Old 06-20-2015, 03:08 AM   #29
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by aagun View Post
what about DI system its look like deleted
Oh no I won't get rid of DI!!!! It just wasn't installed yet
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
The Following 2 Users Say Thank You to FRS Justin For This Useful Post:
Kris86 (03-15-2016), raven1231 (06-22-2015)
Old 06-22-2015, 04:22 AM   #30
FRS Justin
started the engine and trans swap
started the engine and clutch swap
710whp
Old 06-22-2015, 11:11 AM   #31
FRS Justin
Originally Posted by NotSoJDM View Post
Did you get the oil pump gears coated with something from WPC?
Are you using stock cams?
Yes the pump gears are WPC treated so are the rings, bearings, crank, and pistons. WPC is not a coating it's a surface treatment that reduces friction. Kind of like a glass beading check out the you tube
[ame="https://www.youtube.com/watch?v=jSiC7D8patU"]WPC Metal Surface Treatment Demo #1 of 2 - YouTube[/ame]
[ame="https://www.youtube.com/watch?v=VvKH-BYQcoM"]WPC Metal Surface Treatment Demo #2 of 2 - YouTube[/ame]
The cams are stock in this one I want to see how much we can push out of this configuration.
710whp
The Following 4 Users Say Thank You to FRS Justin For This Useful Post:
Kris86 (03-15-2016), NotSoJDM (06-22-2015), Valentino (07-03-2015), whataboutbob (03-02-2016)
Old 06-22-2015, 05:34 PM   #32
FRS Justin
Vacuum manifold
Look what Spencer Fabrication built just for us, the most AWESOME vacuum block!!!!!
710whp
DustinS (06-24-2015), Kris86 (03-15-2016), mrk1 (06-22-2015), raven1231 (07-29-2015)
Old 06-24-2015, 11:06 AM   #33
Fiebruz Motorsports
Fiebruz Motorsports's Avatar
Drives: 2013 RB Turbo FRS, 2013 N/A FRS
Nice! Build!
Subscribed!
Fiebruz Motorsports is offline   Reply With Quote
The Following 3 Users Say Thank You to Fiebruz Motorsports For This Useful Post:
FRS Justin (06-24-2015), Kris86 (03-15-2016), raven1231 (07-29-2015)
Old 07-03-2015, 03:02 PM   #34
FRS Justin
Yes stock cams and yes the pump gears are treated with WPC
710whp
Old 07-04-2015, 10:19 AM   #35
SnapOv3st3r
Drives: 400whp Scion tC
What trans did you swap in?
SnapOv3st3r is offline   Reply With Quote
Old 07-04-2015, 10:37 AM   #36
Summerwolf
Panda Trueno
Summerwolf's Avatar
Drives: No twin now.
Wow, now THIS is a build thread!
The Following 3 Users Say Thank You to Summerwolf For This Useful Post:
DAEMANO (08-08-2015), FRS Justin (07-05-2015), Kris86 (03-15-2016)
Old 07-05-2015, 04:45 AM   #37
FRS Justin
Its the factory trans looking at other options undecided at this time
710whp
The Following User Says Thank You to FRS Justin For This Useful Post:
SnapOv3st3r (07-27-2015)
Old 07-28-2015, 10:07 PM   #38
Mathewgzlz
Mathewgzlz's Avatar
Drives: 2013 SCION FR-S FIRESTORM RED
i need more lol
Mathewgzlz is offline   Reply With Quote
Old 07-29-2015, 05:00 AM   #39
wnt3d
wnt3d's Avatar
Drives: Toyota GT86
Very nice build mate! definitely keeping track of this build and taking notes on how you built your motor.
subscribed!
wnt3d is offline   Reply With Quote
Old 07-29-2015, 06:55 AM   #40
raven1231
Looking forward to seeing updates! Love the build
Old 07-29-2015, 12:39 PM   #41
Top-Secret
Drives: FRS monogram
mind blowing amount of awesomeness going on here. keep up the good work
Top-Secret is offline   Reply With Quote
Old 08-05-2015, 11:55 AM   #42
motoxman
motoxman's Avatar
Drives: 2013 fr-s firestorm red
Yep, I'm Jealous... Just sayin... Great build so far! Hope to see more progress soon! Oh, if you go into the stock transmission and brace up the gear rail bosses around the bearing plates the transmission should hold significantly more power. This is how we made our Getrag 6spd Transmissions in the 3000GT VR4's hold 900+ horse power. Kept the gears from separating the transmission halves... Found this out after I destroyed my first transmission on a hard launch at 28lbs on twin 19t turbos... $400 worth of bracing the internals would have saved me a $5800 transmission... SMH!
motoxman is offline   Reply With Quote
