Old 06-20-2015, 05:38 PM   #43
Captain Snooze
Because compromise ®
Captain Snooze's Avatar
Drives: Red Herring
Originally Posted by sykaka22 View Post
what is wheel size?
https://en.wikipedia.org/wiki/Wheel_sizing
Old 06-21-2015, 08:32 AM   #44
sykaka22
Drives: 2015 frs
i mean what is poster's wheel size man LOL
sykaka22 is offline   Reply With Quote
Old 01-06-2016, 04:39 PM   #45
sav
Official anti-BS squad
sav's Avatar
Drives: Toyota 86 High 6MT
Originally Posted by Spaceywilly View Post
I have these 4 pots on my wrx and the feel is pretty similar to the stock BRZ brakes. The wrx has crappy stock brakes so it's a big upgrade, but the BRZ brakes already have decent feel. I think the only real benefit you'll get from these is increased thermal capacity, and the bling factor. Just new pads and rotors will be fine for most people, and the other people probably should step up to a big brake kit. These 4 pots are very popular on rally cars because you can fit 15" wheels around them.
Not sure if this applies to the brz, but on the wrx another common upgrade is to install a legacy caliper bracket and legacy rotors, which are 1" bigger diameter but use the same calipers (same swept area). These shift the bias to the rear even more and together with the 4 pot brakes and SS lines it's an awesome and cheap setup on the wrx. Might be able to do something similar for the BRZ if the parts fit.
Cast iron. They are pretty heavy. I haven't had my BRZ brakes off yet but I would guess they are heavier.
A bit after fact and sorry if it's been mentioned before. Having doen this upgrade recently I have weighed the stock and WRX calipers.
Stock: 6kg
WRX: 5.4kg
Hard to believe they're actually lighter than stock but they are...
Toyota 86 High 6MT (Satin Pearl White)
95RON SAV Tuned
sav is offline   Reply With Quote
Old 09-03-2016, 04:00 AM   #46
Bobster
Drives: GT86 GTS
Can anyone tell me how this setup feels and braking performance?
Bobster is offline   Reply With Quote
Old 11-20-2017, 06:59 PM   #47
Wise
Circle Work Clerk
Drives: 2012 Mt. Fuji Red Toyota 86 GTS
These look like a solid choice for those who want to retain low offset 17x9's.
I have 17x9 +35 RPF1's and just upgraded my rotors to DBA T3 3000's. I wouldn't mind a more solid pedal feel though and a bit of bling so I'll definitely look into these.
Are the Subaru lettering a sticker or painted on?
Wise is offline   Reply With Quote
Old 11-21-2017, 01:28 AM   #48
finch1750
Undisputed El Presidente
finch1750's Avatar
Drives: Zenki 37J ZN6
Paint iirc. And if you have the ability to file metal down or just don't care if they say "NISSAN" instead you can get the ones off a Z32 for much less (they are the same caliper, check the thread here on the forum)
Wise (11-21-2017)
Old 11-21-2017, 02:01 AM   #49
sav
sav's Avatar
Embossed on GC8, stickers on the newer ones. The rears are stickers on all models.
95RON SAV Tuned
The Following 2 Users Say Thank You to sav For This Useful Post:
Racecomp Engineering (11-21-2017), Wise (11-21-2017)
Old 11-21-2017, 02:08 PM   #50
jamal
jamal's Avatar
Drives: Legacy GT
While they are "the same caliper," the mounting to the hub is different and they use different sized rotors. So you can't just bolt them up like the subaru branded part.
However, a company (kns brakes), does make a bracket to use them along with a larger 316x30mm legacy gt/ 15" wrx rotor.
jamal is offline   Reply With Quote
Old 11-21-2017, 05:10 PM   #51
finch1750
finch1750's Avatar
I knew the adapted was needed with the Z32 calipers. Thought they were needed with the Subaru versions as well for some reason (been a while since this thread was bumped lol). Probably makes the price a little more in line with each other.
But with the Z32 version there is less bias change and more thermal capacity with the bigger rotors.
Old 11-21-2017, 07:08 PM   #52
jamal
jamal's Avatar
Drives: Legacy GT
In the front, all subaru calipers bolt on to any other subaru. In the rear there are three different mounting setups so yeah to put the rear 2-pots on you do need an adapter.
I was thinking about the nissan + LGT rotor setup but it won't work with my winter wheels and I don't really need the bigger and heavier rotors.
The Following User Says Thank You to jamal For This Useful Post:
finch1750 (11-21-2017)
Old 12-06-2017, 08:28 PM   #53
Wise
Circle Work Clerk
Just bought a set of 06 WRX 4 pots off Ebay for $210 bucks.
Plan to refurbish and repaint them and found this link on another forum which I'll definitely follow and repeat the process.
https://www.i-club.com/forums/suspen...d-pics-236053/
The Following 2 Users Say Thank You to Wise For This Useful Post:
Kenny_LongWrench (12-08-2017), Racecomp Engineering (12-06-2017)
Old 05-15-2022, 04:38 PM   #54
Uncle86
Uncle86's Avatar
Drives: 2013 Fr-s
Thread revival apologies, I was going to go with ATS brakes and decided to go with 06-07 Subaru 4pots. Currently on the Stoptech Sport Kit (lines,rotors and pads) amazing upgrade. Question is if I swap out the front calipers will I have to pick up WRX pads and anything else? Thanks
Uncle86 is offline   Reply With Quote
The Following User Says Thank You to Uncle86 For This Useful Post:
sav (05-15-2022)
Who wants to see Wilwood Brakes vs. AP Racing Brakes ( Sprint Kit ) FT-86 SpeedFactory Suspension | Chassis | Brakes -- Sponsored by 949 Racing 119 12-17-2017 05:53 PM
How long will my brakes last? pinoyplaya Suspension | Chassis | Brakes -- Sponsored by 949 Racing 6 08-24-2012 11:21 PM
OEM Brakes? marinjim Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 3 08-20-2012 10:26 PM
GT brakes jello AUSTRALIA 2 06-10-2012 09:10 AM
