Old 07-01-2015, 11:33 PM   #1
soundman414
Drives: 2014 Silver BRZ Limited
My first performance mod?
So I am looking into my first mod for my new BRZ.
The thing I have been noticing is that even on very small spirited rides, it gets a bit tuckered out... I am at a loss of words on how best to explain it quickly. But it doesn't shift as quickly, accelerate as quickly, feel as zippy.
So with a ton of talk of engine oil temps being the culprit of many issues, I am wondering if my first mod should be an oil cooler?
More specifically a Cusco since I am living in Detroit and will be driving the BRZ in the winter.
Other thoughts?
soundman414 is offline   Reply With Quote
Old 07-01-2015, 11:41 PM   #2
JS + BRZ
Drives: 2010 MS3
The answer is always tires.
The Following 4 Users Say Thank You to JS + BRZ For This Useful Post:
hmong337 (07-02-2015), Leonardo (07-02-2015), mixxxx (07-02-2015), Special_K (07-02-2015)
Old 07-02-2015, 12:04 AM   #3
Sammakko
Bilge monkey
Sammakko's Avatar
Drives: '13 BRZ, 82 starlet
1. get rid of those hideous wheels.
2. put good tires on the new wheels.
3. OFT and E85
Sammakko is offline   Reply With Quote
The Following User Says Thank You to Sammakko For This Useful Post:
FloridaBRZ (07-02-2015)
Old 07-02-2015, 12:17 AM   #4
mixxxx
mixxxx's Avatar
+1. But burn thru your stock set first. Those tires are a lot of fun.
Also, there's an 86 driving academy coming this month, a worthwile investment. I know this is not a mechanical part. But 'you' are still part of the car
https://www.facebook.com/86DDA?fref=ts
mixxxx is offline   Reply With Quote
The Following 2 Users Say Thank You to mixxxx For This Useful Post:
Frogamazog (07-02-2015), JS + BRZ (07-02-2015)
Old 07-02-2015, 12:24 AM   #5
zigzagz94
BRZerhood Lurker #13
zigzagz94's Avatar
Drives: 15 DGM BRZ Premium
1) Driver Mod: Track days, AutoX, Seat Time, etc.
2) Tires
3) E85 and Tune
Yesterday is history. Tomorrow is a mystery. Today is a gift and that's why it's called the present.
zigzagz94 is offline   Reply With Quote
The Following 2 Users Say Thank You to zigzagz94 For This Useful Post:
JS + BRZ (07-02-2015), mixxxx (07-02-2015)
Old 07-02-2015, 01:02 AM   #6
Cal3000
Drives: Panda FR-S
The only answer is Forced Induction.
Vortech SC on 9psi Pulley, Invidia Catless Front Pipe, Invidia N1 Catback Exhaust
242whp/197ft-lb on Mustang Dyno (91 octane water)
284whp/223ft-lb on Mustang Dyno (E85)
Cal3000 is offline   Reply With Quote
The Following User Says Thank You to Cal3000 For This Useful Post:
Old 07-02-2015, 01:32 AM   #7
Poodles
Drives: 2015 Series.Blue
The OEM tires have a mileage warranty on them...wear them out and have the money put towards MPSS's
But that's not really what the OP was asking since it sounds like he's got an auto and it's not being as aggressive while hot.
Old 07-02-2015, 01:41 AM   #8
strat61caster
strat61caster's Avatar
Drives: '13 FRS - STX
Always upgrade the weakest component first:
2) Alignment
3) Brakes
4) Tires
ineedyourdiddly
Old 07-02-2015, 01:44 AM   #9
ray7792
ray7792's Avatar
Drives: AT 2013 BRZ Limited
I really doubt it would be an issue with the oil temps if you are just doing some spirited driving on public roads, but I could be wrong...
I'd get a tune first, it makes the most difference and is the best bang for the buck. Just use the OEMs until winter hits, get winter tires and then come next spring get sticker tires and maybe wheels at the same time? unless you have another car for winter then meh.
As someone mentioned, the OEMs have just enough grip to be fun, not to mention good MPG. They are good enough to learn on.
My 2 cents
Good luck!
'13 BRZ (sold)
'17 STI
ray7792 is offline   Reply With Quote
Old 07-02-2015, 01:46 AM   #10
mixxxx
mixxxx's Avatar
OT: for the mileage warranty, do you just complain to the dealer?
Old 07-02-2015, 02:18 AM   #11
lithiumion
Drives: 5555
I suggest long travel rally suspension for Michigan roads
lithiumion is offline   Reply With Quote
Old 07-02-2015, 02:35 AM   #12
Fastbrew
Drives: 2014 Pearl White BRZ
Seafoam.
If you don't buy that, throw in a K/N and a Perrin inlet hose. You will feel like you are faster. Don't bother with an oil cooler.
In short - just go FI + e85/flex fuel.
Fastbrew is offline   Reply With Quote
Old 07-02-2015, 10:32 AM   #13
fika84
fika84's Avatar
Don't listen to anybody and do what you feel you need/want to do to the car first!
fika84 is offline   Reply With Quote
The Following 2 Users Say Thank You to fika84 For This Useful Post:
soulreapersteve (07-03-2015), strat61caster (07-02-2015)
Old 07-02-2015, 12:11 PM   #14
PNW-BRZ
PNW-BRZ's Avatar
Drives: 2015 Limited
Personally, unless your really driving this hard an Oil Cooler won't make much of a difference. It will even be cooling the oil when your not driving the car hard and in the winter which can have other issues. Tuning is where I'd start, optimize it for what you have and see if you can log what's happening when the car is acting "less spirited" and take it from there.
PNW-BRZ is offline   Reply With Quote
all season high performance or winter performance tires? Aloxi NY / NJ / CT / PA 29 03-24-2015 10:23 PM
Excelerate Performance: Your Northeast Performance and Installation Center ExcelerateRep NY / NJ / CT / PA 40 07-22-2014 06:55 PM
