force was (1/2)kx^2, formalities. I kind of get it.
Old 07-04-2015, 08:41 PM   #122
donoman
donoman's Avatar
Drives: '13 FR-S
That's spring energy.
donoman is offline   Reply With Quote
Old 07-04-2015, 08:56 PM   #123
RBbugBITme
Drives: S60R/Corvette
Hoosier daddy got fairly detailed and there really isn't anything wrong with what he said.
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
The Following 8 Users Say Thank You to RBbugBITme For This Useful Post:
Calum (07-05-2015), cdrazic93 (07-04-2015), CSG Mike (07-04-2015), drewbot (07-24-2015), EAGLE5 (07-04-2015), SkiRideDrive (08-28-2015), Turdinator (07-07-2015), wparsons (07-24-2015)
Old 07-04-2015, 10:03 PM   #124
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
I looked up some pictures and apparently these J dampers i have run across before i think i would understand it better in a visual demonstration. Although it sounds to me like it takes the rotational mass of the car and absorbs it.
Old 07-04-2015, 10:27 PM   #125
RBbugBITme
I was going to say you'd have better luck googling "penske inerter" because j-damper was a secret code name but apparently there still isn't that much info on the net about them.
I haven't seen anything that looks like the stuff we're actually doing right now.
Ryan M.
Strange Engineering
Old 07-04-2015, 10:32 PM   #126
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
The only penske inerter i was able to find was a drag shock
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 10:22 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
Ultimate Racing Exhaust help psyclone07 Engine, Exhaust, Transmission 0 07-06-2014 11:05 PM
Ultimate Racing, quality? rhythmM Engine, Exhaust, Transmission 5 11-30-2013 05:46 PM
