Old 06-19-2015, 03:16 PM   #127
PITTFRS
Drives: 2013 FR-S Hot Lava
I got mine today, it looks to be the same quality as everyone else. My only complaint is the packaging, there was not bubble wrap or anything just the header, a plastic bag over it and a box.
I will be test fitting tonight, and if all is well i will ceramic coat it and then do the full install. I will keep you guys updated on how it goes.
Originally Posted by Gaiakai View Post
If you're not driving like your car runs on the blood of virgins, you're doing it wrong.
PITTFRS is offline   Reply With Quote
The Following 2 Users Say Thank You to PITTFRS For This Useful Post:
Strife26 (11-07-2015), WhiteFRS69 (06-19-2015)
Old 06-19-2015, 04:55 PM   #128
WhiteFRS69
WhiteFRS69's Avatar
Drives: 2014 Scion FRS
awesome! keep us posted!
Old 06-21-2015, 12:35 PM   #129
PITTFRS
Had a family emergency come up so I haven't gotten a chance to get the headers test fitted yet but I may have some time later tonight
Old 06-25-2015, 02:49 AM   #130
Jake_86
Jake_86's Avatar
What's up wit a dyno
Gold Accented GT86 Build Thread
Live Fast, Die Young.
Jake_86 is offline   Reply With Quote
Old 06-25-2015, 07:16 PM   #131
PITTFRS
im gonna do a dyno, but its gonna be after all of my other mods are on so you wont be abel to tell what the gains are from just the header.
Old 06-30-2015, 05:25 AM   #132
cawith
Drives: Toyota GT86 6M/T
Thanks for all the pics. It looks like it's worth the money if you ask me. For those of us that aren't building race cars it will be fine.
Hi,
Mine just arrived today.
Can you or anybody tell me what the two bolts and crushers are for, if you could just use the original bolts?
cawith is offline   Reply With Quote
Old 06-30-2015, 06:09 AM   #133
PITTFRS
It's because on the stock header there are studs that attach to the stock over pipe.
Old 06-30-2015, 07:42 AM   #134
cawith
Ah okay, thanks!
Old 07-08-2015, 12:51 PM   #135
CaptivaBlueTeg
Drives: WRB Brz
Installed mine yesterday. I have to say, I used to work at a architectural metal shop and the weld were nice considering. When I looked at some of the more expensive headers I was not impressed with the welds. Yes, the collector could use some reworking on the inside, but it's what I could afford. Sound is amazing
CaptivaBlueTeg is offline   Reply With Quote
Old 07-08-2015, 12:55 PM   #136
WhiteFRS69
WhiteFRS69's Avatar
how was fitment??
everything aligns up?
Old 07-08-2015, 01:11 PM   #137
Bergen23
Drives: '15 Halo FR-S
Will update shortly after I get it installed. Should be done in a few hours.
Have to make it home from the airport first.
Bergen23 is offline   Reply With Quote
The Following User Says Thank You to Bergen23 For This Useful Post:
D_Thissen (07-08-2015)
Old 07-08-2015, 05:01 PM   #138
CaptivaBlueTeg
Drives: WRB Brz
Fitment to the block was perfect, not a fight at all. The flange to the over pipe was slightly off as far as a 1/16" gap on top, but once I torqued the bolts down it closed up. So, in other words, all holes lined up perfect and probably the easiest install I've done. Took me longer to pull the protective plates on the bottom of the car off and back on then the header swap itself haha. 1.5hrs for install, if that.
The Following 2 Users Say Thank You to CaptivaBlueTeg For This Useful Post:
DAEMANO (07-08-2015), WhiteFRS69 (07-09-2015)
Old 07-08-2015, 05:04 PM   #139
DAEMANO
Time Traveller
Question, were you switching from an all stock setup (header and overpipe), if so did you have to loosen/remove the overpipe to get the stock header off due to the stock header having the OP bols attached?
Old 07-08-2015, 07:20 PM   #140
CaptivaBlueTeg
Drives: WRB Brz
Yes, factory overripe and downpipe. I did not have to take off the overripe. Remove the nuts from the header/overpipe. On the downpipe, there is a hanger (halfway down the car) the hanger has two 12mm bolts, loosen those and you can lift up to pull up to unhook from the hanger and drop/pull the exhaust a little. That gave me more then enough room to pull the header out.
The Following User Says Thank You to CaptivaBlueTeg For This Useful Post:
DAEMANO (07-09-2015)
Borla Unequal Length Header Review and DIY F1point4 DIY (Do-It-Yourself) Guides 92 05-10-2021 04:06 PM
Tomei unequal length header Thatguyjeremy Engine, Exhaust, Transmission 5 02-11-2015 03:15 PM
WTB: FA20Club Unequal length header Chrisposey Want-To-Buy Requests 3 09-03-2014 02:59 PM
****Rev Works 4-1 UEL (Unequal Length) Header - $699!**** Rev Works Engine, Exhaust, Bolt-Ons 206 08-01-2014 05:10 PM
Unequal Length Header Noise fuse614 Engine, Exhaust, Transmission 55 07-30-2014 11:06 PM
