#3291 |
The Stig's German cousin
It gets you some more track width (helpful until you start hitting the fender) but width-wise it gets you an increase only in the rear. I don't see that as super helpful; most of the pointy end guys aren't fighting a lot of oversteer and I don't anticipate they will jump to take advantage.
Not to mention you lose the ability to rotate front to rear. Also if deemed legal you'll need to be careful on combinations. Your base offset must be the same for all four corners, as it's not possible to order the car with two normal wheels and two TRD wheels, and if you use the TRD offsets as your base you must run 7.5" wheels on the rear. |
#3292 |
i'm sorry, what?
Drives: Canada
going in for an alignment next week,
does anyone know which way the rear toe goes when the rear end goes up? if I set 0 toe with a full trunk and gas tank, how will this change when I take everything out and run 1/8th of gas?
#3293 |
NASA SpecE30 Racer
My understanding is that rear toe should change very little if any with rear ride height changes.
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
#3294 |
Drives: Series 10 FRS
Doug Gill with SCCA said that they are legal for 2015 models since they are available on the build your own part of the Scion website. Does anyone have any proof about the 2013/2014 FRS being the same (maybe there is a prior website or the dealer has an older order book with them)...
#3295 |
Drives: 2014 FR-S 6MT
So did anyone else have to clearance the top hat in the rear to get the Koni shock rod through it?
#3296 | |
Senior Citizen
Drives: Scion FR-S
Any personal emails answered are NOT official. You could still lose a protest without proper documentation. If there is a letter about this in the works, then we may be looking forward to a ruling next Fastrak. |
#3297 | |
I know the process (done it for MANY years at a National level and been thru the protest process and always won with proper documentation and following by the letter of the rules)... |
| The Following User Says Thank You to solort For This Useful Post: | simpleisbest (06-24-2015) |
#3298 |
Drives: 2014 FR-S
Yes you have to drill it out, use a bit that is as close to the stem size as possible, even to the point of buying one. This is one modification that is allowed for installing shocks.
#3299 |
Drives: 2015 Subaru BRZ Series.Blue
Hi guys! I will be autoxing this weekend and want to run as low fuel I can possibly do. I just want to make sure our cars doesn't have fuel starvation issue, right?
#3300 | |
In other news - CS is currently the largest class for Nationals, with 31 of 387 entries of this writing. This is my first trip out to Nationals, and I'm psyched to be a part of the healthiest class in the category.
#3301 | |
#3302 |
#3303 |
#3304 | |
Drives: Yes
| Cinco De Mayo SCCA SOLO | Ryeong86 | NY / NJ / CT / PA | 0 | 04-23-2013 05:22 PM |
| Koni Sports in SCCA SOLO | Ryeong86 | Tracking / Autocross / HPDE / Drifting | 4 | 04-22-2013 12:58 PM |
| 2013 Preliminary SCCA SOLO and PRO SOLO National Schedule | Scooby South | Tracking / Autocross / HPDE / Drifting | 13 | 12-05-2012 08:08 AM |
| Houston SCCA Solo #9 - 5 FRS, 1 BRZ | hankster | Tracking / Autocross / HPDE / Drifting | 0 | 10-09-2012 01:35 PM |
| SCCA Solo Car Class for the FR-S/BRZ? | MrVito | Scion FR-S / Toyota 86 GT86 General Forum | 31 | 06-15-2012 10:03 AM |
