Old 06-28-2015, 01:05 AM   #43
brady86
Drives: 2013 firestorm fr-s
Loving this kit makes me want to pick it up over a sbd turbo kit just trying to get over the fact that it makes less power for more money. I do like the idea of a supercharger vs turbo though I'm also wondering if you could change the blow off valve on this kit to give people the sound they seem to want.
brady86 is offline   Reply With Quote
Old 06-30-2015, 02:05 PM   #44
aruxe
I planning to do GT supercharger in my BRZ this year.
Wondering what's the main different between the Ver. 1 and Ver. 2?
Because I see the Ver. 2's price has drop quite a bit and less piping.
aruxe is offline   Reply With Quote
Old 06-30-2015, 02:26 PM   #45
HKSUSA
HKSUSA's Avatar
Drives: HKS
The new version uses a larger intercooler and optional fuel injectors.
HKSUSA is offline   Reply With Quote
Old 07-03-2015, 11:29 AM   #46
FRSCanuck
Drives: Scion FRS
thought i share my dyno.
HKS V2 with fuel injector upgrade. Running TRD air filter with Tomei header, overpipe, front pipe, and Greddy CS GTS V2 catback tuned by ECUtek. the restrictor plate is slightly bored out.
FRSCanuck is offline   Reply With Quote
Old 07-04-2015, 08:16 PM   #47
wbradley
Sarcastic SOB
wbradley's Avatar
Excellent numbers. Car must be super fast 40 km/h and up.
Standard pulley?
How much did you bore the restrictor and how did you decide the amount?
Is it much work/cost for a mechanic to do the injectors? I have Deatchwerks 700c that aren't yet installed.
Did the tuner come to do the work at the mechanics shop?
Is your tune speed density calibrated?
Do you/will you install a wideband?
Old 07-04-2015, 10:36 PM   #48
FRSCanuck
Drives: Scion FRS
Standard pulley?
it is pure happiness past 40km/h
yes! standard pulley! the restrictor plate is bored about 4mm. Injectors didn't cost a lot, but i had the shop do a lot of other work as well. The tuner came to the shop to tune. I installed the innovate SCG-1 as well.
cheers,
Kelvin
Old 07-05-2015, 12:57 PM   #49
10Stars
Drives: 14 Subaru BRZ Limited WRB
UEL or EL?
10Stars is offline   Reply With Quote
Old 07-05-2015, 01:28 PM   #50
FRSCanuck
Drives: Scion FRS
Originally Posted by 10Stars View Post
UEL or EL?
Equal length
Old 07-05-2015, 01:49 PM   #51
10Stars
Equal length
Forgot to ask, was your dyno on 91?
From what I understand the "Fuel Upgrade kit" comes with injectors and a bigger restrictor plate (43mm)? How much cc is the Hks Injectors?
I'm hoping Hks sells the restrictor separately as I might just go with different injectors instead.
Old 07-05-2015, 02:54 PM   #52
brady86
13 psi seems like a lot of boost on the stock engine and i am surprised you didnt make well into the 300s with that much boost unless its a mustang dyno.
Old 07-06-2015, 10:47 AM   #53
FRSCanuck
Drives: Scion FRS
nope, i used 94 octane. not 100% sure on the injector size, i'll have to double-check when i get home but the restrictor plate is 43mm compared to the 39mm one in the V1 kit
i agree, i thought it was a lot of boost as well, but the tuner has done several HKS kits before on the FRS and said it was safe for a daily.
Old 07-06-2015, 12:00 PM   #54
brady86
have you timed a 0-60 or 1/4 with this set up and was it a mustang dyno? @FRSCanuck and it could be okay i would just be worried about how long the stock engine would last i want to last at least two years of good use when im supercharged/turbo before i need a rebuild lol.
Old 07-08-2015, 07:13 AM   #55
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
I know i couldn't use this for track use but for a daily driver would this work with the HKS v2 supercharger kit?
http://www.ft86club.com/forums/showthread.php?t=50427
I'm curious why more people don't run this kit, its similar in price to the Kraftwerks which breaks belts so why don't more use this? Lack of support in the US maybe?
I would like to run it but also considering the Jackson Racing or maybe the Edelbrock depending on numbers and price.
Old 07-08-2015, 08:38 AM   #56
brady86
I would just get a real oil cooler to be safe no point in cheaping out on safety for your cars engine health lol. And I too am wondering why less people run this set up for me its between this the vortech and the Jackson kit still trying to figure out what's the best power and reliability wise.
Kraftwerks Supercharger Owners Thread projek_01 Forced Induction 4310 04-07-2025 01:12 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
Five Axis Edition FR-S Owners Thread digital_assassin FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 563 07-08-2015 09:22 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
Supra Owners Build Thread BoostJunkie Other Vehicles & General Automotive Discussions 164 03-12-2012 09:37 AM
