Old 06-29-2015, 12:04 PM   #43
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
https://www.facebook.com/subaristlov...43875818965355
New announcement coming June 30th, 2015.
Will update once i know wut is it O.o..
The Following User Says Thank You to chaoskaze For This Useful Post:
Createddeleted (06-29-2015)
Old 06-29-2015, 10:36 PM   #44
DSOmegaX
DSOmegaX's Avatar
Its out and just a new revision on the tS. Retuned bilstein dampers (already were available), but new front strut bars. Looks like stiffening or reinforcement in the unibody? Exterior additions are the fender trim in black, red stripes front and rear, and a black trim accent by the led lights in front. Also a trunk lip spoiler that again was already available. Interior is just a new color scheme.
@dsomegax.cars
Old 06-29-2015, 11:23 PM   #45
chaoskaze
The Fail Boat
chaoskaze's Avatar
Drives: CWP S.B.
Like DSOmegaX said! New tS is available for preorder! (only 300 will be build)
Only 100 in yellow, the other 200 have the choice of WRB/CPW/CBS.
http://www.sti.jp/product/brzts2015/index.html
http://www.sti.jp/product/brzts2015/...equipment.html
^ Check this for the stuff on 2015 tS. Last one is Extra insulation on front, rear wheel wall section, door & trunk & It seems they modify the tS only VDC a bit.
Sideway accleration/yaw change graph on corner
Just more refinement I guess, They said they also change the seat?
Interior noise graph
Interior Page
http://www.sti.jp/product/brzts2015/interior_seat.html
Exterior Page
I noticed more useless part for me that I need to get.... XD
The Following 2 Users Say Thank You to chaoskaze For This Useful Post:
Createddeleted (06-30-2015), kuczynskika (06-30-2015)
Old 06-30-2015, 01:47 AM   #46
spicyricecake
spicyricecake's Avatar
Drives: 2017 CWP BRZ Performance Package
that interior is sex...
spicyricecake is offline   Reply With Quote
The Following 3 Users Say Thank You to spicyricecake For This Useful Post:
Jfheisenberg (07-01-2015), KidRed (07-01-2015), meWant (06-30-2015)
Old 06-30-2015, 02:31 AM   #47
kuczynskika
kuczynskika's Avatar
Drives: Harrop TVS86 STi BRZ tS
revised bilsteins, v-bar, draw stiffeners and sound deadening seem like the most interesting new components, otherwise...
kuczynskika is offline   Reply With Quote
Old 06-30-2015, 02:49 AM   #48
SPCorBUST
SPCorBUST's Avatar
I want those brakes. And those seats. Ugh.
Setup 3: JR C30, DW 700, Grams 265, 3bar, FlexFuel, Moto-East
Setup 4: JR C30 HBP, DW 700, Grams 265, 3bar, FlexFuel, Church
Setup 5: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Built Motor
Setup 6: JR C30 HBP, DW 700, DW 300, 3bar, FlexFuel, Delicious, Closed Deck Built Motor
SPCorBUST is offline   Reply With Quote
Old 06-30-2015, 07:36 AM   #49
krayzie
Drive From Home
krayzie's Avatar
Drives: BRZ STI Performance
Dammit STI I just ordered the Bilstein damper kit now I need new flexible V bar too?!?
krayzie is offline   Reply With Quote
Old 06-30-2015, 10:10 AM   #50
cslntuee
Drives: Subaru BRZ Limited
Did you also have or plan to have flexible draw stiffener together?
Thanks.
cslntuee is offline   Reply With Quote
Old 06-30-2015, 10:34 AM   #51
cslntuee
Did draw stiffeners also different than previous version?
http://www.sti.jp/parts/catalogue/br...0118AS000.html
Thanks.
Old 06-30-2015, 10:56 AM   #52
Ouhei
Ouhei's Avatar
Drives: '14 SWP BRZ Limited
Glad they ditched the weird grey color scheme on the interior. Digging the front pin striping too, guess I'll have to order some new parts!
Ouhei is offline   Reply With Quote
Old 06-30-2015, 11:57 AM   #53
krayzie
Drive From Home
krayzie's Avatar
Thanks.
I've always had both the flexible tower bar and the flexible draw stiffeners installed. If they are revising the draw stiffeners too then I wouldn't replace the tower bar with the new V-bars (the draw stiffeners are not cheap).
The only thing I can see them revising on the draw stiffeners are the springs inside. However, I would think they should be the same on this new setup and no need for a revision.
I'm also wary on switching the V-bars, as those bolts are known to strip easy. Once they are stripped your chassis is pretty much done for.
Another train of thought is that; if they are revising all these gear, how would that translate to tire selection? Would the new setup require tires with more grip?
I ordered the damper kit seeing how it is now on the STI Performance catalog and says it is compatible with the non-tS setup. I can really use more shock travel on these crappy Toronto roads.
The Following User Says Thank You to krayzie For This Useful Post:
cslntuee (06-30-2015)
Old 06-30-2015, 12:17 PM   #54
Kostamojen
I just want those seats damnit...
Old 06-30-2015, 12:30 PM   #55
kuczynskika
Thanks.
No, I don't think the draw stiffener design has changed from what's already been offered. Only the bilstein did, prolly not even that noticeable of a difference too.
Old 06-30-2015, 11:06 PM   #56
DSOmegaX
DSOmegaX's Avatar
Here's one in the wild
@dsomegax.cars
The Following 3 Users Say Thank You to DSOmegaX For This Useful Post:
chaoskaze (07-01-2015), kuczynskika (07-01-2015), ybotspawn (06-30-2015)
** TRD JAPAN GT-86 PARTS LIST ** Carson Toyota Exterior Parts - The Rest 222 08-28-2014 01:43 PM
I wish list of parts for my FRS jflogerzi Scion FR-S / Toyota 86 GT86 General Forum 19 04-28-2013 10:55 PM
R Magic Parts List quik1987 Engine, Exhaust, Transmission 9 07-30-2012 01:55 PM
List of all parts you want on your BRZ/86 StarsGarrador BRZ First-Gen (2012+) — General Topics 72 05-22-2012 05:20 PM
Lexus IS-F parts wish list aspera Engine, Exhaust, Transmission 21 08-18-2011 01:59 PM
