Old 06-23-2015, 10:47 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
Shouldn't all the pulleys be cogged? That seems to me like it would be the obvious answer.
Old 06-23-2015, 11:13 AM   #16
John92
Drives: White scion frs
I drove from WA to FL no oil cooler and the only problem I had my whole trip was due to bad fuel. I have not snapped a belt yet, and you should run clogged idler pulleys just saying.
John92 is offline   Reply With Quote
Old 06-23-2015, 12:41 PM   #17
Cheeseballs
Cheeseballs's Avatar
Drives: Really slow
Originally Posted by themajesticone View Post
This doesn't happen on the JR kit as far as I have read, no?
lolololol......No. This does not happen with the JR kit. The JR kit actually has good quality and support behind it.
Cheeseballs is offline   Reply With Quote
Old 06-23-2015, 01:55 PM   #18
themajesticone
themajesticone's Avatar
Drives: '13 UM86
That is what I understood as well
JRSC C30 91 oct | JDL UEL Header | Tomei Overpipe | Milltek Front Pipe | Milltek Catback | SPL LCA v2 | FA 500 v5 Coilovers 6k/7k | SPC Front Camber Bolts | Enkei RPF1 17x9 +35 | 245/40 Michelin Pilot Super Sport
themajesticone is offline   Reply With Quote
Old 06-23-2015, 02:23 PM   #19
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
The KW belts may not regularly break with light street usage, but the cogged design means that they will experience shock when transferring power to the pulleys and when that energy repeats in intense fashion (track abuse) they can only take that shock so many times before giving out.
Originally Posted by CSG Mike
Here's an analogy. When drag racing, if you bog your engine and the tires hook.... you'll probably break something. But, if you get wheelspin, all that excess energy, instead of being absorbed by the drivetrain (transmission, driveshaft, differential, axles), gets burned up as tire smoke.
No play = something has to take the force when you do a hard shift. Normal belt systems are intentionally designed to momentarily slip to release the energy. With Kraftwerks, the belt has to take all that load, and it can only do it so many times...
This is why Rotrex doesn't recommend cogged belts/pulleys to drive their superchargers.
Old 06-23-2015, 02:55 PM   #20
KraftWerks
KraftWerks's Avatar
Drives: Kraftwerks BRZ
Originally Posted by D K View Post
There is a reason why Rotrex doesnt recommend cogged belt for this application.
Call Jackson Racing and see if they will sell you just the bracket and piping?
Please show us where Rotrex doesn't recommend the cogged system?
Where does a belt failure show poor quality of the kit or poor quality it service?
Again, please show us where Rotrex has stated the recommendation against a cogged system.
There are plenty of users, some even here, without issues. Rotrex representatives themselves have given many compliments and praise to both the cogged design and divorced belt drive-system that we offer.
KraftWerks is offline   Reply With Quote
Old 06-23-2015, 03:01 PM   #21
ATL BRZ
ATL BRZ's Avatar
From http://www.rotrex.com/media/5fd67e23...20Handbook_pdf
Ribbed are the standard as the handbook states. Cogged is non-standard so it's insinuated that they do not recommend them.
Old 06-23-2015, 03:04 PM   #22
D K
Stig's dark passenger
I have an email trail....
D K is offline   Reply With Quote
Old 06-23-2015, 03:06 PM   #23
D K
Looks like Atlanta beat me to it....
Anyway, thats the PG13 version.
My conversation was considerably more direct.
Old 06-23-2015, 03:41 PM   #24
slipdog
slipdog's Avatar
Drives: 2013 WRB BRZ
Nowhere in that paragraph or in the design specifications in 6.1 or 6.2 does it say to not used cogged pulleys.
slipdog is offline   Reply With Quote
Old 06-23-2015, 03:51 PM   #25
ATL BRZ
ATL BRZ's Avatar
That insinuation in the user manual that I highlighted along with all the evidence of broken belts from the end users who are tracking KW kits is enough for me to understand that it's not a good idea to use a cogged system regardless of it being explicitly stated.
Old 06-23-2015, 04:34 PM   #26
themajesticone
Drives: '13 UM86
@slipdog
You can also argue that the fact they specifically put,
"Not following these specifications voids warranty and may result in permanent damage of the supercharger system and/or other systems in the vehicle/application"
...explicitly states it is highly not recommended as well as discouraged because of the above said repercussions.
Old 06-23-2015, 06:11 PM   #27
Andrew025
Andrew025's Avatar
Drives: Neptune GR86
I want to see it
Old 06-23-2015, 06:22 PM   #28
Cheeseballs
Drives: Really slow
One belt failure doesn't do that. Multiple and repeated failures does.
I cannot comment about your service since I have never, nor will ever, buy a Kraftwerks product. Hell, I won't even abbreviate your name because I feel like I am somehow sullying the people who I humbly consider the real KW (the suspension company) by doing so.
I can speak with high regard for Jackson's quality of service since I have experience with them though.
Anyway good luck luck OP. I hope you get all these issues sorted out for the better.
forced induction, kraftwerks, supercharger
Wtb: kraftwerks supercharger darnbry Want-To-Buy Requests 1 08-31-2014 02:04 PM
F/S Kraftwerks supercharger kit captain_jack Engine, Exhaust, Bolt-Ons 27 06-10-2014 10:34 AM
Kraftwerks Supercharger kit-Now stocked at JRP Stav Canada Classifieds 4 05-27-2014 09:07 PM
KraftWerks SuperCharger Ocho Seis CANADA 18 04-06-2014 10:33 PM
Kraftwerks Supercharger?? umpadupa Forced Induction 1 08-05-2013 05:27 PM
