Old 06-21-2015, 04:44 PM   #1
Spartiduck
Drives: 2013 Subaru BRZ limited 2.0l
OFT Lost its data, corrupted wierdness.
Updated unit, flashed car with new off the shelf tune, went for a drive, didn't like the tune, seemed slower. put the old tune back on the tuner and looked at a data log. plugged tuner back into car and it failed, and was corrupted.
none of my data loads up on the openflash manager. please advise.
Debugging log file. http://spartiduck.com/logfile.zip
Spartiduck is offline   Reply With Quote
Old 06-21-2015, 04:54 PM   #2
cnk
Drives: '13 DGM BRZ Limited
The tune will seem slower because the car has to relearn after flashing.
Old 06-21-2015, 05:45 PM   #3
steve99
Drives: FT86
Originally Posted by Spartiduck View Post
Updated unit, flashed car with new of the shelf tune, went for a drive, didn't like the tune, seemed slower. put the old tune back on the tuner and looked at a data log. plugged tuner back into car and it failed, and was corrupted.
the only guys who can decypher that log are the openflash guys.
Did you update the template file to 7.2 as per downloads site and you should be on v20 ofm.
Try flashing your original tune back to car then use erase funbction on ofm to erase oft.
you will then have to read original rom again
else talk to the openflash guys on phone
Old 06-21-2015, 05:47 PM   #4
Spartiduck
No access ether way too or from pc or car
Sent from my SM-G900W8 using Tapatalk
Old 06-21-2015, 05:55 PM   #5
steve99
Drives: FT86
No access ether way to are from pc or car
Hopefully its still under warantee
Old 07-14-2015, 01:00 PM   #6
sevi21
Trackman
sevi21's Avatar
Drives: Raven Frs
This same thing just happened to me, I can't do shit. I'm not fucking impressed.
Instagram @admsevi
sevi21 is offline   Reply With Quote
Old 07-15-2015, 07:54 PM   #7
Tromatic
Has your PC (assuming Windows) auto-updated anything lately?
Old 07-24-2015, 02:38 AM   #8
Spartiduck
Fault in unit, being replaced np
The Following User Says Thank You to Spartiduck For This Useful Post:
steve99 (07-24-2015)
Old 08-05-2015, 09:17 PM   #9
Spartiduck
Received New unit today, updated but will not accept saved stock file.
Old 08-06-2015, 02:36 PM   #10
chickencornsoup
Drives: 2013
My OFT have similar problem.
chickencornsoup is offline   Reply With Quote
Old 08-06-2015, 02:38 PM   #11
Spartiduck
Contact oft via website they will most likely help you out.
chickencornsoup (08-07-2015)
Old 08-06-2015, 02:46 PM   #12
Shiv@Openflash
Shiv@Openflash's Avatar
Drives: 2013 FRS
That is correct. If you want to temporarily flash back to stock, you'll currently need to load a stock file in one of the 5 modified file slots. We are currently working on a revision to OF Manager that will let you manually load stock files into the original file memory slot.
Shiv@Openflash is offline   Reply With Quote
The Following User Says Thank You to Shiv@Openflash For This Useful Post:
TouchMyHonda (08-10-2015)
Old 08-06-2015, 02:48 PM   #13
Spartiduck
Alright makes sense
Lost a screw... Kody Issues | Warranty | Recalls / TSB 8 04-25-2014 04:31 PM
lost my step-dad 5/25/13. :( charged86 Off-Topic Lounge [WARNING: NO POLITICS] 49 06-02-2013 12:54 PM
WE LOST :( Johnp Scion FR-S / Toyota 86 GT86 General Forum 47 03-29-2013 04:10 PM
im lost... lol _F-R-S_ Mid-Atlantic 2 10-07-2012 11:04 PM
