Old 05-29-2012, 05:42 PM   #43
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
Originally Posted by 7thgear View Post
just wanted to slightly correct your system for more clarity
Start Car
clutch in
Put car in first
release clutch slowly until car starts to move (slowly) without use of gas
clutch in
Do it again
clutch in
Do it again
This is perfect. The key part IMO is NOT using the gas at first when you're learning. Concentrate only on where the clutch grabs. If the car starts to stutter too much just press the clutch back in and start over.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
Old 05-29-2012, 06:20 PM   #44
DantKR
Drives: Subaru BRZ LT
7th gear stole my credit QQ
DantKR is offline   Reply With Quote
Old 05-29-2012, 07:48 PM   #45
serialk11r
Drives: '06 AM V8V Coupe
Originally Posted by (K) View Post
Yes, clutch uptake IS car specific. I'm not really sure what that bolded section of your post is leading to, would you mind clarifying?
Coming from automatic, it's more or less programmed into my head that when in doubt, hit the brakes. When I attempted to drive my uncle's car, I could get it started just fine, I could shift just fine, but I could never remember to press the clutch and the brake together, which led to many embarassing stalls and the car violently shaking. In particular his car would refuse to roll in gear with no throttle, you had to give it gas or else it would start to buck violently, so when that happened I could panic and press the brakes (and not the clutch).
Old 05-29-2012, 08:49 PM   #46
(K)
They call me..."Ken"...
Drives: '04 Accord V6 MT
It just seems like you don't have the proper response to the situation (near-stall, panic stops, etc), which stems from lack of seat time. I guarantee you it will become second nature when you get some proper seat time. You won't know until you try!
Hit me up on PM if you're really curious/frustrated/etc. with driving a manual. I'm no pro (far from it), but I get around . Honestly, I just think you need more time behind the wheel, everything else comes after.
(K) is offline   Reply With Quote
Where/How did you learn to drift? DommerEOD Off-Topic Lounge [WARNING: NO POLITICS] 8 06-20-2013 03:22 PM
Fuji Corporation FR-S and BRZ Wheel Fitting Room Configurator / Simulator Nardi330 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 39 05-13-2012 12:44 PM
Who needs to learn how to drive... RRnold Other Vehicles & General Automotive Discussions 14 08-27-2011 12:15 AM
Learn to Drive MtnDrvr86 Other Vehicles & General Automotive Discussions 102 03-14-2010 08:46 AM
