Old 07-02-2015, 12:39 PM   #15
Tectoniic
#FiftyShadesOfBlue
Tectoniic's Avatar
Drives: 2015 FR-S
Corn Juice
Engine/Exhaust: OFT w/ E85 Tune | FT86SF Catted UEL | Invidia Q300 Catback
Wheels/Tires/Suspension: Avid.1 AV-20 18x8.5 +33 w/ 245/35/18 PSS | RCE Yellow Springs | Velox LCAs
Cosmetic: Valenti FT86SF Special Edition Tails | Diode Dynamics Full HID/LEDs | BRZ Fender Garnishes
Tectoniic is offline   Reply With Quote
Old 07-02-2015, 12:47 PM   #16
jawn
jawn's Avatar
Drives: 2015 CWP BRZ Limited
I would also get some way of reading oil temperatures and pressure, if you think that's the culprit. It'd be putting the cart ahead of the horse to install an oil cooler without actually knowing what your oil temperatures are.
In lieu of dedicated gauges, any number of the Bluetooth OBDII readers and the Torque app will let you see what's going on for under 30 dollars.
jawn is offline   Reply With Quote
Old 07-02-2015, 12:55 PM   #17
scottxnizzle
scottxnizzle's Avatar
Drives: WRB BRZ
decals, definitely decals.
scottxnizzle is offline   Reply With Quote
Old 07-02-2015, 12:58 PM   #18
jawn
jawn's Avatar
+5 HP and mad street cred
Old 07-02-2015, 01:09 PM   #19
STV3
Seρor Member
STV3's Avatar
LS swap /thread
STV3 is offline   Reply With Quote
Old 07-02-2015, 05:58 PM   #20
mixxxx
mixxxx's Avatar
Always upgrade the weakest component first:
1) Driver Mod: Track days, AutoX, Seat Time, etc.
2) Alignment
3) Brakes
4) Tires
it's amazing what a simple alignment in these cars can do. especially on the brz.
a lot of these non-aesthetic mods can really do wonders.
mixxxx is offline   Reply With Quote
The Following User Says Thank You to mixxxx For This Useful Post:
strat61caster (07-02-2015)
Old 07-02-2015, 07:11 PM   #21
extrashaky
Drives: 2014 BRZ Limited
Just to clarify this, Torque will give you oil temperature, but not pressure. The car has an oil temp sensor, and Torque will read the temp. But for pressure the car only comes with a pressure switch that turns on the idiot light at some ridiculously low psi and will not give you an actual pressure reading. You have to install an aftermarket oil pressure sender and separate gauge to get oil pressure in psi.
I run Torque almost all the time with a first gen Galaxy Note phone set up as a dedicated engine computer. I have water temp and oil temp gauges set up on it side by side. It usually stays below 220° unless I drive with the RPM up above 4K or 5K for an extended period of time. I seriously doubt any of us really need an oil cooler if we're not tracking the car.
The Following 2 Users Say Thank You to extrashaky For This Useful Post:
jawn (07-02-2015), Tcoat (07-02-2015)
Old 07-02-2015, 07:37 PM   #22
jawn
jawn's Avatar
You are correct. Brain fart.
Old 07-02-2015, 11:51 PM   #23
soundman414
Drives: 2014 Silver BRZ Limited
Cool. Thanks for the suggestions. I like the idea of the BT ODBII reader for reading stats.
I'm saving for blizzaks now. TSW wheels and Michelin PSS, along with DBA rotors, Motul 600/660, SS lines all next year... Just started my job here in the D.
I'll probably do redstuff pads and a master cylinder brace this year since it's not too expensive.
As for bone stock tunes/flasher systems that are flexible enough to have stepped and reliable tunes as you add things like air intake, catless header, etc.; what do you guys recommend?
soundman414 is offline   Reply With Quote
Old 07-03-2015, 05:03 AM   #24
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Do it slow, learn the car. & add things that you feel it's lacking on track 1by1
Brake pad is a very good start.
The Following User Says Thank You to chaoskaze For This Useful Post:
strat61caster (07-03-2015)
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 10:23 PM
Excelerate Performance: Your Northeast Performance and Installation Center ExcelerateRep NY / NJ / CT / PA 40 07-22-2014 06:55 PM
