Old 06-24-2015, 12:03 PM   #99
Shark_Bait88
Shark_Bait88's Avatar
Drives: 2013 Firestorm FR-S
Originally Posted by ajc209 View Post
haha - They were for the Toyota F1 car which didnt do all that well.....No idea if they supply any teams now. They are not all using Penske on the grid are they?
I know at least some other manufacturers are on the grid too; SACHS to name one.
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
Shark_Bait88 is offline   Reply With Quote
Old 06-24-2015, 12:12 PM   #100
Canehda
poverty cause racecar
Canehda's Avatar
Drives: Subaru BRZ JRSC'd
Ferrari I think uses Sachs, McLaren had always used Bilstein or Koni.
Canehda is offline   Reply With Quote
Old 06-24-2015, 12:26 PM   #101
RBbugBITme
Drives: S60R/Corvette
I can say that its pretty well known we worked with McLaren on the first inerter in 2005. Like I said before, some companies pay to have their name on the car and nothing else.
http://www.cam.ac.uk/research/news/s...erter-revealed
Ryan M.
Strange Engineering
Director of Suspension Development
RBbugBITme is offline   Reply With Quote
Old 06-24-2015, 12:32 PM   #102
Canehda
Canehda's Avatar
Sorry I was going off articles like this. Btw just out of curiosity have inerters found their way into sub racing applications yet?
http://m.crash.net/f1/news/57466/1/m...koni-deal.html
Old 06-24-2015, 12:34 PM   #103
Shark_Bait88
I definitely know Ferrari did from when Schumacher was driving for them at least up until Alonso in 2010 as well. I believe they still do, but not 100% on that. BMW Sauber runs them now, and Merecedes did in the 90s (not sure if that has changed though). They also supply clutches to many of the teams now.
Sorry to threadjack though. Back to the Penske discussion!
Old 06-24-2015, 01:22 PM   #104
RBbugBITme
Inerters are required equipment to have any chance in pro drag racing. World challenge banned them. Tudor banned them. I'm sure we'll get them on rally cars now that we're moving that way. Indycars run them every weekend. Rich guys can have them if they want, I believe the Roadster Shop Rampage Camaro will have inerters.
Mechanical inerters require a ball screw which is part of why its so expensive. We're working on a fluid inerter which would be a lot cheaper, so it can get banned at the lower levels of racing too.
Ryan M.
Strange Engineering
Old 06-24-2015, 02:21 PM   #105
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
Originally Posted by juliog View Post
Can we get Tein SRC++ performance and stock++ comfort if we throw enough money at these Penskes? Doable on 2-ways, or 3-ways a necessity to achieve the comfort goal over speed bumps and potholes at low speed?
Ofcourse. Get ready to put that kindey up on med-ebay.
Old 06-24-2015, 02:27 PM   #106
cdrazic93
Junior
cdrazic93's Avatar
Drives: a car
So all this time i see ferrari has electromagnetic dampers and the new z/28 rolls around with them quoting thousands of ajustments every second. Whats stopping someone from asking you guys to build one of those Ryan? Apart from the possible required materials.
Side note: For some reason i keep seeing this gps enabled suspension system, having a digital map of the course in its mind, taking into acount the corners, entrance and exit speed and lateral grip thus adjusting accordingly, being a very interestingly potent thing.
Sounds expensive but thats not what we're here for either lol
Old 06-24-2015, 02:32 PM   #107
RBbugBITme
They're garbage. Developed them with an F1 team first back in the day and found it wasn't worth it. The metal in the fluid tears everything apart so the shocks don't last and the fluid is too expensive to rebuild every week. They're also reactionary. They quote how fast they react because they can't predict the bump your about to hit, they can just respond to the input after its too late. There is an inherent flaw in that.
Ryan M.
Strange Engineering
Old 06-24-2015, 02:36 PM   #108
drewbot
( ͡° ͜ʖ ͡°)
drewbot's Avatar
Drives: '13 Whiteout FR-S A/T
@cdrazic93 while that sounds cool, I don't think a GPS with even the best of the best refresh rate could measure the nuances of track elevation changes, not to mention other things that race conditions (wet/dry and temps), tire compound temps, tire pressure, etc
-fellow engineer
drewbot is offline   Reply With Quote
Old 06-24-2015, 03:02 PM   #109
Hoosier Daddy
Drives: '13 Denali, '15 Volt, soon a BRZ?
Although originally legal when your product was first released, they have been banned since at least 2013 season as per rule 14.11.4. and 14.11.11.
In any event, I'm excited about the news of these products coming to market for the BRZ/FRS/GT86!
Hoosier Daddy is offline   Reply With Quote
Old 06-24-2015, 03:12 PM   #110
RBbugBITme
http://www.indycar.com/Fan-Info/INDY...Specifications
Rule 14.11.1 Dampers are an open development component, provided they otherwise comply with these Rules.
14.11.4 No front or rear third dampers, inerters or any other device are permitted nor any modification to the manufacturer supplied parts.
14.11.11. No independent inerters or mass dampers are permitted.
Basically by the time they wanted to ban them we sold so many too many teams would have had expensive piles of scrap so the corner damper/inerter hybrid is legal because corner dampers are open for development.
Ryan M.
Strange Engineering
Old 06-24-2015, 04:06 PM   #111
Hoosier Daddy
Well I'll be.
Why didn't IndyCar just ammend 14.11.3 to say "Each corner must have one damper and one spring. Helper springs, bump rubbers and
packers, as well as inerters are permitted..."
Old 06-24-2015, 04:12 PM   #112
RBbugBITme
Probably because they wanted to make sure everything from an inerter was contained inside the damper body.
Ryan M.
Strange Engineering
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
More info on Penske shocks ayau Suspension | Chassis | Brakes -- Sponsored by 949 Racing 156 04-28-2015 10:22 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
Ultimate Racing Exhaust help psyclone07 Engine, Exhaust, Transmission 0 07-06-2014 11:05 PM
Ultimate Racing, quality? rhythmM Engine, Exhaust, Transmission 5 11-30-2013 05:46 PM
