Old 06-20-2015, 11:26 PM   #1611
markw
Drives: 2014 FR-S
Originally Posted by trippinbillies40 View Post
Who wants to take a few minutes to help me figure out where to start shaving weight? Muffler will be gone with a track pipe for now, obviously spare tire, tools, and rear trunk carpet. Floor mats, cup holder, empty the glove box...
Am I missing any other freebies? I know the battery is a huge saver, just trying to make sure all of the free stuff is out before I start spending money. Thanks y'all!
Are you under or overweight? Myself, I could stand to loose about 60lbs, that is free weight. Just need to get motivated to do it. Easier to shave weight with parts...
markw is offline   Reply With Quote
Old 06-21-2015, 12:35 AM   #1612
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I'm about 40lbs heavier than I was 2 seasons ago. So either I need a faster car or to get back to the gym.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
tahdizzle (06-29-2015)
Old 06-21-2015, 08:50 PM   #1613
FRS Johnny
FRS Johnny's Avatar
Drives: 2013 FR-S Whiteout MT
Originally Posted by RedBRZ80 View Post
You basically get dumped into SM. Maybe use the 18x9.5 for street and pick up some 17x9s for autocross?
Don't really want to spend more money on wheels and tires. I'd rather just use one. I mean I'm not trying to set the fastest times or anything. Just looking to have fun. Plus autox won't be the only driving I do so I think it should be ok if I just go to the practice events for fun.
When in doubt, throttle out!
FRS Johnny is offline   Reply With Quote
Old 06-22-2015, 10:43 AM   #1614
markw
Drives: 2014 FR-S
If you're just doing practices, car classing doesn't matter. It's when you show up, enter into a class and then beat people that they start caring. If you're just going for seat time you'll be fine. When you get serious, then get some lightweight wheels and good rubber for autocross.
Mark
The Following 2 Users Say Thank You to markw For This Useful Post:
EN2_Squirrel (06-22-2015), FRS Johnny (06-22-2015)
Old 06-28-2015, 02:25 PM   #1615
sweetspeed
sweetspeed's Avatar
Drives: 2014 Raven Black FR-S
does this rule out an aftermarket racing steering wheel minus the airbag?
sweetspeed is offline   Reply With Quote
Old 06-28-2015, 05:14 PM   #1616
cjd
cjd's Avatar
Drives: 2017 BRZ
In STX? yes.
Old 06-29-2015, 12:05 PM   #1617
RTR
Drives: monogram raven
So this wknd we had a 2 day event. We have a former national champ solo driver in my region and what did he show up in, his new 10 series. Saturday was his first autocross in the car and thankfully he wasn't in stx bc all he's had time to do is swap wheels and tires. Rpf1s and star specs, BUT they were stock size. All day Sat he's beating my times by close to 10 seconds and yesterday it was around 5-6 seconds. Only posting to reinforce the fact that driver mod is the best mod. My plan? Beg him to co-drive a few events!
RTR is offline   Reply With Quote
Old 06-29-2015, 02:28 PM   #1618
cjd
cjd's Avatar
Drives: 2017 BRZ
I've yet to find a past champ that isn't thrilled to ride and help. I doubt you'll have to beg, just ask nicely.
The Following User Says Thank You to cjd For This Useful Post:
RTR (06-29-2015)
Old 06-29-2015, 11:26 PM   #1619
48Spoons
Drives: Ultramarine FR-S
Has anyone raised their rev limit to get a few more MPH in 2nd? If so what has been found to be a safe amount to raise it if any? Thanks.
48Spoons is offline   Reply With Quote
Old 06-30-2015, 12:40 AM   #1620
FastWhite
Drives: Subaru BRZ Limited M/T
I've gone up to 7800. No issues so far. Most of the local courses here are pretty tight, usually don't get up to 7800. Although the last course was so tight you could stay in first for the first half of the course. There I hit the rev limit. The nice soft limit.
FastWhite is offline   Reply With Quote
Old 06-30-2015, 05:57 AM   #1621
BlaineWasHere
Grip>Drift
Drives: FRS
The courses I run these days use a lot of third gear so I'm shifting anyway so I don't know if I need the revs.
I would not want to run a AutoX stuck in first or not even fast enough to top out 2nd. Eww.
Old 06-30-2015, 02:36 PM   #1622
FastWhite
Oh we can still, come close, to topping out in 2nd. One of those driver skill things. This course was more technical than most. Some were still hitting third in the the slalom. The top car time, was an ASP 911. He had a tall first gear and it worked great for him on this course. Hoosiers of course. It had a LOT of transitions and tight sections that kept the corner workers very busy.
Lot of fun
Old 06-30-2015, 10:27 PM   #1623
BlaineWasHere
Grip>Drift
Drives: FRS
One skill I've been working really hard to get better at is my 2-3 and 3-2 shifts because every national level course I've run is to fast at some or multiple points for 2nd gear. It's been paying off so far.
Old 06-30-2015, 10:36 PM   #1624
FastWhite
Practice makes perfect. I have the AT, so shifting is easy, BUT, this is the only spot I have issue with the AT. It would be better I think to have the paddles fixed on the column. Plus you have to hit 4000 rpm BEFORE you are able to downshift. So until you can master this skill, you end up slowing down too much. If you hit it right on, you can gain a half a second. Shifting 2-3-2 is easy, 2-1 is what needs to mastered, for me.
Otherwise I do good. And I have fun.
Heel/toe technique helps immensely. I bought pedal covers so I could set up for heel/toe. It worked.
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? PatrickSAN Electronics | Audio | NAV | Infotainment 22 11-14-2012 03:12 PM
SCCA sway bar rules gmookher Suspension | Chassis | Brakes -- Sponsored by 949 Racing 0 09-01-2012 07:48 PM
Suggestion for vendor rules... Tainen Site Announcements / Questions / Issues 31 08-15-2012 02:53 PM
Rules for posting in this section Hachiroku User/Vendor/Sponsor Reviews, Feedback, Comments 0 06-25-2012 12:02 PM
