Old 06-25-2015, 01:43 AM   #15
FRS Justin
Drives: 2013 Asphalt FRS
Originally Posted by Dream20b View Post
Okay, So I did some passes at the strip last Saturday and i'm hitting the rev limiter before attempting to shift into 5th.
Current:
Manual Transmission
Unknown Horsepower. estimating 260-270 RWHP
Bridgestone Turanza El400 Hockey Pucks.
Relevant info:
Factory suspension settings
2013 FRS
Sprintex 210 Supercharger
Tomei Equal Length Headers
E85
70mm Pulley (~11 PSI)
Stock Gearing
215/45/17 tires resulting in a 24.6" tire diameter
7450 RPM rev limit
topping out at 12.9 at 105-106 MPH in 4th gear riding out the top 50 feet or so on the limiter
Due to the limiter I have a choice of attempting to shift to 5th or riding the limiter. 5th gear is impossible to shift into within 50 feet at 105 mph.
The easiest change is to increase the rev limiter to 7800:
Proposed changes option 1:
7800 RPM rev limit
top speed in 4th around 114 or 115
Since my tires are nearing the end of their useful life, I may be interested in changing rear wheels to 17x7.5 and tires to stickier street tires sized at 245/45/17 tires resulting in the following:
Proposed changes option 2:
7800 RPM Rev limiter
245/45/17 tires for a 25.7" tire diameter
top speed in 4th around 119 or 120
The last option is 17x8 wheels and tires with stickier street tires sized at 265/45/17 tires resulting in the following:
Proposed changes option 3:
265/45/16 tires for a 25.4" tire diameter
top speed in 4th around 118 or 119, still simple
I probably put way too much thought in for a tenth or two, but every tenth counts in drag racing.
Anyway, Which setup makes the most sense realistically, not necessarily monetarily?
Option 4: Weir performance gear change to 4.56 or buy mine lol
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S
710whp
FRS Justin is offline   Reply With Quote
Old 06-25-2015, 03:15 AM   #16
#maverick#
#maverick#'s Avatar
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
Current:
Manual Transmission
Relevant info:
2013 FRS
E85
Stock Gearing
7450 RPM rev limit
7800 RPM rev limit
I have a 245/45/17 on my stock wheels i still have to shift into 5th. Im not too good with with gearing but i think throwing a 3.73 is300 diff might help.
i hate it when you run out of gear and hit the rev limiter it just falls flat on its face instead bouncing off the rev limiter
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
#maverick# is offline   Reply With Quote
Old 06-25-2015, 09:22 AM   #17
Dream20b
Y u do dis?
What is your rev limiter set at?
Dat Hot Lava Doe
Clearly you have no clue what you are talking about. Everything you said was completely and utterly the ramblings of a babbling idiot regurgitating garbage from his mouth. Everyone here is now dumber from reading your post. Please die now.
Dream20b is offline   Reply With Quote
Old 06-25-2015, 10:20 AM   #18
Kdej1
Colten Drew
Kdej1's Avatar
Drives: '13 Fr-s // '95 Civic // '09 Vette
Current:
Manual Transmission
Relevant info:
2013 FRS
E85
Stock Gearing
7450 RPM rev limit
7800 RPM rev limit
What was the 60ft on this run? And how was the traction through 1st?
Kdej1 is offline   Reply With Quote
Old 06-25-2015, 11:27 AM   #19
Dream20b
Y u do dis?
This particular 60 ft was 2.003 and the traction in first was nothing to write home about. The lowest I've gotten was a 1.9 60' on these tires.
Dat Hot Lava Doe
Old 06-25-2015, 12:51 PM   #20
#maverick#
#maverick#'s Avatar
8000
The Following User Says Thank You to #maverick# For This Useful Post:
Dream20b (06-25-2015)
Old 06-26-2015, 07:04 PM   #21
Kdej1
Colten Drew
Kdej1's Avatar
If you end up getting larger tires, it could help your 60ft alot.. The lower your 60 get the lower your trap speed gets. The lower the trap, maybe it'll help with not touching the limiter..
The Following User Says Thank You to Kdej1 For This Useful Post:
Dream20b (06-26-2015)
Old 06-29-2015, 10:57 AM   #22
Dream20b
Y u do dis?
received my re-tune from @moto-mike today, Will be going to the track again soon, and posting some new numbers, hopefully.
Dat Hot Lava Doe
Old 06-29-2015, 11:15 AM   #23
STV3
Señor Member
STV3's Avatar
We need a drag racing thread.
What setup are you guys running. Clutch, SC or TC, Tires, Suspension, misc?
I have p&l's kit and I launch at 4000 on 245/45/17 nitto nt555rs, @ 25 psi it wheel hops nasty, at 18 - 20 psi it wheel hops but not as bad.
What are you guys running, curious to hear other people's setups
Ditch the drag radials and get a set of drag slicks. When you launch, the sidewall wrinkles and that takes a lot of strain off the drivetrain and will help with that wheel hop.
STV3 is offline   Reply With Quote
The Following 3 Users Say Thank You to STV3 For This Useful Post:
#maverick# (06-29-2015), Dream20b (06-29-2015), johan (06-30-2015)
Old 06-29-2015, 11:34 PM   #24
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Didn't realize that was you...NICE TIME!!! Making the most out of that blower for sure.
Xero-Limit is offline   Reply With Quote
The Following User Says Thank You to Xero-Limit For This Useful Post:
Dream20b (06-30-2015)
Old 06-30-2015, 12:07 AM   #25
johan
Drives: '14 981CS, '99 NB1
This!
Launching with boost on street tires (and drag radials are even worse) is a one way trip to something in the drivetrain breaking.
Get slicks, make sure the wheels are hub centric (or have hub centric rings), run them at 10-11psi hot. Smoke them in the water box, launch at 6500rpm. Profit.
If you're serious about getting the best time out of your setup, slicks are the only way to go. Anything else is just a waste of tire/clutch/drivetrain. I would bet money that slicks will completely eliminate your wheel hop unless you start making more than 400whp. Messing with bushings is just going to make your car more harsh and won't make you go any faster.
Background: I have over 250 passes at the track. In cars ranging from 150whp to 650whp.
johan is offline   Reply With Quote
The Following 2 Users Say Thank You to johan For This Useful Post:
#maverick# (07-02-2015), Dream20b (06-30-2015)
Old 06-30-2015, 02:30 PM   #26
FRS Justin
I have launched at 7600 rpm and ran a 1.88 on drag radials. 86's are light hook up well with the right suspension mods and adjustments. I would not run less than 15psi in the rear any lower and you are just adding rolling resistance...
710whp
Old 06-30-2015, 11:55 PM   #27
sosick
fastest frs in sbg
sosick's Avatar
Drives: sick ass ultramarine frs
I did a few more test hits.... on a road in mexico...
I set my air pressure in back to 16 psi. Raised the 2 step to 6000 rpms to build about 4-5 lbs of boost to do a burnout. Lit them up for 6 seconds or so.
Lowered my 2 step to 5250 - 5300, preloaded the drivetrain with the hand brake, and slipped it out aggressively. I spun for about 20 feet and then it hooked and booked. No more wheel hop
Road totally differnt from track tho shouldve tried this on the track
2013 ultramarine frs sold
2014 turbo ultramarine frs Sold
2014 firestorm frs
sosick is offline   Reply With Quote
The Following 2 Users Say Thank You to sosick For This Useful Post:
#maverick# (07-01-2015), Dream20b (07-01-2015)
Old 07-03-2015, 11:04 PM   #28
Kdej1
Colten Drew
Kdej1's Avatar
I have personally always used the ebrake to help preload.. I'd say it's definitely good practice
CounterSpace Garage Forced Induction || Jackson Racing | Edelbrock (IN STOCK!!)|| CounterSpace Garage Forced Induction 66 08-09-2016 01:59 PM
close. bought jrsc BRZ'13 Canada Classifieds 13 05-29-2015 03:46 PM
For all you Forced Induction Drag strip guys BadBRZ Forced Induction 25 09-04-2014 10:14 PM
going forced induction ft86me Forced Induction 14 02-05-2014 08:23 AM
Forced Induction Primo86 Engine, Exhaust, Transmission 11 05-29-2012 07:50 PM
