Old 06-23-2015, 10:24 AM   #15
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
I would clock that turbo center section so that the oil feed and drain are more perpendicular to the ground.
The Following 2 Users Say Thank You to King Tut For This Useful Post:
Amir Ghadiri (06-27-2015), raven1231 (06-23-2015)
Old 06-23-2015, 11:30 AM   #16
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Much respect, this is the definition of DIY!
Old 06-23-2015, 11:32 AM   #17
TurboBRZ
TurboBRZ's Avatar
Drives: 2013 BRZ Limited
Thank you for the feedback. I will look at doing this before the engine goes in the car
The BlueBaru Turbo Rebuild: http://www.ft86club.com/forums/showthread.php?t=90382
I Rebuild BRZ's for Breakfast.
TurboBRZ is offline   Reply With Quote
Old 06-23-2015, 11:33 AM   #18
TurboBRZ
TurboBRZ's Avatar
Originally Posted by WhiteFRS69 View Post
why you going with an FRS bumper over the BRZ????
And it's fun confusing people lol. I think I should call this my BR-S, rather than BRZ. I'm not loyal to either manufacturer lol.
The Following User Says Thank You to TurboBRZ For This Useful Post:
WhiteFRS69 (06-23-2015)
Old 06-23-2015, 12:37 PM   #19
Hmongfrs
Drives: Red
I had the same turbo kit on my car for about 2500 miles now, doesn't drive my car as much anyways the fitment is right on. no gap no leaks but the only problem was they send me a 50 trim snail instead of a 60 trim but this thing spool super quick.
Hmongfrs is offline   Reply With Quote
The Following User Says Thank You to Hmongfrs For This Useful Post:
Old 06-23-2015, 03:06 PM   #20
TurboBRZ
TurboBRZ's Avatar
So in bolting up the engine subframe the holes on the side that took the impact are about 1/4" off. I have found the main culprit - as the frame got bent a little bit on the rear mounts of the subframe. Now it's time to re-construct my DIY frame puller and get that sucker moved forwards! I'll post some pics later of the current position and the new position after the pull.
Nice to hear another person has the same turbo kit. Mine is the .60 trim and I'm looking forward to driving it. I'll likely upgrade to a bigger turbo down the line, but this seemed like a good (cheap) place to start.
Old 06-23-2015, 03:32 PM   #21
raven1231
This is exactly what I was going to do originally. I planned on getting the kit without the turbo and wastegate though and just sourcing my own.
Old 06-23-2015, 03:44 PM   #22
BPAuto
BPAuto's Avatar
Drives: GT-R, S2000, Evo VIII-X, BRZ, FRS+
This rebuild looks good, keep up the good work.
BPAuto is offline   Reply With Quote
Old 06-24-2015, 11:08 AM   #23
TurboBRZ
TurboBRZ's Avatar
It was really hard to get a photo of the engine sub frame being off alignment, but I did the best I could. I forgot to do the "after" photo, but the holes do lign up now after a 10,000lbs frame pull. I actually broke one of my ratcheting straps (the actual locking/tightening mechanism) during the pull lol!
What you're going to see in the photos is #1 the hole being off position. #2 the point on the frame that was bent that I strapped into for frame pulling. #3 how I pulled the frame. #4 drilling out the new frame rails. #5 a close-up of the drill holes. #6 - welding it back together.
I am still in the process of welding - just completed the driver side - and after this I will be doing the core support. Once that's done I will be grinding down all the welds, applying the auto-body seam sealer (rubberized caulk-like stuff), and in 2 days when my paint gets here it will get a new coat of 02C blue pearl. I'll post some more pics of the welds ground down and the rubberized sealer when I'm done!
The Following 2 Users Say Thank You to TurboBRZ For This Useful Post:
DAEMANO (07-07-2015), philooo (08-07-2015)
Old 06-24-2015, 11:42 AM   #24
8R6
8R6's Avatar
Drives: FRS
major props on doing all this yourself!!
8R6 is offline   Reply With Quote
Old 06-24-2015, 10:40 PM   #25
TurboBRZ
TurboBRZ's Avatar
Today I ground down the welds on both sides of the car, then sprayed the frame rails with a rubberized undercoat. After all the welding/grinding/undercoating is done of all parts (core support & frame rail braces) I will apply the 3M seam sealer before applying a base coat of paint. Then the engine goes back in.
Nice enough today my new Deatschwerks fuel pump arrived along with my Innovate LC-2, Omni 4 bar map sensor and Tosh86 single-piece aluminum driveshaft. This thing is seriously light weight! I haven't pulled the factory driveshaft yet - that will be on my list tomorrow.
In just a few days time (depending on when the paint arrives) the engine will go back into her rightful home.
8686 (06-25-2015)
Old 06-25-2015, 09:18 AM   #26
statik
Drives: 2017 RS3, 2013 BRZ, 2010 M3
awesome stuff! I picked up a salvaged BRZ as well for $10k though mine didn't need any frame work
statik is offline   Reply With Quote
Old 06-25-2015, 09:42 AM   #27
TurboBRZ
TurboBRZ's Avatar
Yeah, I bought a black BRZ (salvaged) at auction for $2k less that didn't need any frame work as well. Now I know what (exactly) to look for in the photos to make sure I never buy another car with damage to this extent. I would never make a dime on this car if I went to sell it, so it's perfect that it will become my daily driver lol.
Old 06-25-2015, 02:12 PM   #28
Turbowned
Turbowned's Avatar
This is impressive; normally I would poo-poo someone for putting a Chinabay turbo kit on their car but you're totally reconstructing that car and turbocharging it on the cheap; nothing wrong with cheap speed in this case!
The Following User Says Thank You to Turbowned For This Useful Post:
Vroomin86 (06-26-2015)
brz cx racing turbo, brz rebuild, brz turbo
Ultimate Racing Turbo Kit sweetfrs Forced Induction 34 12-17-2015 11:25 AM
Ultimate Racing Turbo Kit ganz954 Forced Induction 19 11-13-2014 10:34 PM
91 MR2 Turbo with KO Racing GT35R Turbo Kit Unleashed Cars for Sale/Trade 2 02-21-2013 05:18 PM
91 MR2 Turbo with KO Racing GT35R for sale/trade for FR-S turbo kit Unleashed Cars for Sale/Trade 8 02-20-2013 06:26 PM
