Old 06-26-2015, 02:12 PM   #253
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by civicdrivr View Post
And honestly, if you're understeering, just give it a boot-full of throttle and oversteer it out
another way to think about it is if your understeering, youre not driving fast enough.
cdrazic93 is offline
The Following User Says Thank You to cdrazic93 For This Useful Post:
civicdrivr (06-26-2015)
Old 06-27-2015, 04:02 AM   #254
cf6mech
Drives: FRS Silver LS1 swapped.
Originally Posted by ZDan View Post
FA20 may be heavy for an aluminum 2.0 four cylinder, but it is certainly lighter than a 450 lb. LS engine.
The boxer may sit relatively forward, but it's a lot *shorter* than an LS. So that even with the cylinder heads back against the firewall, there's no way the LS c.g. is aft of the FA20's, indeed it looks to be forward of it.
The FA20 tranny/engine combo is in fact 480lbs,...with the light tranny almost ending under the dash,i.e.requiring remote linkage , putting overwhelmingly the bulk of that 480lbs. indeed very forward.
"The engine block is short front-to-back (only 18" long) but it is placed in the engine bay way too far forward. So far, in fact,that more than 1/2 of the mass of the engine is in front of the front axle centerline. This is very strange, and I cannot say why the Subaru and Toyota engineers that designed this chassis and drivetrain placed the engine so far forward. They even had to use an extra long bellhousing and a crazy long shifter extension on back of the transmission to get the gear shift lever far enough rearward to mate up with the driver in the cockpit. My calibrated engineer's eyeball says this stock motor could be moved back by another ~10", which would help the front to rear weight balance significantly; in stock form we measured 56% of the weight on the front wheels, and our Alpha tester's modded FR-S has a 55%F/46%R weight bias."
cf6mech is offline
Old 06-27-2015, 09:17 AM   #255
ImBatman
My Tumbler is an FRS
Drives: exclusively in the fast lane
Originally Posted by cf6mech View Post
Our Alpha tester's modded FR-S has a 55%F/46%R weight bias."
101%
That's a heavy car.
All jokes aside, that's a sweet swap dude. Bring her to Houston so we can appreciate the outstanding work Vorshlag did down here too I wanna hear her rumble in person!
ImBatman is offline
The Following User Says Thank You to ImBatman For This Useful Post:
cf6mech (06-27-2015)
Old 06-27-2015, 01:19 PM   #256
ZDan
ZDan's Avatar
Drives: '23 BRZ
Originally Posted by Jaden View Post
I had started to respond as to why but then stopped. It has to do with the double fulcrum that two axle vehicles have.
Think of it as two sideways L's where the long part of the L represents the frame of the car and the little part of the L representing a line going to the ground at the axle line.
The front rear bias will be based on a division of where the balance of the weight resides on the length of each L, so shifting backward a balance point on the two L's can have a significant effect on the F/R bias because it affects both the fulcrums balance points, not just one.
What I think you are getting at is how cornerbalancing works. You can adjust weight on the front right + left rear vs. front left + right rear all you want, all the way to teetering on one of the diagonals. But front/rear and left/right weight distribution are strictly a function of the fore/aft and left/right locations of masses, and there's nothing magical going on with imaginary Ls. Move a 100 lb. mass 10" aft and the vehicle c.g. moves according to that mass percentage of total and the 10" movement relative to wheelbase length, that's all.
Take a 480 lb. engine/trans centered ~6" aft of front wheel centerline, and add a ~580 lb. engine/trans centered ~12" aft of of front wheel centerline (I think this is *very* optimistic btw!) on a car that starts at ~2750 lb split 1512/1238 (55/45) and with a 101" wheelbase, and you are taking 480 lb * [(101"-6")/101"] = 451.5 lb. off of the front wheels, and adding 580 lb. * [(101"-12")/101" ] = 511 lb. back on, ending up at 2850 lb. split 1571.5/1278.5, 55.1/44.9. Hey, not bad...
Looking at the pics of where the 450 lb. LS engine winds up, and noting that the engine alone only weighs only 30 lb. less than stock engine with transmission, I would be very surprised if the c.g. of the LS/T56 is situated more than 6" aft of the stock FA20/6-speed, if that far.
Anyway, to get from stock 55/45 to 53/47 or 52/48 with LS/T56 swap is going to require other stuff going on, but yeah, I am beginning to see it happening with the battery moving from in front of the front wheels to behind the rear wheels (and maybe A/C delete?)...
*ANY*way, very impressive even to get 55/45, anything better than that I'd call a major victory
ZDan is offline
Old 06-27-2015, 06:14 PM   #257
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
CoG........................... creating stupid arguments since Archimedes 287BC and then relentlessly resurrected by FT86Club enthusiasts
Lame
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline
The Following 3 Users Say Thank You to AZFA20 For This Useful Post:
cdrazic93 (06-27-2015), cf6mech (06-27-2015), civicdrivr (06-27-2015)
Old 06-27-2015, 09:29 PM   #258
cf6mech
Lame indeed.....insightful point. Over all weight was and is my main concern. COG actual improving ......... a footnote.
cf6mech is offline
The Following 2 Users Say Thank You to cf6mech For This Useful Post:
cdrazic93 (06-27-2015), civicdrivr (06-27-2015)
Old 06-28-2015, 08:34 PM   #259
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
@cf6mech who cares about numbers, blah blah blah. I just want to sit passenger side for like 30 seconds lol. Numbers are great but my butt dyno is the only measure that matters to me. And also the butt g meter. And go ahead and add smiles per mile to that too
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline
The Following User Says Thank You to carbonBLUE For This Useful Post:
cf6mech (06-28-2015)
Old 06-28-2015, 09:45 PM   #260
cf6mech
Vorshlag has intentions of bringing it out for Dallas Cars And Coffee when its ready.
cf6mech is offline
Old 06-29-2015, 01:54 PM   #261
carbonBLUE
Reverse Burnouts
This weekend?
(wont forget you)
2011 Infiniti G37x
Old 06-29-2015, 02:30 PM   #262
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
If you dont show up in the most american way possible i will be disappointed. Also video proof is required.
The Following 2 Users Say Thank You to cdrazic93 For This Useful Post:
civicdrivr (06-29-2015), wparsons (06-29-2015)
Old 06-30-2015, 05:45 AM   #263
cf6mech
Car will be at Cars and Coffee this weekend for interested parties.
cf6mech is offline
The Following 3 Users Say Thank You to cf6mech For This Useful Post:
cdrazic93 (06-30-2015), civicdrivr (06-30-2015), wparsons (06-30-2015)
Old 06-30-2015, 10:00 AM   #264
Captain Kermit
Drives: 1981 Holden Commodore
This gives me the horn.
Once you've got this sorted what are the odds of looking into a right hand drive version?
Captain Kermit is offline
The Following User Says Thank You to Captain Kermit For This Useful Post:
Kiwi Greg (09-16-2015)
Old 06-30-2015, 10:43 AM   #265
Basket Case
Drives: 2013 Raven fr-s
really looking forward to learning more details on this as in how much modification (cutting/welding) of the chassis is going to be required, etc.
Basket Case is offline
Old 06-30-2015, 10:55 AM   #266
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
If you look back in this thread it is expanded.
The tunnel support for the trans is removed and replaced. Can be done with a spot weld bit.
That is a must for this particular transmission.
Nothing serious.
That's it.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline
The Following User Says Thank You to Floggin Tires For This Useful Post:
FS: KW V3 Coilovers w/ Vorshlag Front Camber Plates Steeze_Its Brakes, Suspension, Chassis 7 06-27-2014 10:32 PM
FS: Vorshlag Front Camber Plates h4nh Brakes, Suspension, Chassis 1 03-01-2014 11:49 PM
FS: KW V3 w/ Vorshlag camber plates & oem stock suspension (SF bay area) serial gixxer Brakes, Suspension, Chassis 18 05-20-2013 09:51 PM
WTB: Front Vorshlag Camber Plates YDNA Brakes, Suspension, Chassis 0 05-03-2013 06:31 PM
Maybe a repost, but have you seen the Vorshlag project car? Bart1 BRZ First-Gen (2012+) — General Topics 3 01-07-2013 02:19 PM
