Old 06-27-2015, 08:58 PM   #155
yomny
yomny's Avatar
Drives: 2013 FRS Whiteout
Originally Posted by erok81 View Post
@yomny - is your bov on the passenger side? The way my outlets were sized my ends up on the driver side...
Mines on the passenger side, check out the thread I mentioned on the post above yours. It's my install thread and I have a lot of detailed pictures.
GTX2867R, moto-tuned , tomei op , motiv fp , Invidia Q300 ti , Rota titan 17x9 +42 , nt555 255/40 , ST coilovers w/cascam , Hotchkis sways
yomny is offline   Reply With Quote
Old 06-27-2015, 09:01 PM   #156
yomny
yomny's Avatar
Originally Posted by moto-mike View Post
Those little drips are a pita @yomny. Hate to say it but really common with aftermarket turbo installs. Best thing I can say is don't use paper gaskets and clean the heck out of everything with brake cleaner before putting on any sealant. Then careful with the torque. Overdoing it will have the same effect. It is a low pressure system on the drain side (and coolant side really...) so you don't need torque so much, but a broad clean surface for the gasket maker to stick to and not lift off.
Thanks Mike, I'm going nuts with this. I'm talking with JDL sicnr the turbo is still under warranty t see if anything could be done. I'm taking off the turbo and this ahould allow me to clean things and reinstall the flange outside, seal it right and then reinstall as the access with the turbo on is a pain. Thanks for your feedback.
Old 06-27-2015, 09:03 PM   #157
erok81
Drives: 2015 BRZ
Yeah I checked your thread (a few times) but wanted to confirm just in case. Mine is on the other side. Weird.
erok81 is offline   Reply With Quote
Old 06-27-2015, 09:12 PM   #158
Xero-Limit
Xero-Limit's Avatar
Drives: JDL Turbo FRS, 335SC BRZ (ret)
Yup, I think that's a good idea. Let that cure real good and use the super high temp silicone since that cartridge does get hot and lots of radiant heat from the turbine housing. Ronnie & Jessie should be able to walk you through the best method of sealing that sucker up.
Xero-Limit is offline   Reply With Quote
Old 06-27-2015, 09:24 PM   #159
yomny
yomny's Avatar
Not sure why they changed the location though. Weird.
Old 06-27-2015, 09:26 PM   #160
yomny
yomny's Avatar
I was using the Toyota form in place oil pan sealant. Seems to stand the temps but I'll look into something for high temps spicifically. Thanks
Old 06-28-2015, 08:09 AM   #161
drambo136
drambo136's Avatar
Drives: 2013 Hot Lava
That's right, mark where the intercooler inlet and outlet would go, take off just what's needed and then drill some holes where the mounting tabs fall on the crash beam. I'm going to post some pics in a bit from my install thread.
@drambo136
Check out this thread, first post you'll see a few good pics of the cutting areas and how to mount. Notice the crash beam on the passenger side has a square hole right in front of the intercooler coupler, I had to cut this open to reach the nut for the bolt secure the intercooler mounting tab, the driver side already has access.
http://www.ft86club.com/forums/showthread.php?t=81623
Oops my bad I thought u bought a aftermarket crash beam. I wanna be able to remove my grill without it looking dumb
Sent from my SAMSUNG-SM-N900A using Tapatalk
drambo136 is offline   Reply With Quote
Old 06-28-2015, 09:21 AM   #162
yomny
yomny's Avatar
Nah I wish I would have done so. The JDL bar mounts the intercooler right up without issues.
Old 06-28-2015, 02:22 PM   #163
erok81
Drives: 2015 BRZ
Last question from me then mine is done. How did you mount your oil feed? I tried looking through your pics but couldn't quite see how you did it. It looks like you might have tee'd into another sensor? Map used a port on the top. I didn't get anything but an oil line. So I'm probably going to have to pick up some additional hardware.
Edit: looking at my pack slip I should have gotten more hardware for the oil line. So tee'd off a sensor is the right way.
Old 06-28-2015, 03:27 PM   #164
NyC Zn6
NyC Zn6's Avatar
Drives: 10 Series #974 6m/t
Hey do you have the uel or el manifold..I am interested in this kit.. how has your kit been holding up.
Old 06-28-2015, 03:55 PM   #165
erok81
Drives: 2015 BRZ
Cute lil intercooler.
And my bov is definitely on the other side to yours. The paint is only on one side and its facing out. So it has to be right. Which again is weird because every turbo kit I've ever built or installed try to get it closer to the throttle plate. This move is opposite.
The Following User Says Thank You to erok81 For This Useful Post:
yomny (06-28-2015)
Old 06-28-2015, 05:28 PM   #166
yomny
yomny's Avatar
Thats odd. I'm using a precision turbo but I'm sure they make the adapters and include them for all their kits( i could be mistaken) but definitely give them a call, something has to be missing. It's a T that feeds off the engine oil light sensor, you plug the T in to the original port, the sensor goes on the bottom port of the T and the top port goes to the feed line. See below.
Old 06-28-2015, 05:30 PM   #167
yomny
yomny's Avatar
The kits amazing..my daily driver and couldn't complain. I have an EL manifold.
The Following User Says Thank You to yomny For This Useful Post:
NyC Zn6 (06-28-2015)
Old 06-28-2015, 05:31 PM   #168
Astroboy
Astroboy's Avatar
Drives: None
JDL turbo kit owners thread
Do you daily drive it? Yomney
Astroboy is offline   Reply With Quote
HKS Supercharger owners thread wbradley Forced Induction 1054 10-26-2024 01:18 PM
P&L Turbo kit Owners thread Hawaiian Forced Induction 73 07-07-2018 02:31 AM
To Greddy Turbo Owners (or SBD/Zage Turbo).... Melted Radiator Fans? General Opinion? xuimod Forced Induction 106 09-01-2016 07:33 PM
**Offical 213/323/626/818 owners thread** mr. slim Southern California 71 10-07-2013 12:58 PM
P&L Turbo Owners Topic Thread GTB/ZR-1 Forced Induction 4 09-01-2013 06:27 PM
